Battery and inverter questions
Submitted: Wednesday, Aug 18, 2021 at 01:31
ThreadID: 142398 Views:33516 Replies:11 FollowUps:4
We have been getting into camping but so far we have only been to powered sites and we take all our 240V electrical equipment but I am now looking into getting a battery and solar setup. i have been doing some reading but am totally overwhelmed with the info.
We are just 2 adults and we have a coleman northstar lighted 10 person tent and a 3m * 3m gazebo
I have bought some 12V lights already
At the moment we use the following 240V devices
kettle
laptop
electric blanket
heater
I have read about a 12V kettle but we already have a gas cooker (Coleman hyperflame fyre cadet) so can use that to boil water if needed, it is a very hot stove. Do people use kettles or stoves for boiling water?
There were 12V electric blankets but with mixed reviews. Can anyone recommend a brand or model? Are they as good as the 240V ones?
For a heater I couldnt see many if any 12V heaters for tents, but did see propane heaters, is that what people use for cold nights?
As I understand it we need a deep cycle battery and inverter, but I was thinking I could save on the cost of the inverter if I could get everything we currently have as 12V electric.
At some point we will buy a 12V fridge/freezer and either a 12V tv or projector
Then that leads onto how do I calculate what size battery I need and what size solar?
I realise there are a lot of questions but any help is appreciated even if it is just a link to another website!
Reply By: Allan B (Sunshine Coast) - Wednesday, Aug 18, 2021 at 08:08
Hi Bob,
For starters, forget about any form of heating using solar snd battery, it simply consumes too much power.
You may care to read this blog by John which covers the whole question.
Electric blankets aren't too bad. They only consume about 30 Watts each when on low so even the smallest 230v inverter will handle them.
Roughly, you will need at least 200W of solar and 100ah of battery, more if you run a TV for hours at a time. Remember, you are camping, not at home!
AnswerID: 637556
Reply By: Member - McLaren3030 - Wednesday, Aug 18, 2021 at 08:54
Hi Bob,
Firstly let me state that I am not an Auto. elec. or a 12 volt expert, just someone who has been camping in both tent and caravans for more than 50 years.
If you a seriously looking at Off Grid camping, forget about heaters, electric blankets and most other electrical appliances, they just draw too much power from batteries. Yes you can get your vehicle set up with enough batteries and charging capacity, but it will be very expensive.
You can get 12 volt kettles, but they take a very long time to boil, better off using an LPG stove. As for electric blankets, a good sleeping bag with the appropriate rating and a good “thermal” blanket should be sufficient for most people. Even high country campers in the snow do not use electric blankets. However, if you must, you need to consider the continuous power consumption on your battery.
As for sizing your battery and charging system, you need to look at all the electrical appliances that you want to run, and total up their power consumption in amps, and the number of hours you want to run them, this will help you decide how large a battery/batteries you will need. You state that you have not yet got a 12 volt fridge, when sizing your battery system, it would be prudent to factor the fridge into your equation so that you do not have to add additional batteries later on. IMHO, Lithium Iron Phosphate (LiFePo4) batteries with the appropriate charging system is the way to go. They are lighter, can discharge to a deeper State of Charge (SOC) without affecting their longevity, and will recharge faster with the appropriate charger.
Next as for charging these batteries, a good rule of thumb is that for every battery Amp, you need double the watts of solar capacity. That is, for 100 AmpHr of batteries, you need 200 watts of solar capacity. Of course, solar only works during the day, and for maximum efficiency, in full sun at the appropriate angle to the sun.
A good DC/DC charger with a high amperage output (greater than 30 amps) and solar controller should keep your batteries topped up from your car or sun. You need to remember that your charging system needs to be large enough to top up your batteries while they are still discharging.
You have not indicated if you have a ute with a canopy set up, or a wagon, or a sedan. Depending on your vehicle, this may limit what size battery system you can install. An 80 Ltr. compressor fridge/freezer will draw around 4 amps per hour when cycling. So if you factor that the fridge will cycle for about 16 hours per day, depending on ambient conditions and how often you open it, 16 x 4 = 44 amps per day. Worst case scenario if the fridge was to cycle continuously, that would equate to 96 amps for 24 hours. So, you would need at least a100 AmpHr battery just for the fridge, without anything else running. These numbers will vary depending upon a number of different factors. Size and make of fridge, ambient conditions, enclosed space etc.
