Not a bad innings for Mazda!
Submitted: Thursday, Feb 27, 2020 at 16:58
axle
On January30, 2020, Mazda celebrated its100th anniversary of its founding
Mazda originated as a company producing cork ,and then took the path to manufacturing
automobiles
The first Mazda motor vehicle was produced in 1931, called the Go it was a three wheeled motor cycle type truck
By 2015 Mazda had produced 1.5 million vehicles. for global sales
Mazda vehicles have a very strong reputation world wide and continue to sell very
Existing for 100 yrs is a pretty good testament
Funny enough..
Although I like the mazda sedans and we have had a few through out the family with very little trouble
the worst vehicle i've ever had myself was the E2200 easy load truck with that RB22 diesel engine what a shocker!...….LOL.
Cheers Axle.
Reply By: Kazza055 - Thursday, Feb 27, 2020 at 17:15
I quick google and I found this "As one of the oldest companies in the Japanese automotive industry, Isuzu traces its beginnings to 1916."
So Isuzu beats Mazda by a few years - even better ;=))
630230
Follow Up By: Member - cruza25 - Thursday, Feb 27, 2020 at 18:40
And Isuzu has produced 21 million Diesel engines since it started production
905519
Follow Up By: axle - Thursday, Feb 27, 2020 at 20:02
And i guess there all still running mate.....,..))
Cheers.
905521
Follow Up By: Ron N - Thursday, Feb 27, 2020 at 22:13
And I trust you all know, that Isuzu Motors is a division of Mitsubishi Corporation!! LOL
Cheers, Ron.
905523
Follow Up By: Gbc.. - Friday, Feb 28, 2020 at 06:08
May as
well add one - And Isuzu is building the next BT50
905524
Reply By: Member -Pinko (NSW) - Thursday, Feb 27, 2020 at 19:42
Axle 'tis peculiar how car manufacturers evolved.
Peugeot started in 1810 making coffee grinders and bicycles.
630231
Follow Up By: axle - Thursday, Feb 27, 2020 at 19:53
It sure is amazing with some of them Pinko!
Axle.
905520
Follow Up By: Shaker - Thursday, Feb 27, 2020 at 21:52
Jaguar started by building motor cycle sidecars, which is where the SS designation came from, Swallow Sidecars. Not Sport Special or Sports
Sedan as people think today.
905522
Reply By: Ron N - Thursday, Feb 27, 2020 at 22:18
Axle - I don't know what this RB22 engine is, that you talk of - but the 1980's E2200 Mazda vans and light trucks were powered by the 2.2L S2 Mazda diesel engine, which is a Perkins 4-135 engine built under licence by Mazda!
I have a Mazda E2200 van, and that little diesel is quite a good donk for the era.
Underpowered, at only 65HP, to be sure - but they are reliable enough.
I'd be interested to hear what kind of problems you encountered with your 2.2L Mazda diesel - apart from an inability to overtake anyone on the highway!
Cheers, Ron.
630232
Follow Up By: Gbc.. - Friday, Feb 28, 2020 at 06:11
The first series of Kia Ceres was also based on the Ford/Mazda and the Perkins S2S2. I had one for a few years. Yes, slow, but it toiled away and always got it done.
905525
Follow Up By: axle - Friday, Feb 28, 2020 at 08:58
Ron
It was the alloy head ones that gave trouble ,Probably early ninetys, head gaskets were a big fault they just leaked no matter what you did. There was a company that introduced a cast head for them and that fixed the issue,if you wanted to pay the dollars.lol. if I remember the early ones did have a cast iron head ,just a change they made for the worst. Might of made a mistake with the Rb22, ….sure it was RB 2.2l ,It was along time ago, the memory does fade a bit these days lol.
Cheers Axle.
905528
Follow Up By: Ron N - Friday, Feb 28, 2020 at 12:18
Axle - O.K. You had the R2 diesel, the model after the S2.
The S2 was cast iron head and block with timing gears - then Mazda replaced the S2 with the R2 (1987) with a synthetic fibre timing belt, initially with cast iron head, then later (around 1990?) with an alloy head.
They all run 22 to 1 compression ratio, the reason why the head gasket became a problem.
Cheers, Ron.
905531
Reply By: eaglefree - Friday, Feb 28, 2020 at 11:20
Was very interested inaMazda cx3. Read many reviews and of of a few faults was air conditioning condenser leaking meaning no cold air but main concern is Mazda’s reluctance in fixing it under warranty with the replacement depending how loud you yelled.
