Saturday, Jun 19, 2021 at 14:45
Stevemac
A re calibration of the
fuel gauge! does that allow for any
fuel above the normal sensor
fuel position which is not normally sensed until dropping to the normal FULL position? Only the
fuel usage calculated by the ECU can work out any above, but may be able to be added to read of distance to empty reading I suppose. I can't see the normal sensor knowing what is above it and it is still drowned until dropping to Full level. Just like any
tank sensor does.
Also, as you mentioned, the expanse of
tank and therefore, volume of
fuel below the normal Empty sensing is good as mentioned, but since there is a wide area, although you have
fuel in there, it may not be at the pickup when you need it and a bit hard to rely on it even though you can hear the sloshing.
It would be good to know how the whole LR
tank is recalibrated from full to reserve amount empty!
914808
