Air compressors
Submitted: Tuesday, Jul 06, 2004 at 17:05
Jayboy
I have my hilux booked in at ARB to have an air compressor fitted in the engine bay and am thinking about having it hooked up to a
tank I have behind the bullbar.Some people have told me that I should just have it going to an outlet at the bullbar.Can someone with a bit more knowlege advise me on the best way to go.
Reply By: Member - Roachie SA- Tuesday, Jul 06, 2004 at 17:21
G'day mate,
Having a
tank is a good idea for a few reasons. (Note that I don't call the 500ml jobbie on the ARB a real "tank")......
Firstly, it'll give you a reserve to use if you want or need to blast dust out of a air filter or brake drums etc.
Secondly, you'll also find it better for re-seating the bead of a tyre after you've repaired same.
Thirdly, if you ever want to mount a decent set of air horns, you'll have a great air supply to run them (none of those dicky little Fiamm type efforts).
Lastly, if you fit air locker/s you've got the air there already (although the ARB
tank is okay for that purpose anyway).
I would think twice about having it fitted under the bonnet due to dust and moisture concerns. I have a mate with a 3 litre Patrol and we mounted his against the firewall (it's an automatic). He didn't use it all that often and it seized up on him. He's now moved it to the back of the cargo bay. If you can fit under a
seat or somewhere, I reckon you'll be better off.
Good luck
66691
Follow Up By: Peter McGuckian - Tuesday, Jul 06, 2004 at 21:37
Roachie
I have
mine fitted under the bonnet, drivers side corner. Its a very neat fit and ARB had to move some stuff. It stays clear of mud etc and is very easy to connect to.
327480
Follow Up By: Jayboy - Wednesday, Jul 07, 2004 at 01:16
Thanx Roachie some of the ideas you mentioned are what i was thinking of.Do you think it would run a rattle gun for changing
wheels?
Cheers Jayboy
327514
Follow Up By: Member - Roachie SA- Wednesday, Jul 07, 2004 at 09:21
Mate, I haven't tried it, but I wouldn't expect my small
tank to run a rattle gun. I'm keeping my eye open for a 9 litre fire extinguisher and would like to substitute for my existing one.
327535
Reply By: Truckster (Vic) - Tuesday, Jul 06, 2004 at 17:45
What do you want from the
Tank.??
What do you want it to do, inflate tires, lockers or what...??
ARB compressors arent the best for running air tanks depending on volume, they WILL do it, but will wear out faster than other items...
66695
Follow Up By: Jayboy - Wednesday, Jul 07, 2004 at 01:17
What do you suggest as a better comp. for the job
Jayboy
327515
Follow Up By: Truckster (Vic) - Wednesday, Jul 07, 2004 at 10:34
Depends on what you want it for, and your budget.
If money is no object, Clisby's are T H E kit to have, they wont die ever either, but you do pay a bit more for them..
Max Air, Blue Tounges, etc are all about as good as each other, the other top idea is Endless Air. But they dont fit every car.
327548
Reply By: Sparkie - Tuesday, Jul 06, 2004 at 19:52
I also think warrenty gets affected by having
tank. I bought the ARB compressor today and the owner of our local 4wd store said it voids the warrenty because of the back pressure???????????????
Sparkie(IE not Y) ;-)
66714
Follow Up By: Member - Roachie SA- Tuesday, Jul 06, 2004 at 20:08
Sparkie,
Back pressure issue can be overcome by putting in a one way valve which is what I've done on my max-air set-up. Compressor pumps up thru the valve and pressure is stopped from returning back to the pump. Works really
327463
Follow Up By: Topcat (WA) - Tuesday, Jul 06, 2004 at 20:24
You would be advised to have a relief valve in the system or a max. pressure shut off solenoid switch otherwise you will have backpressure problems which could overload the compressor. Cheers.
327465
Follow Up By: Member - Roachie SA- Wednesday, Jul 07, 2004 at 09:23
G'day Topcat.....Should have mentioned that I have my set-up run through a ARB pressure switch, also have a pressure relief valve and also have a pressure gauge mounted on my "A" pillar....so I think I've got all the bases covered.
