79 series airconditioner
Submitted: Thursday, May 01, 2025 at 16:22
ThreadID: 150320
FollowUps:2
Ranald N
Airconditioner will not operate properly when outside temperature is over 30 degrees. The compressor starts and immediately cuts out. Very depressing in the middle of the day. Has anyone had similar issues?
Reply By: Member - LeighW - Friday, May 09, 2025 at 20:56
As others have written there will most likely be high and low gas pressure switches. If either is faulty or the gas is low then the compressor would switch off pretty quickly.
The 78 series which I assume would be similar to yours also has a lock sensor in the clutch assembly, a faulty lock sensor circuit will also turn off the compressor quickly.
A faulty AC realy can also cause all sorts of issues.
The other issue is under temperatures can affect connections, switches realys etc, you could try heat the the pressure switches, AC relay etc with a temperature controlled hot air gun and see if you can provoke the fault that way. Simply deciding one part is faulty without doing any real diagnostics is most likely going to be an expensive way of finding the fault. If you don't have the electrical skills to diagnose the problem then take the vehicle to someone who has.
647891
