Recovery points on a 94 Hilux
Submitted: Saturday, Jul 03, 2004 at 18:09
ThreadID: 14346 Views:2936 Replies:1 FollowUps:1
Hi everyone, Looking for suitable places for recovery points on my 94 2.8 D Hilux Dual Cab. Had an old patrol with hooks already set. Have Reece Ball at back and TJM steel bar at front. Sorry if this seems lame but getting back into it after a 10 year layoff. Thanks.
Reply By: Utemad - Saturday, Jul 03, 2004 at 21:31
You can use the square tube towbar as a recovery point on the rear. Just remove the towbar and put the snatch strap in the tube then insert the pin. On the front there should be recovery hooks on the TJM bar. If not you should be able to locate two holes close together on the lower section of the bar which you can bolt a tow hook too (I have an ARB bar which has this but assuming TJM is the same).
Utemad
AnswerID: 66333
Follow Up By: gleno - Sunday, Jul 04, 2004 at 07:04
Thanks I'll check the bar. Cheers
FollowupID: 327153
