Wednesday, Nov 20, 2019 at 16:45
RMD...My Pajero gives 2 readings...Pan temp and exit pipe temp. The alarm goes off at 147 degrees. The lock kit that many Pajero owners have fitted have been a huge success with no failures. It was developed and sold by a Pajero enthusiast with a smart technical mind. When using the converter we never see high temps and allows us to drive in full auto a lot more. Definitely a mod that makes for more relaxed driving and increased tranny oil life. It is also worth remembering that once the load has come off the unlocked torque convertor, after climbing a steep
hill and descending the other side of the
hill, the ATF temperature can continue to rise because the torque convertor is not locked up when there is not accelerator input. When the torque convertor is unlocked and the vehicle is "coasting" the ATF does not circulate through the ATF coolers so the ATF is stationary and sitting in a hot torque convertor. This is done to decrease
fuel consumption but at the penalty of overheating the ATF. So the ATF takes a long time to cool down, particularly in very hilly country and especially when towing.
Lockup Mate keeps the torque convertor locked up even when there is no accelerator input, this allows the ATF to circulate through the ATF coolers after the load has been reduced and results in ATF temperatures dropping rapidly. Auto Mate works slightly differently as it unlocks the torque convertor when coasting down
hill, however there is a special feature that locks the torque convertor up to provide downhill ATF cooling if the ATF is over 85C.
903233
