Track Logs
Submitted: Wednesday, Nov 30, 2022 at 15:28
ThreadID: 145091 Views:5954 Replies:4 FollowUps:12
I recently become a member and am finding the track logs difficult to use. I tried to put in a day of 4wd a specific day to see my track log. It asked for selected position what does that mean. I must admit i do find it difficult to easily navigate this App. My main objective is to track my days driving in the bush and to keep a recorded log of the tracks i went on for future reference is this possible.
Any advice or suggestions on how to use this App would be appreciated at the moment i dont use it because it is complicated.
Reply By: ExplorOz - David & Michelle - Wednesday, Nov 30, 2022 at 19:55
Willy,
What you need to do is use the LHS menu and select Export to Track Log. When this page comes up put in the Start Date and End Date for the tracking you wish to export. Once you enter to two dates the system will draw a map of the data that is present in the file. Once the map shows the data you are after enter a Name and press Create Track Log.
You can optionally elect to include positions within Geofence and/or trim/crop the file to some exact times if needed.
David
AnswerID: 642212
Reply By: Member - Willy121071 - Thursday, Dec 01, 2022 at 07:13
I tried this and this error shows up.
AnswerID: 642215
Follow Up By: ExplorOz Team - Michelle - Thursday, Dec 01, 2022 at 12:09
The date you have selected has no data recorded so impossible to create a Track Log for that day.
Michelle Martin
Marketing & Customer Support
FollowupID: 921702
Follow Up By: Member - Willy121071 - Monday, Dec 05, 2022 at 15:23
Is there any instructions on how to set up the Apps so that Track logs can be created.
FollowupID: 921721
Follow Up By: Member - Dick L - Monday, Dec 05, 2022 at 16:09
The User Manual - Tracking pages 23-24
- Track Logs pages 24-28
The User Manual can be found via Hamburger Menu top right hand corner of main map -
References- Manuals and about.
FollowupID: 921722
Follow Up By: ExplorOz - David & Michelle - Monday, Dec 05, 2022 at 16:12
Yes all the instructions are given but its very straight forward. Current User Manual dated Feb 2022 has Track Logs page 24-28. The current User Manual is always in the app and also on the Traveller webpage - https://www.exploroz.com/traveller .
Do you understand that the Traveller app records position data automatically every time it is running? You can't see the data - it's huge obviously (buts there's literally thousands of positions recorded to capture a short trip). The whole idea of creating Track Logs is to convert this collection of lat/long positions and connect them together chronologically and show them on a map. This is done by our server so when you Export Positions the app will convert the data and create the Track Log. It can do this when offline in the app but when online it will sync the saved Track Log to your online account/saved on our server for backup/other uses.
So, simply open the menu in the Traveller app - select Export Positions and select a date you know you had the app running when you were moving. Press Create Track Log. Everyone has access to do this.
If no positions for that date, nothing has been recorded because the app wasn't running OR you've since uninstalled the app from that device hence deleting it. There is no other way to create a Track Log if the data isn't there.
Members do have a secondary option for creating Track Logs however. It's available only if they have previously enabled the Tracker service on a device which has initiated a continuous feed/sync of the positions data from your device/s to your account on our server. Server Tracking. So, Members could take a look at their Server Tracking and press SAVE to make a Track Log.
NOTE: the app will "auto save" a Track Log from Server Tracking anytime you LEAVE a Geofence.
FollowupID: 921723
Follow Up By: Member - Dick L - Monday, Dec 05, 2022 at 16:18
Should read - Menu top LEFTHAND corner.
FollowupID: 921724
Follow Up By: Member - Willy121071 - Tuesday, Dec 06, 2022 at 07:44
Do you have to have the App open for it to be recording logs in order to create track logs at a later date.
FollowupID: 921730
Follow Up By: ExplorOz Team - Michelle - Tuesday, Dec 06, 2022 at 10:29
Yes, the app can't record if it's not running.
Michelle Martin
FollowupID: 921731
Reply By: Member - Willy121071 - Thursday, Dec 01, 2022 at 18:03
How do i fix that. I have turned on the tracker so don't understand why.
AnswerID: 642216
Follow Up By: TrevorDavid - Thursday, Dec 01, 2022 at 19:43
Willy, you don’t need the tracker turned on for this.
Did you actually travel anywhere on the 26th?
Are you you using the device that you travelled with when you try to create this way.
TrevorDavid
dontyajustluvit
FollowupID: 921703
Follow Up By: Member - Willy121071 - Saturday, Dec 03, 2022 at 12:02
Hi Trevor
Yes i went 4wd from 25-27th. I just find it impossible to navigate this App. It is the most confusing set up i have ever seen and the manual and Youtube videos are not helpful. I have tried following them but nothing i try works. I will not be renewing my subscription it has been a total waste of alot of money.
FollowupID: 921706
Follow Up By: TrevorDavid - Saturday, Dec 03, 2022 at 13:55
Willy,
Slow down & take a breath. A deep breath by the sounds of things.
Have you tried Export Position from the left hand menu? , just make sure it is on the same device that you used on your trip.
TrevorDavid
dontyajustluvit
FollowupID: 921707
Follow Up By: Member - Willy121071 - Sunday, Dec 04, 2022 at 16:25
Yes tried that. I have resigned to the fact that this App is not for me. The complicated set up is to difficult to use. Its a shame because i was looking forward to being able to keep a record of my 4wd trips. I will try and find another tracking App that is easier to use.
FollowupID: 921715
Follow Up By: TrevorDavid - Sunday, Dec 04, 2022 at 18:04
That’s a Shame Willy, but each to their own.
I see you have three saved track logs, so you aren’t doing to much wrong.
Happy to help out offline should you wish, just MM me
TrevorDavid
dontyajustluvit
FollowupID: 921716
Reply By: Member - Jason J4 - Thursday, Dec 01, 2022 at 19:06
This is interesting, I found it easy to create a track log from the snail trail from days of driving but since my membership expired last month and I renewed it everything seems impossible.
I can't for the life of me get "create track" to appear from the 2 ways the manual says too, and how I used to do it.
Incredibly frustrated after just doing a 4 day trek with no record of it..
AnswerID: 642217
