Tuesday, Jul 31, 2018 at 23:04
The special synthetic oil required for the Ford 6R80 auto transmission is called Mercon LV.
Every oil manufacturer produces a transmission oil which is fully compatible with, and meets Mercon LV specifications.
At $900 for a transmission oil change, you are being right royally shafted with the biggest pineapple they can find - large end first.
Sparesbox - Castrol Transmax transmission oil - meets Mercon LV specs
The main problem with these complex transmissions is that they have a very convoluted system of oiling, and oil passageways.
It takes quite a while to get MOST of the original oil out of the 6R80 transmission, after dropping the transmission oil pan.
To get ALL the oil out of an auto transmission, requires the line to the oil cooler to be removed, and the engine run for maybe 20 secs, to pump all the oil out of the torque converter, oil lines, and passageways.
I do not see Ford recommending this technique for the 6R80 oil change procedure.
The refill of the new oil in a 6R80 transmission is a complex and slow process, to ensure there are no air locks in the transmission oil and lubrication system.
An initial refill of 3.3L is pumped in, and the vehicle is driven until the oil is at 85 to 88 deg C. This enables any air in the transmission oil to be properly purged.
The oil level is then checked (with engine idling and the transmission in Park). If the level is low, it is topped up, very slowly - if it's overfull, the excess oil needs to be sucked out.
The new oil in these transmissions needs to be pumped into the transmission, using a special Ford transmission tool - a transmission fluid evacuator and injector.
If this transmission is accidentally overfilled, a special Ford transmission servicing tool - a hand-operated vacuum pump - is needed to remove the excess oil.
A Vehicle Diagnostics Scan tool (or Vehicle Communication Module, in Ford-speak) is needed to
check for correct operation of the transmission, and its operating temperature.
It sounds to me as if the Ford dealer is making you pay through the nose for the sheer pleasure of them using these special transmission servicing tools.
I would find an independent garage that has the ability to service the transmission in the Ford-approved manner, and get them to do it. These people exist - you just need to search them out.
Of course, if the vehicle is still under warranty, then Ford will insist that a Ford dealer do the transmission servicing.
Below is a link to a Ford technical bulletin download, showing the servicing of the Ford F150 transmission - and a link to the Ford Mustang transmission servicing - both of which vehicles use the exact same transmission as the Australian Ford
Ranger.
Ford F150 - 6R80 transmission servicingFord Mustang - 6R80 transmission servicing
If you do a Google search for "draining and refilling 6R80 transmission", you will get a lot of videos and discussions on 4WD forums, about the process.
Cheers, Ron.
620435
Follow Up By: RMD - Wednesday, Aug 01, 2018 at 08:14
How can there’s be air locks in a system which is pressure fed by a hydraulic pump?
Administering fluid to the inlet of the trans is the same is what happens all the time is running while driving.
If you are draining and refilling, preferably at the same time, the transmission doesn’t know anything has changed and can’t need any special testing gear.
Two sections of pvc pipe of sufficient capacity, interconnected so pressure transfer happens, will catch old fluid and inject new fluid at the same rate. Not hard, no special testing just sensible fluid replacement.
No complicated, involved, internet searching is required.
892870
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Aug 01, 2018 at 09:31
Ron,
Some years ago after becoming disillusioned by the service from a major Ford dealer I bought a new Ford from them. I then wrote to Ford head office and queried the requirement to maintain my warranty by exclusive Ford dealer service.
Their reply was that their requirement was to have the vehicle "serviced in accordance with the Ford provisions" adding that they doubted that I could find any independent service workshop who could meet those provisions. I took my chances and had all my servicing including the initial 1000k free service, done independently. Fortunately, I never had a warranty call to
test my resolve. These days we have a lawyer in the family! lol
Incidentally, the last straw of the first vehicle, a Cortina, was when the engine fell out. Yes, it really did. The securing bolts of an engine mount worked out leaving the engine at a crazy angle and the throttle cable stretched to produce a very fast idle! The bolts were the type with a flanged head and serrations on the flange face. A fortunately nearby workshop replaced all the mount bolts with high-tensile and spring washers. That's why they call me "Lucky Al" lol
892876
