Charging Lithium Direct from Alternator 78 series FTE (Part 3)
Submitted: Saturday, Jul 15, 2023 at 17:44
ThreadID: 145994 Views:5353 Replies:5 FollowUps:39
Hi All
As the regulars on here would know, I am attempting to charge a lithium bank in my 4 x 4 direct from the alternator.
Many on here have said don't do it. Others are doing it and are saying it's fine.
Other also say that all Landcruisers since 1990 have temperature compensating alternators.
My local dealer says if the alternator has 3 pins it is non compensating, 4 pins it is. I have the original alternator still installed.
I have called two dealers around Australia that had stock of my alternator and asked if they could do a visual on it.
Both said it had 3 pins.
My question for today is what would be a permissible operating temperature for an alternator when under load. Has anyone here used a thermal camera and tested this?
Lyndon
PS, I've have just taken some thermal photos. So as not to slew opinion, I'll post them in a bit :-)
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Member - LeighW - Saturday, Jul 15, 2023 at 19:49
Lydon,
Rather than asking questions and getting mixed answers why not just check it on the vehicle. Start the car when the engine bay is cold and measure the voltage reading across the battery terminals with the engine at 1500RPM. Then take the car for a 30 minute drive and check the voltage again. First reading should be around 14.2V second reading will be around 13.8V with a temperature compensated alternator.
Toyota temperature compensated alternators on earlier models only have three wires, one for the charge light, one for the voltage sensing circuit and one for ignition switched power to power the alternator.
If they are talking 4 wire there is an extra wire that goes to the engine management CPU on later models.
It is no surprise they don't understand it as even the toyota service manuals don't mention temperature compensation as it is done by the voltage regulator and or engine ECU and can't be altered.
AnswerID: 644116
Follow Up By: Member - lyndon NT - Saturday, Jul 15, 2023 at 20:01
Hi Leigh
The alternator measured 14.11v on cold start up. Half hour at idle in our not so cold Darwin climate saw it at 13.95v.
So half the voltage drop you were expecting? Or do you think it would drop more if vehicle driven?
Has anyone put a thermal camera over their alternator under load?
Lots of different temperature figures getting quoted on the internet.
Lyndon
FollowupID: 924069
Follow Up By: Member - LeighW - Saturday, Jul 15, 2023 at 20:09
That would tend to indicate it is a temperature compensated unit, you really need to drive the car and get the engine bay hot and test at 1500RPM. I woul also turn the headlights on high beams to make sure you have a reasonable load on the alternator.
Temperature voltage modulation on older models won't be as great as on more recent models.
I'm also assuming you don't have an aux connected?
FollowupID: 924070
Reply By: RMD - Saturday, Jul 15, 2023 at 20:28
Lyndon
Surely you can unplug the alt things wires and visually see if it has 3 or 4 wires. Problem solved. If a three wire system the alt can be made to increase charge voltage by adding a switched, inline diode to bring voltage up again despite the temp shutting it down slightly. That diode can be controlled via a switch on the dash to again drop the voltage after the battery has been fully topped up. Probably best to have a volt digital meter easily seen to monitor it though.
Simply running at idle will not bring any engine bay to running temp ever.
With a 70+ series Toyota, isn't the battery at the very very hot rear of the engine bay? unlike some advisors having batteries at the front of engine bay and advising on that situation. 70 series are known to cook batteries, so the rules change if at the rear of bay. Far hotter there and battery suitability is of concern.
PS, 1. Just pointing a temp unit at the alternator will not reveal how hot the parts, which are likely to fail, are really running at, only embedded sensor will achieve that!
PS. 2. Did you ever get the pins out of your leaf pack fronts?
AnswerID: 644118
Follow Up By: Member - lyndon NT - Saturday, Jul 15, 2023 at 20:55
Yes, the leaf pack, OMG, what a headache. The like of which I have seldom encountered!
The pin only comes out 1 way, despite the guy at ARB just telling me to hit it harder.
The pin was the easy bit, airbags had to be completely pulled out. There is a preload on the springs. So for me, there is 600 kg of force on the springs whilst still in the hangars.
The rear sway bar that supports the diff had to be disconnected. ETC ETC ETC
Basically, the diff has to be floating in the air on both sides to do the job.