327536
Reply By: Allan-TPWA - Tuesday, Jul 06, 2004 at 22:11
I have a
tank and a blue toungue (rated at 100psi) set up with a check valve and a 80- 100psi pressure switch. When I am 5 min from leaving
the beach I switch the compressor on so I have a
tank full of air to use which I find is good for the first 2 tyres at
servo speed then the other 2 at blue tongue speed. This raises another question though. The last 2 tyres are being inflated at the same time the air
tank is being reinflated, this is taking longer than just inflating a tyre (I don't think it is that crititcal). The compressed air is good for cleaning dust out of parts though.
66754
Follow Up By: Jayboy - Wednesday, Jul 07, 2004 at 01:22
I guess it depends on what size the
tank is as to how many tyres it will do.How long does it take to pump your last 2 tyres?
Cheers Jayboy
327516
Follow Up By: Member - Roachie SA- Wednesday, Jul 07, 2004 at 09:28
Allan,
It depends on what size
tank you have.
Mine is only 3 litres so it doesn't make much difference to the whole tyre inflation process. By that, I mean it doesn't help much at the beginning as the compressor cuts in almost immediately when I start inflation even if the
tank had 100psi to start with;;;;also, the compressor doesn't have to work much harder once the pressures have equalised. However, if you have a 20 litre
tank then you are quite right, the compressor is trying to inflate the tyre as
well as fill up the
tank. Some blokes avoid this by having a simple shut-off tap on the
tank, so that the compressor is not trying to fill it too.
327538
Reply By: GaryW - Wednesday, Jul 07, 2004 at 03:56
I have a 5ltr
tank under the LC100 which is enough to take a tyre from 25 to 35 psi - just. Not much use really. So I also have a 20 Ltr
tank the plugs into the air line either inside the back (I'll be making a place for it when I build in the drawers) or on the trailer via a coupling on the towbar. I didn't go for a connector on the bull bar because it would require a longer hose to get to the trailer tyres - the towbar made more sense for me. The 20Ltr
tank has a handle on it and a tap that allows me to disconnect it and take air to the location required.
I'm very happy with this set up.
Gaz
66777
Follow Up By: old_55 - Wednesday, Jul 07, 2004 at 11:00
Hey dude,
You still O/S??
How's it going?
Catch ya when ya get back.
327550
Follow Up By: GaryW - Friday, Jul 09, 2004 at 04:54
Yep - Home Sunday AM (Early) might see ya might not depends on how much sleep I get.
G
327819
Reply By: Member - Howard- Wednesday, Jul 07, 2004 at 13:23
hi all,
for those considering putting in a small
tank hooked up to their compressor I thought I would share what I am in the process of fitting to the 80 series.
Big W have a 240 volt air compressor for $68. it has a 6 litre
tank( pressure rated). and it was also very easy to modify the pressure switch from 240v to 12v.
I have used a Repco 150 psi HD compressor($99) for the last couple of years and am happy with its performance.
All has been bench tested and works fine,
tank pressurises to just over 100psi and compessor cuts out.
tank will fit behind front bull bar on left hand side with outlet under wheel
well,
Compressor goes under bonnet on left hand wheel arch behind fuel canister and pressure switch goes in behind it in the back lh corner.
only got compressor in last sunday,
tank will go in next just need a couple of brackets .
best thing is all up $99 for compressor, $68 for rated
tank with bleeder /relief valve/quick connect outlet and pressure switch&Gauge, 5metres of air hose and a couple of extra quick fit fittings $30 at bunnings under $200 all up.
another bonus if you dont have acompressor in the garage,as this particular compressor is belt driven not direct drive the 240v motor and compessor can be mounted in the workshop for a straight air supply.makes it even cheaper
Howard
66797
Follow Up By: PeterDarwin - Tuesday, Jul 13, 2004 at 09:58
Sounds great I often wondered if this would be possible
how did you convert the pressure switch?
328251