In the back of my wagon, I have a 60 Ltr Engel fridge, with a 40 amp DC/DC charger and a 100 AmpHr LiFePo4 battery. I carry a 290 watt folding solar blanket for when I am stationary. In my caravan, I have a 190 Ltr compressor fridge, 200 AmpHr of LiFePo4 batteries with 390 watts of fixed roof mounted solar panels. I mainly camp off grid, sometimes sitting stationary for several weeks at a time.
I hope this info has been helpful.
EDIT, I do not have an inverter. I have just read Allans response and John’s blog. Very good info there.
AnswerID: 637557
Reply By: qldcamper - Wednesday, Aug 18, 2021 at 09:20
Hi Bob,
12 volt lighting in a tent is a pain because you need to have wires everywhere. We just use tripple A head lamps and a couple of tiny lantern type lamps that take a single D cell, they last weeks, the baby q has its own light as does the fridge.
Heating a tent is almost impossible to do safely, just heat the bed. We do what Alan said earlier, run a double electric blanket off a 350 watt inverter and a dedicated 80 ah battery with a 100 watt folding panel.
Your fridge is the big consumer, they dont draw a lot but it is a constant consumer that you have to be constantly aware of and dont be lazy getting your panels out as soon as there is light, even if it is cloudy it will still make a bit.
Definatly worth having a suitable charging system in the car to chare your accessory batteries but dont listen to the sales people that try to sell you thousands of dollars worth of un necessary bells and whistles that you dont need.
AnswerID: 637558
Reply By: RMD - Wednesday, Aug 18, 2021 at 09:59
Bob.
Unless you have a Tesla Power Wall, and sufficient solar panels, acres of them, the idea of heating a tent with 12v or 240v isn't going to happen. You can't use a gas heater in a tent, well yes you can, but it will only be the once, with eternal sleep from Carbon MonOxide emitted from the heater.
If you have enough solar panel area/wattage and a decent battery and charger you can use a 240v ac sleeping blanket as previously mentioned. The inverter can also be used to run a laptop power supply. All possible if Macca's accounting of usage/amp/hours is calculated. Ebay, Giandel 300W full sine wave for around $85 if needed. (Blanket and computer,)
The gas burner to heat a kettle will allow hot water, hot drink and easy packup in about the same time the 12v power hungry 12v kettle gets to boiling.
Running a fridge is another issue and requires it's own solar and battery unless everything is sensibly combined and allowed for and sufficient solar and battery/s to handle the lot is provided.
We all spend hundreds to save dollars.
Tv and Projector? aren't you camping? ie, getting away from it all!
AnswerID: 637559
Reply By: Member - Jim S1 - Wednesday, Aug 18, 2021 at 12:02
Hi Bob ….. just my thoughts …
To enjoy camping you need a sound sleep. Get good quality down sleeping bags, some form of comfortable mattress, and a couple of mohair blankets for cool , not cold nights.
Some battery lights maybe, but definitely get some good headlamps.
A gas stove, with non-stick frying pan.
Comfortable folding chairs are good.
A good sized 12v fridge, with appropriate power and charging.
Solid comfortable shoes and warm and waterproof jackets and away you go.
The simplest camping you can manage will be the most enjoyable.
Jim
AnswerID: 637561
Reply By: bob j4 - Wednesday, Aug 18, 2021 at 19:10
Thanks everyone for your replies, all good info for me to go through!!
AnswerID: 637565
Reply By: Tony F8 - Friday, Aug 20, 2021 at 19:29
Here is a simple way to gain or lose a few degrees, we have the old Barcoo style swag, basically a canvas envelope with zips, now get yourself a solar blanket to fit, in summer the shiny side down, and in winter the shiny side up, btw it is placed under the mattress, and you will be very surprised by the results
AnswerID: 637595
Reply By: bob j4 - Saturday, Aug 28, 2021 at 19:09
So I have been looking into Batteries and solar panels and have a few more specific questions...