Then it has to go back in a certain order, as I found out, then pulled it apart again!
It's done, but I'm not keen on doing it again. Even though I do pretty much everything else myself.
Like everyone else, ARB have no staff, I inquired in June and was told the earliest they could do it was September. The vehicle literally could not be driven. So I did it.
Back to the Lithium batteries.
The only battery under the bonnet is the led acid starting battery.
The car does not have a "smart" alternator, so I don't have an under voltage issue.
No need to unplug it, I can see the model number and two dealers have looked at the exact alternator in their warehouse and told me it is 3 pin.
PS, re the leaf pack, the 78's are coil and leaf, so it was the rear.
Lyndon
FollowupID: 924071
Follow Up By: Member - lyndon NT - Saturday, Jul 15, 2023 at 20:57
Yes, true, I cannot fully see into the alternator, but i can see the windings, not sure if that accounts for much.
FollowupID: 924072
Follow Up By: Bob Y. - Qld - Sunday, Jul 16, 2023 at 08:21
Ross,
The later model 70’s have the start battery immediately behind the near side headlight. Don’t know when it was moved there, but my 2015 ute has it there. It also means, for most mortals, that the battery has to be removed just to change a headlight globe.
FollowupID: 924073
Follow Up By: Allan B (Sunshine Coast) - Sunday, Jul 16, 2023 at 12:27
No worries Bob. I think that I have changed more batteries than headlight globes anyway. lol
FollowupID: 924076
Reply By: Batt's - Sunday, Jul 16, 2023 at 08:57
When I was researching lithium ion batteries a couple of yrs ago I read that fast charging at the max imput all the time will reduce its life. Slower charging up to around 50% is better and will give the battery a longer serviceable life I wonder if that's correct.
AnswerID: 644120
Follow Up By: Member - LeighW - Sunday, Jul 16, 2023 at 11:58
What are some electrical vehicles now, about 20 minutes for a fast charge?
FollowupID: 924075
Follow Up By: Member - lyndon NT - Sunday, Jul 16, 2023 at 13:57
Yes, they have max and recommended charge rates.
In my case, 1 battery max charge 100A recommended 50A
2 batteries in parallel, recommended 75A
3 batteries 113A
FollowupID: 924077
Follow Up By: Allan B (Sunshine Coast) - Sunday, Jul 16, 2023 at 15:22
In all my experience, I have yet to see an electrical appliance whose life was shortened by being less stressed.
FollowupID: 924082
Follow Up By: Batt's - Monday, Jul 17, 2023 at 09:03
I have been using rechargeable NIHM AAA ,AA batteries in everything for over 15yrs. I started with a 1 hour fast charger the batteries last approx 2 to 3 yrs on average then we bought a slow 8 hour charger they definitely last longer now 5 plus yrs.
FollowupID: 924098
Follow Up By: Batt's - Monday, Jul 17, 2023 at 15:12
Kia say on their site fast charging reduces life by about 10% because it strains the battery go figure. There's a lot of info on the net from reputable companies Lyndon about the effects of fast charging electric vehicles.
FollowupID: 924105
Follow Up By: Member - lyndon NT - Monday, Jul 17, 2023 at 18:01
Yep, and that's why I'll be charging them within the recommended charge rate.
FollowupID: 924108
Follow Up By: Batt's - Monday, Jul 17, 2023 at 19:36
That will be the max rate won't it because you're going straight off the alternator with nothing to reduce the power just an isolator in between.
FollowupID: 924110
Reply By: Member - lyndon NT - Sunday, Jul 16, 2023 at 14:10
OK folks
Part 1 of what I've found so far
at idle with 3 old fully charged AGM alternator temp around mid 70c. Bonnet up, engine warm.
2 x 100 A/hr lithium in parallel @ idle 60A alternator temp 125c
@ 2000 RPM 90A alternator temp 143.5c
Both these temperatures occurred very rapidly, the last so quickly I didn't stop to photograph the amp meter but shut the car down.
So how hot should it run...............................................
AnswerID: 644125
Follow Up By: Member - lyndon NT - Sunday, Jul 16, 2023 at 15:27
2 x lithium in parallel
FollowupID: 924083
Follow Up By: Member - lyndon NT - Sunday, Jul 16, 2023 at 15:41
Alternator seemed to settle down to around 105C with an output of around 60A @ 2000 RPM.
