Telstra Upfront Mobile Plan and Iridium satellite phone
Submitted: Thursday, Nov 11, 2021 at 21:55
ThreadID: 142844 Views:14701 Replies:5 FollowUps:16
It appears the new Telstra Upfront Mobile Plan, that previous post paid mobile plans have been automatically moved to, does not now allow access to the Iridium satellite phone service when the GSM mobile phone SIM card is used in the satphone.
Have others experienced this?
Reply By: Member - Rowdy6032 (WA) - Friday, Nov 12, 2021 at 00:02
Thanks Mark. I was unaware of the change. Just confirmed you are correct, in my case anyway. Hopefully people don't get caught out when most needed.
AnswerID: 638556
Follow Up By: MARK R48 - Friday, Nov 12, 2021 at 18:43
I think it may all be a bit random. Some legacy plans may not have been changed, at least yet, and can still access the Iridium service.
Not all "Upfront" plans are unable to connect to the Iridium service either. I know of least one other that signed up just before my plan was changed over and they are able to access the service still.
FollowupID: 917055
Reply By: The Explorer - Friday, Nov 12, 2021 at 11:59
My last (post) bill (Nov 7) still says I'm on the "Mobile Accelerate Casual Plan $10". When did the mobiles plans get moved and how do you know it's every plan? Have not checked to see if mine still works yet - will try today.
AnswerID: 638558
Follow Up By: Member - Rowdy6032 (WA) - Friday, Nov 12, 2021 at 16:03
I'm pretty sure it has been well over 12 mths since I was told the $10 Casual Plan was no longer available. I was automatically placed onto what is now the Mobile Plan Extra Small. The costs go up all the time.
At the time it was changed over the sim still worked in the Sat phone so I just grinned and bore it. It no longer worked when I tried it last night. From comments that have been made on a previous occasion it appears that not all the $10 plans were changed, lucky you. International Roaming is still activated so that isn't the problem. I assume Telstra must have made some changes. I am interested to find out if it still works on your $10 plan.
FollowupID: 917053
Follow Up By: Zippo - Friday, Nov 12, 2021 at 16:37
Just checked mine, and it still works.
FollowupID: 917054
Follow Up By: Member - Boobook - Sunday, Nov 14, 2021 at 07:04
Mine stopped working. I could make calls but no longer receive them for some strange reason. Same for text. I have had a $10 plan for 10 years. No problem till this year.
Try both way comms when you test to see if it still works.
FollowupID: 917078
Follow Up By: Zippo - Sunday, Nov 14, 2021 at 12:29
Tony, I just tried calling my 9555 from my mobile. RVA "there will be a short delay" (which is normal in my experience) then it rang about 15 secs later. Didn't bother answering.
Whether this current apparent reduction in access in association with their UpFront plans has anything to do with the Telstra Everywhere proposal I don't know.
FollowupID: 917090
Follow Up By: The Explorer - Sunday, Nov 14, 2021 at 15:12
Hello again
Just checked mine (Iridium 9555 with Telstra Sim on Mobile Accelerate Casual Plan $10) - phoned my "normal" mobile (Optus) and also sent text. Registered fine and worked as normal. Happy Days
FollowupID: 917098
Follow Up By: The Explorer - Sunday, Nov 14, 2021 at 16:05
PS - Keep in mind that (at least some) sat phones can be used to dial 000 (Edit - or 112) without a SIM - so that maybe a suitable emergency option in some circumstances.
FollowupID: 917103
Follow Up By: MARK R48 - Monday, Nov 15, 2021 at 18:56
Without an active sim card it seems you have to use the alternate emergency number 112. See extract from and link to the Telstra Customer Terms for the satellite service below.
Our Customer Terms
Telstra Mobile Satellite Service
TELSTRA CORPORATION LIMITED (ABN 33 051 775 556) | The Telstra Mobile Satellite Service Terms were
last updated on 10 April 2019
PAGE 7 OF 24
2.11 To access emergency services from within Australia, you can call 000 if you have an
active sim card in your handset/device. If you do not have an active SIM card in your
handset/device you can access emergency services from within inside Australia by calling
112.
https://www.telstra.com.au/content/dam/tcom/personal/mobile-phones/pdf/mobilesat.pdf
FollowupID: 917134
Follow Up By: Allan B (Sunshine Coast) - Monday, Nov 15, 2021 at 19:13
I'm confused. Why would you carry a satphone WITHOUT an "active SIM card"?
FollowupID: 917136
Follow Up By: The Explorer - Monday, Nov 15, 2021 at 19:23
Probably a few scenarios (e.g. found one in the cupboard but already have PLB or Spot etc so take it as a backup and couldn't be bothered getting a SIM that works). Either way if you did (and you knew it would work) it provides an option to contact emergency services, that's all - wouldn't get too "confused" about it.
FollowupID: 917138
Follow Up By: Allan B (Sunshine Coast) - Monday, Nov 15, 2021 at 19:29
That's pathetic Greg.
FollowupID: 917139
Follow Up By: The Explorer - Monday, Nov 15, 2021 at 19:36
? That's Bizarre - you are making me laugh...anyway
No one said relying on a Sat phone with no SIM card was a great idea (assume this is your issue?) - it was just pointed out that it is possible to contact emergency services without a working sim - again - possible handy in some situations, another example - lost/broken/expired sim card?
FollowupID: 917140
Follow Up By: Member - Rowdy6032 (WA) - Monday, Nov 15, 2021 at 21:54
The main reason I carry a Sat phone as well as PLB is for emergencies, not for chit chat. If it works in an emergency on 112 that's good enough for me.
FollowupID: 917144
Follow Up By: Zippo - Monday, Nov 15, 2021 at 22:23
Allan, the only half-sane reason I could offer for anyone carrying a SIMless satphone is ...
"well, the SIM I use in it is the one from my cellphone, and that's where it currently is."
(NOT me - a dedicated SIM lives in my satphone.)
FollowupID: 917145
Follow Up By: Allan B (Sunshine Coast) - Monday, Nov 15, 2021 at 23:01
Ah yes, of course Zippo. Why didn't I think of that?
But not me either. I would be sure to drop the SIM into the sand whilst transferring it and then have two very limited phones!
FollowupID: 917146
Reply By: Peter S99 - Saturday, Nov 13, 2021 at 00:26
May it is due to the new update of Telstra as compare to iridium. The GSM mobile phone now are coming with new updates . In the paste the Telstra used to come with the cordless telephone a lot of changed in a few years.
AnswerID: 638563
Reply By: Geoff (Newcastle, NSW) - Monday, Nov 15, 2021 at 17:00
Thanks for the information,
It used to be sufficient to enable International Roaming on a Telstra post paid SIM to work in the Iridium phones.
Are you saying in the new plans even this isn't enough?
Geoff,
AnswerID: 638605
Follow Up By: Member - Jim - Monday, Nov 15, 2021 at 17:19
Geoff,
I seem to recall that Telstra require you to activate your SIM for overseas use on Post Paid plans now.
This was from a recent Upgrade? to Post Paid plans. The upgrade included a fee rise as well.
I did not bother to read too much of the bumf as I have a separate satellite plan, and figured I would read more of the plan on the off chance that I might go overseas and need to use the additional services.
If one completely read and understood all the T & C's coming in lately it would be a full time job.
Jim
FollowupID: 917129
Reply By: Zippo - Monday, Nov 22, 2021 at 16:34
Noticed this on the Whirlpool forum. So at least that person found a way around the problem.
AnswerID: 638680
