Hickuping diesel Landcruiser
Submitted: Friday, Jul 05, 2002 at 00:00
ThreadID: 1425 Views:4703 Replies:7 FollowUps:0
My 1982 diesel Landcruiser intermittently "hickups" (the engine momentarily cuts out sometimes every few seconds)
The problem seems to be electrical as it is accompanied by a clicking under the dash.
Sometimes it will go for weeks and not occur. Other times it will not go away.
Recently when travelling from Adelaide to Streaky bay I had the problem start about 100 Km after leaving Adelaide.
It was night time and I tried everything I could think of to stop it. It was after 3 or 4 hours I found that when I turned off the lights
and drove with no lights on (there was a full moon) the problem dissapeared. As I couldn't keep driving like that I stopped untill dawn.
Over the next three to four weeks the problem occured only twice. Once during the day for about 10 Km (without lights being on)
and once at night for about an hour. (I reached my destination)
MOST FRUSTRATING.
If anyone is able to help I will be most grateful.
PS : The vehicle does have an imobiliser fitted, and I have suspected it may be the cause. However I have never been able to trigger
the problem, to identify it's cause, by any means.
All the best,
Reply By: Steve - Friday, Jul 05, 2002 at 00:00
With the sound coming from under the dash it could be a faulty immobiliser triggering the immobiliser relay, or it could be the fuel cut-off relay, which is also under the dash.
A comon cause for this is a dead or dying regulator producing low voltage or "dirty" voltage with lots of spikes. This could be the reason for turning off the headlights and the problem going away......less load on the regulator/regulator. It could also be bad connections producing spikes. Have an auto electrician give it a once over.
Hope this helps
AnswerID: 4662
Reply By: Savvas - Friday, Jul 05, 2002 at 00:00
I think you hit it on the head with lights. Getting your charging system checked out. My guess is that a diesel won't use as much electrical power as a petrol motor. Particularly an '82 vintage where engine management systems were largely non-existent. This could explain why the problem may be masked at certain times. A question that comes to mind is whether you experience this only when there are other electrical loads such as a fan or air conditioning being on during the day or lights on at night? If you drive around during the day with the air turned off, do you still experience the problem?
AnswerID: 4665
Reply By: Bruce - Friday, Jul 05, 2002 at 00:00
Peter, the problem is most likely caused by a faulty headlight rheostat. I had this problem a few years ago with the very same year vehicle. When I replaced the rheostat the problem went away. Good luck
AnswerID: 4670
Peter, Further to my last reply, that part is more commonly known as the Instrument Lights Dimmer Switch
AnswerID: 4675
Reply By: Dave - Friday, Jul 05, 2002 at 00:00
I had a similar problem in an 88 troopie.
We looked at all sorts of things, problem ended up being the cable from neg terminal to the chassis was dodgy, replaced the cable, problem disappeared.
AnswerID: 4684
Reply By: Member - Jim - Saturday, Jul 06, 2002 at 00:00
You may as well have another thing to look at and that is the oil pressure switches. There are 2 senders for this, one which diplays oil pressure in the instrument panel and another which sends its info to the fuel system. Its this one which causes the engine stop solenoid to cut off the fuel pump.
If this persists and you need to keep going you can disconnect the control arm from solenoid to pump and continue driving, of course you must have confidence that is not low oil pressure and cause engine damage.
Replace the faulty sender and the problem should disappear.
Jim
AnswerID: 4717
Reply By: Ray Hart - Saturday, Jul 20, 2002 at 00:00
Hi Peter, Had the same problem in a HJ47, Think it is to do with bad connections in the engine control system. Bugger to find ended up giving up. Since replaced the motor and problem has not re-occurred.
One quick way of getting around the problem is to remove the engine control rod. The rod between the engine control relay and the injector pump. Pull it up hard to remove it will pop off. The only thing is, you will have to stall the truck to stop the engine.
Temporary solution but it is much more relaxing driving without the engine cutting out all the time
AnswerID: 4992