2 x AGM 110 A/hr @ 12.1v vehicle 2000 RPM
Note.
No noticeable difference was detected in Alternator output voltage. Voltage didn't really seem to drop with temperature, only with RPM.
At idle, output was around 37A and voltage had dropped into the 13's
It would seem the alternator will not drop below 14.1v regardless of temperature when traveling in the normal rev range.
I increased the RPM to 2400 with the AGM's connected, this didn't result in an increase in charge. Not sure if the same could be said for the lithiums. Increase in alternator temperature was quick with AGM's but did take a little time. With Lithium it was INSTANT.
Thoughts folks?
Lyndon
FollowupID: 924085
Follow Up By: Member - LeighW - Sunday, Jul 16, 2023 at 16:50
I'm a tad confused you indicate the AGM's are fully charged yet they are putting a considerably load on the alternator looking at the temperature increase?
Flatten the AGM's down to 50% SOC and repeat test and see how the alternator handles them.
Also you wrote engine warm, what do you mean by that?
Is the car fitted with the OEM alternator?
Is it possible the regulator has been replaced at sometime?
It is not unusual to see alternator temperatures of 190C on some models with poor are flow on hot days.
FollowupID: 924090
Follow Up By: Member - lyndon NT - Sunday, Jul 16, 2023 at 17:03
Hi Leigh
I've had the car since new, same alternator. Car sat at idle at 2000 RPM for half hour in 35c.
Not sure if your indicating I need to get it hotter than that?
Please re read and the rest will make sense. If not let me know.
Thanks for the heads up on the 190c, I had no idea.
Lyndon
FollowupID: 924091
Follow Up By: Member - lyndon NT - Sunday, Jul 16, 2023 at 18:10
Leigh, please see details on photos. Might make more sense.
What are you thoughts if I drive the vehicle for an extended period of time and the alternator is still >14v?
Lyndon
FollowupID: 924093
Follow Up By: RMD - Sunday, Jul 16, 2023 at 19:22
Lyndon
If your alternator is running flippin' hot, it may be because it is sucking in the very HOT airflow from the radiator which is already running at 80+ degrees. Maybe try supplying the alt with a flex duct so the intake to alt airlfow is from an ambient source and not the fiery engine bay ambience. With the bay at 80 C There isn't much temp differential at all, to provide much cooling in the alternator internals.
COOLER IS BETTER FOR ALT HEALTH AND LIFE. Get away from temp pics because they only prove things aren't suitable for high output temps and high charge rates
FollowupID: 924095
Follow Up By: Member - LeighW - Monday, Jul 17, 2023 at 13:31
Some aspects I don't understand:
In your intitial testing the alternators hot voltage was less than its cold voltage, in the latest info no change?
You indicate the AGM's are fully charged yet your thermal imaging would imply the altenators it is working very hard?
I would have thought your 3 agm's when down would draw a similar current to the two Lithiums, what size and length cable have you connecting the AGM's. Are you using the same setup for the Lithiums?
What isolator are you using for the AGM's.
When alternators are under a heavy load or at 100% output one would expect to the see the alternators output voltage dropping even if not temeprature compensated ie on a test bench setup yet that does not appear to be the case in your testing?
As for the voltage >14V, if it is only for a short duration and then the batteries are cycled ie charge during the days drive and discharging into a freezer orver night daily then it should not be a big issue. If your going to continue to charge them for hours on end daily when fully charged and thei not being drained after the drive then I wouldn't be happy with that setup. Personnaly when I'm not using the aux and just driving around town I disconnect the Lithium and only charge it when it needs it. which usually never needs to be done between trips.
FollowupID: 924104
Follow Up By: Member - lyndon NT - Monday, Jul 17, 2023 at 18:58
There are details on the photos that are being overlooked.
Anyway.
In the car I had 3 tired old AGM's fully charged.
I ran a test to see what the alternator ambient temperature would be with these still in situ. i.e, under hood temperature.
I then removed these and installed the Lithium
Where upon start up the alternator put in around 60A under the load of the two lithium batteries at idle.
