4WD Indication light
Submitted: Wednesday, Jul 21, 2004 at 10:02
Troopy Travellers (NSW)
Some advice from Troopy drivers please!
On my '89 Troopy I have noticed that the 4WD Indication Light, on the dash, illuminates whenever I put the 4WD gearstick into H4, N & L4. Should the light come on when the gearstick is in N?
I got tricked up with the 4WD light being "on" when I was about to go down a
hill, when I thought I was in L4, but actually I hadn't pushed the gearstick over far enough and I was in "N".
Pretty tricky!!
Sparky
Reply By: V8troopie - Wednesday, Jul 21, 2004 at 11:32
I would say 'yes'.
The way I understand it the "N" position is really for PTO winch usage, the shifting mechanism is still powering the transfer case but not the drive shafts.
Its just a light operated by a little switch that gets activated whenever you move off the H2 position.
Klaus
68785
Follow Up By: Troopy Travellers (NSW) - Wednesday, Jul 21, 2004 at 19:20
Thanks V8 for that info, I will be careful in future!!
329353
Reply By: waveslave - Wednesday, Jul 21, 2004 at 17:24
Hey dude,
It's the same in my Troopy. I've had the same myself, and have just learnt to be 100% sure. Only thing I've encountered is some difficulty getting it BACk into 2wd. I'll be on flat ground,
wheels straight, and i'll have to try 3, 4 or more times to get it back to 2wd. Any suggestions?
68840
Follow Up By: Geoff - Wednesday, Jul 21, 2004 at 18:29
Sounds like transmission windup,can be due to using worn tyres with new ones ie different diameter on front and rear axles.Try reversing before putting back to 2wd.
329340
Follow Up By: V8troopie - Thursday, Jul 22, 2004 at 00:56
My 4WD shifter sticks too if I used it on hard ground (like towing a boat up the ramp). Found that slowly rolling forward, pushing the clutch and, at the same time, push the lever to 2WD does the trick most of the time.
I do that only on level ground, of course. Reversing also works but its not always a good idea with a large boat trailer behind :-)
Klaus
329403