So we will look at a Suzuki vitara
Tony
630242
Follow Up By: Gbc.. - Friday, Feb 28, 2020 at 12:26
We just did that exercise. Ended up with a base model forester. Nearly went the XV. They Both drive so
well on the new platform. Good luck with the search. Everyone’s needs are different. We needed a back
seat that fitted 6 footers so the field narrowed quickly.
905533
Reply By: Norm F - Friday, Feb 28, 2020 at 14:59
My Mazda R360, 360cc air cooled V twin Automatic, 1964 model, I owned for 10 years, went quite
well for a little motor. Not very popular on our east coast but a lot in
Perth. Known as the "rabbit" for some reason - wish I still had it. Sold it via Southerby's Auction in 1989 & was told someone flew in from Japan just to take it home!
My Mazda R360
630250
Reply By: Phillip P5 - Friday, Feb 28, 2020 at 21:57
Mazda is cool but I prefer Peugeot actually
630258
Reply By: Ron N - Friday, Feb 28, 2020 at 23:43
I've got a Mazda forklift and it's powered by a 2 litre Mazda VA engine. The motor was worn out and in pieces when I picked up the forklift for $300 - and I set to and rebuilt the VA engine.
This little engine is built like a
tank with replaceable wet cylinder liners - and despite having done probably 10,000 to 12,000 hrs of hard, stop start work, I couldn't find any wear on the crankshaft journals.
I also dug about 2-1/2 cupfuls of muddy dirt out of the block, from the bottom of the liner area, testimony to the cooling system abuse it had received.
It had a fibre timing gear, which I don't like, so I found a Nissan H20 timing chain and sprockets fitted in place of the timing gears, with very little modification.
This little donk runs like a top, and in the era when these were built (late 1970's/early 80's), Japanese engineering was really hitting its stride.
I also have an '81 Ford Laser Ghia hatchback - a Mazda with Ford badges - another great little chariot, sips
fuel like a Mini, goes like a train, and I can fit a mind-boggling amount of stuff inside it when I fold the seats down!
I'm not sure how the latest Mazdas are for build quality and reliability, but the older ones were certainly pretty good.
A fascinating little snippet of historical news below, about how Mazdas founder, Jujiro Matsuda, survived the atomic bombing of Hiroshima.
How Mazda survived the bombing of Hiroshima.
Cheers, Ron.
630260
Follow Up By: axle - Saturday, Feb 29, 2020 at 10:16
Ron, my daughters have both had the later mazda 3, and not one problem with either in excess of a 100,000ks . At the time, the sales figues for private sales was
well above Toyota corolla
which for a while there was building some pretty ordinary vehicles.
Cheers Axle.
905562
Reply By: Bob Y. - Qld - Saturday, Feb 29, 2020 at 13:00
Was that truck the one with 4 speed box and a splitter, Axle?
Had never had anything to do with Mazda, until a daughter bought a 2nd hand 323 in 2004, and she still has it, with only a couple of hiccups over the past 16 years. Then another daughter bought a CX-3 turbo diesel, which suits her style of driving, and it’s been trouble free. In 2016, we bought a CX-5 twin turbo diesel, after 40 years of Holden utes, a Datsun Skyline, a Hilux dual cab & the remainder, Landcruisers.
The CX-5 is a great touring vehicle. Roomy, quiet & comfortable enough to knock over a 1K km day in 12 hrs, and not needing surgical removal from the cab, at end of the day. Economy is around 6.5-7L/100 at 100-110, giving
fuel range close to 800kms. Torque produced is only 30nm less than a stock V8 Landcruiser ute, from a 2.2L 4cyl engine. Pulls like a train!
630266
Follow Up By: axle - Saturday, Feb 29, 2020 at 15:00
G/Day Bob,
Just a light little truck small duals on the rear, actually could carry a load very
well , better than any car type ute, just a bit under powered,
No splitter box, although I thought I had a split box! one day when a horrible noise erupted from underneath, it was a gearbox bearing saying" ive had enough "...lol.
The CX5 sounds like a great unit.
Cheers Axle'
905572
Follow Up By: Ron N - Saturday, Feb 29, 2020 at 16:50
Bob, the Mazda trucks with the splitter were the T-series - the 6 cyl T4100, and the 4 cyl T3500.
They all had 5 speed gearboxes, the splitter made them 10 speeds. Nearly as good as a Kenworth! LOL
The E2200 Mazda truck was the "flat low" variety with small duals on the rear and bigger front
wheels, meaning you had to carry two spares.
Flickr - E2200 Mazda truck
Cheers, Ron.
905576