Temp jumped to the mid 120's. I didn't leave it run at this for long as unsure of what temperature alternator could run at.
I shut the motor off for half hour or so. Then ran the motor at 2000 RPM, output 90A, temp jumped into the mid 140's in seconds. I was very concerned, so shut motor down.
I then pulled out the lithium and put in two new AGM's. Details on photos above.
On idle, these pulled around 37 A. At around 13.4 V. Temp from camera was indicating around the mid 120's.
Ran motor up to 2000 RPM and left for around half hour. Initial input was around 68A with camera showing high 130's.
As amperage slowly dropped towards 60A the alternator temperature slowly fell to 105 or 110C
Voltage remained just over 14v.
Out of interest I increased RPM to 2400 as I think this is what it sits around when cruising. There was no noticeable increase in current flow.
Red arc isolator
Car is set up so I can flick a missile switch on dash to link AUX to start if required. New Lithium has a CCA of over 800A
2 B&S I believe. Same as battery cable throughout. Grounding to chassis done at each battery.
Now that I know that alternators run so hot I need to do some more testing.
I have previous towed a camper trailer with 2 AGM's in it also. So I guess the total capacity may have been 350 A/hr. I never tested A or V output on that set up.
I may flatten a couple of these not totally stuffed AGM's join them up to the other AGM and see what the alternator does then. As this will give me a rough comparison to a set up that I know has worked previously with this vehicle.
The Lithiums are going in the boat for an upcoming trip to the beautiful Roper River in a couple of months time.
I will then have to decide as to whether to put them back in the car. If I do, all 3 may be going in. I wonder if the draw will be greater again? Thoughts?
We are heading off to Litchfield in a couple of weeks with the AGM's in the car, so I will take my meters and do some testing to see if this alternator will ever output less than 14v unless at idle.
Lyndon
FollowupID: 924109
Follow Up By: Member - LeighW - Monday, Jul 17, 2023 at 20:04
Personally I would be using smaller cable to limit the charge current somewhat, in my setup I'm using around 4M of 13.5mm cable.
FollowupID: 924111
Follow Up By: RMD - Monday, Jul 17, 2023 at 21:56
Lyndon.
I consider the stationary temps with either the bonnet up, or closed, to be causing different readings as it isn't the situation the alternator or batteries will be operating under. If travelling the hot airflow from the radiator will be flowing rearwards and some of that will be ingested along with it's temp, into the alternator in an attempt to keep it cool. If just stationary, the hot radiator airflow will be causing heat soak to all components and that airflow will sort of static, ie not changing much and be not moving away and the full radiator airflow temp will be the sucked into the alternator. Some tracing/tracking of travelling airflow temps at alt rear, compared to stationary/parked and running airflow might be needed before you can decide on a course of action. I would imagine a significant difference. all needed before you can really tell what temps the alt is running while charging lithium or AGM batteries.
What if what your pictures show, isn't really what happens while in actual use?
Depending on alt fitted, if the alt fan fins are external, are they close to case to ensure a full positive airflow extracted?
Have you ever been through muddy water and the alt stator windings are full of crap and mud and the fan airflow cannot cool it much at all no matter what the engine/alt revs are?
PS. If regulated, After a certain rpm an alternator won't keep increasing output after a designed rpm maximum no matter how fast you rotate it.
FollowupID: 924113
Follow Up By: Member - LeighW - Tuesday, Jul 18, 2023 at 10:05
Lyndon,
What is the year and model of your car?
Idle voltages are not import, the alternator can't produce its maximum voltage at idle if heavily loaded you need to be testing with engine RPM's of 1500RPM or greater.
My main concern with your setup is there doesn't appear to be any temperature compensation taking place, if that is the case then the alternator will not be self protecting which is why I keep placing the importance of testing the voltages under driving conditions and not idling and ensuring temperature compensation is working. I'm assuming you have a diesel engine which take forever to warm up at idle. Load on the alternator though even at idle if great enough should heat up the alternator and cause it to back off back off but depends on load and ambient temperature.
For instance in my case with a light load on a cold day my alternator with a booster diode fitted will start of at around 14.4V and will gradually reduce to around 14.2V after a 20 minute drive or there abouts. If the Lithiums are down it will drop from 14.4V to around 13.8V within a short time and stay there to the load on the alternator drops and will then gradually creep back up to around 14.1V to 14.2V. Hot day voltage might drop to 13.5V before working it's way back up 13.9V or there abouts.
