Tibooburra to Bourke via The Cut Line
Submitted: Friday, Apr 14, 2023 at 19:38
ThreadID: 145533 Views:8601 Replies:7 FollowUps:6
Hi folks,
Long time stalker, first time poster :)
We're doing a NSW 'outback' trip later in the year, and want to head up from Broken Hill to Tibooburra, then out to Cameron Corner (and maybe even Innamincka). But we want to head to Bourke from Tibooburra. There'll be 3 four wheel drives going, but one 2 wheel drive (a smaller vehicle too). Does anyone know if the road has been sealed yet for the last few hundred ks? If not, is it advisable to give it a miss?
Many thanks!
Stuart.
Reply By: Peter_n_Margaret - Friday, Apr 14, 2023 at 20:20
I reckon the road (MR405, via Wanaaring) is gravel except for about 30km of black top at the eastern end, but I may be out of date.
I also reckon it would be pretty good gravel and probably quite OK for 2WD.
AnswerID: 643316
Follow Up By: StooJ - Friday, Apr 14, 2023 at 20:36
Thanks, Peter. I'm not at all familiar with this area, and I'm using a combination of Tripline and Google Maps, but the MR405 seems to be the same road as The Cut Line - isn't it? Or were you just referring to it by it's other name?
If it's gravel, then that might be OK for us. We can take it easy as we're in no rush.
Thanks again!
FollowupID: 922964
Follow Up By: Peter_n_Margaret - Friday, Apr 14, 2023 at 20:56
"The Cut Line" is not a name I see anywhere, so I am assuming we are talking about the same road. There are not many to choose from that connect those 2 places and it is VERY straight, so I can imagine it originated as a "cut line".
I am not sure if I have driven it, or not, but "probably" :)
My "recons" are based on the roads I can recall in the area and its depiction by HEMA which suggests that it would be an "OK" road.
ps.... Just found the description "The Cut Line" on the western end (west of Wanaaring) on HEMA's 1:150,000. :)
FollowupID: 922965
Follow Up By: Peter J4 - Saturday, Apr 15, 2023 at 07:16
We travelled that route a few years ago and it was very rough, down to virtually wandering through rocks in afew places but did improve as it approached the western end due to the extended drought conditions .
The rain over the last year or so would have changed it but as to whether its been reformed or repaired would require local knowledge or a recent experience.
It might not even be trafficable due to flooding due to ongoing wet weather.
FollowupID: 922967
Follow Up By: Member - Cuppa - Saturday, Apr 15, 2023 at 10:50
We too travelled it a while back, in September 2017. I don't recall it as being especially rough at the the time, but it is certainly a road where conditions probably change quite regularly. It was stinking hot, & apart from a full on dust storm we had to sit & wait out for a while the main obstacles were the many animal carcases on the road. A 2wd vehicle in the company of 4wd's would make it if conditions were as we experienced, but I would advise LT tyres as a precaution against punctures from bones.
This link to our blog reminds me that the last 50 to 60kms into Bourke were sealed.
Blog - Tibooburra to Bourke
FollowupID: 922970
Follow Up By: StooJ - Saturday, Apr 15, 2023 at 19:25
Thanks! I'll check out your blog for sure!
FollowupID: 922975
Reply By: Bazooka - Saturday, Apr 15, 2023 at 12:12
Not current, but should give you some idea of what to expect Stu.
https://topwiretraveller.com/the-cut-line-bourke-wanaaring-tibooburra/
Youtube has some footage also.
Live traffic shows no current hazards on that road but one adjacent
https://www.livetraffic.com/
AnswerID: 643317
Reply By: ExplorOz Team - Michelle - Saturday, Apr 15, 2023 at 12:31
Yes the last section is sealed...take a look at this on the new EOTopo 2023 map. You can see the Cut Line is a major unsealed road but then becomes sealed east of Argyle.
Free EOTopo online webviewet
Michelle Martin
Marketing & Customer Support
AnswerID: 643319
Reply By: IvanTheTerrible - Saturday, Apr 15, 2023 at 15:04
Most of that road wont be an issue to a 2 wheel drive but there are some section that are very lose sandy gravel. It will depend on if any road maintenance has been done.
AnswerID: 643320
Follow Up By: OzzieCruiser - Saturday, Apr 15, 2023 at 15:12
Yes and the section between Tibooburra and Wanaaring is gibber country and the stones and rock on the road can be quite sharp and will wear and cut treads of 2wd tyres but should still be OK.
FollowupID: 922974
Reply By: StooJ - Saturday, Apr 15, 2023 at 19:28
Thanks for all the great comments. It's very helpful indeed!
We've decided to leave the 2WD at home and have another friend with a 4WD who is going to tag along and we can split the occupants of the 2WD between our car and the other 4WD. I think that's much safer (and probably will mean we won't have a damaged car!).
Thanks again!
AnswerID: 643321
Reply By: braincell - Tuesday, Apr 18, 2023 at 17:03
did 40 years ago in a ford escort panelvan , so you should be ok .
AnswerID: 643346
Reply By: Member - Lout - Tuesday, Apr 25, 2023 at 16:22
Did it last month (march) …roads sealed from Bourke to about 40k from Wanaaring.
Wanaaring to Tibooburra is all dirt quite soft sand with corrugations but they re in the process of grading it.
Doable in any car really, I was in a Jeep!!
AnswerID: 643414
