Transitioning from MudMaps to Exploroz
Submitted: Tuesday, Aug 09, 2022 at 13:14
ThreadID: 144384 Views:4599 Replies:1 FollowUps:0
Hello There,
Finally discovered Exploroz, right here in our home town!
Keen to find a way to export way points from MudMaps 2 and import to Exploroz.
We’ve been languishing with unsatisfactory MM on our old mini ipad 2 as didn’t want to upgrade. Now that we have found Exploroz we are upgrading our ipad. Awaiting its arrival as we speak.
However, mapping afficianodo spouse has a couple of thousand way points that were lovingly entered into MM which we do not want to lose. MM are no use unless you are buying.
Hopefully someone has found a way to do this. Would be extremely grateful.
Looking fwd to seeing you on the track.
Safe travelling,
Gary
Reply By: Frank P (NSW) - Tuesday, Aug 09, 2022 at 14:24
Does MM allow you to export your personal waypoints/POIs in GPX format? If so you can do that then import the GPX file into Traveller.
BTW the app is called Traveller. It's made by the folk who run ExplorOz :-)
AnswerID: 641397