FollowupID: 924116
Follow Up By: Member - lyndon NT - Tuesday, Jul 18, 2023 at 19:18
Model is in the initial heading
2004 Troopy FTE motor.
As I've been saying, and as as Toyota have said, I don't think the alternator is temperature compensated. But a certain few on here have insisted it is.
As for airflow when traveling, yes, yes, I get all that. But if the thing is going to cook itself just at idle with the bonnet up, the rest is kind of irrelevant.
The difference was AGM pulled 37 A at idle, Lithium pulled 60A. In hindsight, I should have run the idle test with the Lithium longer and seen what happened.
As for the alternator not being up to temp so it didn't drop the voltage. Anyone want to say how far above 143 C in needs to get before this function kicks in?
As said, I'll check the voltage output on our run to Litchfield in a couple of weeks (AGM'S) installed.
Lyndon.
PS, not sure what you are putting into those batteries Leigh, but that 6 B&S is only rated to around 55A I think..........
FollowupID: 924122
Follow Up By: Member - LeighW - Tuesday, Jul 18, 2023 at 21:10
Toyota specifies for Land cruisers built around the 2000's that the output voltage should be in the range of 13.2V - 14.8V, I haven't found a Toyota model that wasn't temperature compensated.
The temperature sensor will be in the brush assembly it will take a short time for it to heat and react. Once the temperature rises a few degrees you should see a drop in voltage, if this is not happening something is not right.
FollowupID: 924124
Follow Up By: Allan B (Sunshine Coast) - Tuesday, Jul 18, 2023 at 21:57
Leigh, is that form of compensation intended to protect the alternator or the battery? Or both?
FollowupID: 924126
Follow Up By: Batt's - Wednesday, Jul 19, 2023 at 00:16
An alternator putting 60amps into batteries at idle is very impressive do you have a smaller pulley on it.
FollowupID: 924128
Follow Up By: Member - LeighW - Wednesday, Jul 19, 2023 at 09:45
Alan,
It is designed to protect the battery, the alternators main task is to charge the battery. In recent years car manufactures have also used the feature to reduce fuel consumption and emission though at the expense of battery life. To keep the design of the alternator simple when electronic regulators came along they decided to include the regultor in the brush assembly in most units one imagines for ease of assembly and replacement, to simply wiring within the alternator and to keep it away from the rectifers and their heat generation. With the alternator running under reasonable loads the location of the regulator this is not a problem. With very high alternator outputs though the heat load being shed from the alternator affects the sensor causing the voltage to drop, this is a design comprise but again doesn't cause much of an issue as when alternator output is approaching 100% of its output capacity it won't be able to produce anymore than its rated output which will around 13.8V - 14.2V anyway depending on the manufacturer concerned. It also comes in handy as a persudo form of overload protection but that was not the intention. I have seen alternator regulator chips that do have inbuilt overload protection which acts instantly but in the world of automotive manufacturing if it costs a few cents more their not interested hence why we they are still using incandescent bulbs. There were also more efficient alternator designs in the pipeline but with current developments and the move to towards EV's it would seem continued delevopment in those areas may be a waste of time and as more electonics is involved the higher cost will be a hinderence unless they have to use them for anti pollutions gains etc.
FollowupID: 924130
Follow Up By: Batt's - Wednesday, Jul 19, 2023 at 10:43
Good luck measuring the fuel econ you save through an alternator you might be able to do it in a lab but it would be very difficult in the real world unless you can monitor every milliliter the engine uses.
FollowupID: 924131
Follow Up By: Member - LeighW - Wednesday, Jul 19, 2023 at 11:49
Not that hard to work out and it does make a difference, without idle speed correction ramping up the alternator to max output will slow and engine to the point it gets a rough idle and stumble. A 120A alternator under max load is drawing more than 1.4kW from the engine, at idle possibly 840W. Many smart charge systems reduce the alternator output to the point where the battery is either discharging or just being maintained. They then raise the charge rate during deceleration to put some charge back in the battery.
