Troopy rotor
Submitted: Sunday, Sep 18, 2022 at 10:20
ThreadID: 144836 Views:5787 Replies:3 FollowUps:4
Hello
I needed to change two rear wheel studs on my 78-series and chose to have a go at it myself. With the handbrake off and in neutral, I still needed to use two M8 bolts to remove the rotor. My new wheel studs are set properly and I've wound the pads right in to supposedly make it easier to put the rotor back on, but for the life of me I can't get it in properly. I'm just wondering if anyone has a suggestion? It took a bit of effort to get it off with those M8 bolts. Something seems amiss?
Thanks.
Paul
Reply By: Bob Y. - Qld - Sunday, Sep 18, 2022 at 14:15
If you have backed off the adjustment on the handbrake shoes(pads are the ones in the brake calliper :-)) the rotor should slide on easily. Just check there is no rust or dirt build up on the hub as the rotor/hub tolerance is quite small? If there is a noticeable outer lip on the inside of the handbrake drum, you could remove this with a die grinder, or even a small angle grinder, utilising a flap disc.
Just remember which way you turned the star wheel as you backed off the shoes, you’ll need to readjust the shoes once rotor is on.
If you haven’t already, it’s worth getting a workshop manual, to get all the clues for a job like this. Or there’s sure to be a YouTube video on the procedure.
AnswerID: 641669
Reply By: Paul S53 - Sunday, Sep 18, 2022 at 21:17
Thanks, Bob. I realised after I posted that I should have used the term 'shoes'. Strange way to describe those things, all the same. I did get the rotor back on. My handbrake needs adjusting, so I'll have a go tomorrow putting the screwdriver in the hole. Thanks again for the advice.
AnswerID: 641675
Follow Up By: Allan B (Sunshine Coast) - Sunday, Sep 18, 2022 at 21:52
Shoes?
When the younger Paul was decelerating his soapbox, what was on his foot when he planted it on the ground?
Brake shoes maybe?
FollowupID: 920973
Reply By: Member - pete g1 - Wednesday, Sep 21, 2022 at 22:13
Hi Paul,
May I suggest you pack 4 (or more) spare wheels studs deep in the 78's tool kit...?
It will lessen the pain if your caught with a "way out bush" roadside repair & no spares....nothing worse than scavenging studs off other hubs & all the inherent effort to achieve same.
I had an 80 series & early in our life together I heard fractured/failed wheel studs were apparently a "known" issue, hence I replaced ALL studs.....much easier on the comfort of your concrete garage floor than scratching about on a hot day in the dirt.
Hate those rattle guns & over tensioned wheel nuts etc.
safe travels & may the wheel stud gods be with you !!
Pete
dig about in this dedicated 'cruiser site
http://lcool.org/
AnswerID: 641700
Follow Up By: Paul S53 - Thursday, Sep 22, 2022 at 04:00
Good advice, Pete. Thanks. Given how cheap studs are, I think I will change them all this summer and get a few extras. I agree with you in regard to rattle guns. The wheel nuts were way too tight after the last trip to the tyre shop.
Paul
FollowupID: 921006
Follow Up By: Bob Y. - Qld - Thursday, Sep 22, 2022 at 08:13
Those reading this thread might be interested to read one of Mick O’s blogs from 1st January, 2011. It relates to Landcruiser wheel stud issues he had over a number of remote trips. Mick was a prolific contributor to EO’s blog pages back then, and he has written many good yarns, around 386 blogs in total!
Sadly, the engineering business he used, Galpro Engineering in Cavan SA, has closed. Perhaps someone can come with another shop that can produce a similar quality item, at a reasonable cost.
Failing that, just carry a quantity of spares, both studs & nuts, to help keep the wheels turning.
FollowupID: 921007
Follow Up By: Paul S53 - Thursday, Sep 22, 2022 at 09:59
Hi again, Bob.
One of the first articles I read regarding wheel studs was the one by 'MickO' where he describes getting Barry from Galpro to engineer better fiitting studs from 'Swedish Steel'. I found it interesting and useful.
I might ask an engineering uncle about it. He's got the equipment and skills to produce them, I reckon.
Paul
FollowupID: 921009