So battery choices seem to be AGM or Lithium am I correct in saying
AGM are cheaper but arent as good as Lithium, but as we are only going to be using it maybe 10 times a year will an AGM battery will be good enough for us?
I have been looking at AGM batteries and there seems to be quite a difference in price from brand to brand, so are there some brands to avoid or go for?
At Snowy's they have
Zeal 105Ah - $299
Zeal 125Ah - $349
At Battery world
Century 105Ah - $399
Century 120Ah - $449
Is there a great difference between the brands?
Solar panels
I was looking at the fold up blankets as they are easier and smaller but then I was thinking that the solid panels are easier to angle towards the sun, but still think I will go with the fold up blanket.
So again do the brands make much difference?
https://ontrackoutdoor.com.au/products/solar-blankets?variant=16069399904358 I would get the 300W version as it is only slightly more expensive than the 200W one
or there is this XTM 200W from BVC for similar price - https://www.bcf.com.au/camping/power-and-household-batteries/solar-power
As I have been writing this I found this - https://outbax.com.au/voltx-12v-100ah-lithium-battery-maxray-200w-folding-solar-blanket-bundle this seems a very good combo deal including a lithium battery
AnswerID: 637699
Follow Up By: Genny - Saturday, Aug 28, 2021 at 21:37
Google Outbax reviews .....
FollowupID: 915791
Follow Up By: Nomadic Navara - Sunday, Aug 29, 2021 at 15:55
"Is there a great difference between the brands?"
There could well be. When comparing batteries, look at their weight. There are a lot of batteries out there that do not have sufficient lead in them for the capacity of the battery. This means their capacity is overstated. Look for AGM batteries that weigh at least 32 kg per 100 Ah of capacity.
It is a similar story with solar panels, when comparing solar panels, when comparing panels also compare the cell area of similar types of panel.
FollowupID: 915814
Follow Up By: Member - Warren H - Tuesday, Aug 31, 2021 at 17:01
I've the earlier 100 watt version of the BCF solar blanket. So far been OK, but I've not used it a lot. My main issue, which would be more pronounced for a bigger blanket is that the only realistic way to use the blanket is across the windscreen. There are only small poorly attached loops on the edge of the blanket that you can use on a frame or some other method of setting it up so that you could chase the sun.
NT Pajero
2007 Goldstream Crown
FollowupID: 915847
Reply By: bob j4 - Sunday, Aug 29, 2021 at 00:17
So thats Outbax off the list then haha
Looks like I need to do more digging into each specific make & model I am considering then to make sure they arent like Outbax.....
AnswerID: 637704
Reply By: DaveHart - Wednesday, Sep 01, 2021 at 14:34
Anything with a heating element in it will chew a batteries power in 2 seconds, they're not designed for that kind of load. I run a 12v fridge and some LED lights off a 300w panel with a 135ah battery I bought in a kit from camping solar panels australiaThe trick is to just check up on your battery level each day and make sure its getting enough.
AnswerID: 637728
Reply By: bob j4 - Saturday, Sep 04, 2021 at 15:49
I've been looking into a lot of batteries and solar and reading reviews and this combo seems to be a good price - https://www.4wdsupacentre.com.au/adventure-kings-200w-solar-blanket-with-mppt-agm-deep-cycle-battery-115ah-1500w-pure-sine-wave-inverter-battery-box-10m-lead-for-solar-panel-extension.html
has anyone any experience with the Kings brand or these products?
4WD Supacentre has good reviews on trustpilot in general but some bad reviews for solar panels.... I'm sure I've heard people talking about Kings products in a positive manner before though
AnswerID: 637790
Follow Up By: Nomadic Navara - Sunday, Sep 05, 2021 at 00:05
You probably do not need the inverter, particularly as you are keen on getting only 12 F devices. That kit gives you the design of your needs. See if you can procure just the bits you need and you will probably save some money. If there is no savings, then just use the inverter for a door stop at home.
FollowupID: 915902