I haven't seen figures for cars but have seen it for a trucks, they estimated that for 2000 hours of operation the fuel cost to drive a conventional alternator at 100A would be around $1300. With a high compensation type alternator the difference in fuel cost would be around $263 a not insignificant amount and they based that on fuel costing 27C a litre!
FollowupID: 924133
Follow Up By: RMD - Wednesday, Jul 19, 2023 at 15:39
Leigh
You mentioned the brush holder being apart from the hot rectifiers in automotive alternators. The alt in question is a Denso and all recent Denso designs have the brush holder screwed to the rectifier block and rear case. That is hardly apart or separated from the rectifier and it ensure the brush holder is heated by the rectifier. All the ones I have in my shed are like that, older Mitsubishi and many others also are similar.
FollowupID: 924138
Follow Up By: Member - LeighW - Wednesday, Jul 19, 2023 at 16:58
Yep, there is little room in an alternator to mount things, they could have mounted the regulator directly to the rectifer plate if they wanted to heat it that way but they try to maintian as much thermal seperation as possible. The below is a 120 alternator diagram, there just isn't anywhere else to mount the regulator. The regulator itself will aslo generate heat that needs to be shed, note the cooling fins. An external regulator would have been better and in the case of the newer samrt charge setups the engine management system can control the alternator. Interestingly the alternators in such setups still in many cases have an internal voltage regulator and in the event engine management system loosing contact with the alternator regulator the regulator will switch to stand alone mode. This aspect has been used by a few to circumvent the smart charge systems in their cars.
FollowupID: 924140
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Jul 19, 2023 at 17:33
Quite frankly, I cannot imagine that there would be ANY location inside an alternator housing that would be significantly cooler than any other location. It would be anywhere between 120c and 200c. The windings and diodes, being the source of heat, would be the hottest but the rest would not be far behind as the heat from those sources is dispersed.
FollowupID: 924141
Follow Up By: Member - LeighW - Wednesday, Jul 19, 2023 at 17:54
You do have cooling air being dawn in, the air flows over the regulator etc, then across the windings in a compact alternator to shed the heat. If you look at the diagram above the regulator is not in the diode heatsink airflow. Below is the airflow path. I'll see if I can dig up a heat load versus output and post it.
FollowupID: 924143
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Jul 19, 2023 at 18:00
Oh c'mon Leigh, all that diagram shows is that the air enters through the endplates and exits via the centre of the housing.
Inside the alternator would be considerable air turbulence with little temperature gradient.
Remember that I do have some form. I spent much of my life designing, installing and maintaining instrumentation to measure and control heat. I did learn stuff along the way. One being the difficulty of accurately gauging the temperature of specific points within a space of turbulent fluid.
Other than within the windings and right on the diode junctions it is going to be much the same everywhere.
FollowupID: 924144
Follow Up By: Member - LeighW - Wednesday, Jul 19, 2023 at 18:19
Best i can dig up at short notice, regulator remains relatively cool compared to the rest:
FollowupID: 924145
Follow Up By: RMD - Wednesday, Jul 19, 2023 at 18:53
Lyndon's idle test is flawed, because the alternator simply sucks in the heated air back into the inlet vents when the airflow is just milling around and not being changed. Also the background of his photos show the ambient components at around 25 to 30c, so for it to be hot quickly, it must be recirculating it's own air.
With background so cool the engine bay isn't anywhere realistic engine bay temps his battery will experience when all is hot.
FollowupID: 924146
Follow Up By: qldcamper - Thursday, Jul 20, 2023 at 08:28
Allan,
You are forgetting this is an internet forum, where no individule has any respect for any real life experience another individule has.
Many base their arguements on things they may have done once or twice and back it up by digging up diagrams and charts of the net that have no technical references, just invented by other inexperienced would be experts.
How many times have you seen the SOC voltage charts slapped on a thread to express superior knowledge of the subject without reference to temperature and settling periods?
FollowupID: 924149
Reply By: qldcamper - Thursday, Jul 20, 2023 at 08:43
Lyndon,
To save me reading through the pages of 60/40 bulshit/ correct information, have you thought to go to the alternator manufacturer, Denso not Toyota and asking their tech help department what the max continious load current is for your exact alternator is?
It will have been designed to meet specifications requested by Toyota, find out what they are.
AnswerID: 644150
