I found this:
""Do I have to take special steps to protect the battery of my hybrid vehicle if I plan to store the vehicle for an extended period?
In addition to the "storage tips" for our conventionally-powered vehicles, our hybrids require additional steps for each battery, as the hybrid vehicle battery and auxiliary battery will discharge and their condition is liable to decline.
To prevent excessive auxiliary battery drainage, charge the battery at least once every two weeks by powering on the hybrid system for 20 minutes with all non-essential electrical accessories (such as air conditioning and audio equipment) turned off. It is not necessary to drive the vehicle, but do not start the hybrid system in an enclosed area unless the tail pipe is connected to an exhaust hose to prevent harmful buildup of fumes. As an alternative, you may disconnect the negative terminal of the auxiliary battery.
For the hybrid vehicle battery, charge the battery at least once every two months by starting the hybrid system for about 30 minutes*. Check that the "ready" light is on and all lights and electrical accessories are off. As with the auxiliary battery charging, it is not necessary to drive the vehicle, but the steps to prevent exhaust buildup must be taken."
From the above it seems the traction battery will be ok but the 12V battery needs to be every two weeks. I have left my corolla cross for around 5 weeks and it started ok though.
The battery is quite small and 3 months might be a big ask for it to hold enough charge to fire up the car. I would contact the dealer who
services the car and ask.
I just read my owners manual and it indicates you need to disconnect the earth cable if your going to charge the battery with a charger. This may become problematic if you have a power operated tail
gate, you may be able to access the battery via the back though with the rear door closed?
There are some items that may not work correctly when you reconnect the battery at first, check your owners manual.
647954
Wednesday, May 21, 2025 at 07:16
There does seem to be a mountain of information online about long turm storage of the RAV4 Hybrid most talk about disconnecting the negative battery terminal as mentioned above .
as
well as the redit website ....rav4/club where someone said that people get mixed up with incorrect information from non hybrid .
Google AI
929085
Wednesday, May 21, 2025 at 16:28
Leigh
Traction battery aside. Why is there a claim about removing the Negative cable from the AUX battery, It starts the car and is charged while the engine runs. Having something charging it while sitting, ie, as KAZA suggested, is what I do for many vehicles which sit for a while. Just yesterday I gave a mate a mechanical timer to switch on a small maintenance charger to keep his EXPENSIVE MERCEDES battery charged while stored. 5 mins a day, maybe 10 if not quite enough.
Unless the charger is delivering some wildly high voltages to the battery it will be as normal!
929098
Wednesday, May 21, 2025 at 16:50
RMD,
I'm not going to debate it with, I know you believe you know better than everyone else but in this case the auxillary battery is charged by the hybrid system and Toyota have indicated the negative battery terminal should be disconnected before charging the battery if the battery is in the car. In this instance I'm inclined to take the advice of the manufacturer rather than yours.
929099
Wednesday, May 21, 2025 at 21:13
Leigh
I read what you posted! How do you know what I believe? and NO, I don't know or believe I know better than others. I am simply providing an alternative which would deliver a very small charge ability for a short time per day. Others had same idea. Someone suggested leaving it and JUMP STARTING the engine if flat later. Nick B showed a GOOGLE info which says connect a battery charger to it! SAME THING!
I am quite ok if someone wants to remove the aux battery for a long period and then have to deal with any unknown consequences of it being unpowered later on when reconnecting. OK. Maybe there is no down side to doing that. Does anyone really know?
I presume the aux battery is charged by the alternator system on the petrol engine.
The owner could ASK the EXPERTS at the dealers to see if it is OK to do that!
929105
Wednesday, May 21, 2025 at 23:30
Dealer is telling me to leave it on trickle charge while we're away - not sure how safe I feel it would be to do that, sitting in the garage with a charger hooked up for three months while the house is vacant.
I'm leaning towards the option of getting someone in to drive the vehicle for me every couple of weeks instead.
| Wildmax
Formerly an AOR Eclipse and a TVanMember My Profile Send Message |
929107
Thursday, May 22, 2025 at 08:01
RMD,
You wrote you read my post, if you had then you would have read the aux is charged via the hybrids system. The MG charges the high voltage battery which then powers an inverter which charges the aux. You portray yourself as an automotive electrics expert yet you don't know there is no conventional alternator in a Toyota hybrid which any car service centre would be aware of?
929109
Thursday, May 22, 2025 at 08:07
Wildmax,
If the dealer has said its ok to trickle charge the battery then you could just connect the charger via a time clock as suggest.
Also if the deal has indicated its ok to charge the battery without disconnecting the negative cable then there is a set of jump start terminals in or around the engine fuse box that you should be able to connect the charger to without having to access the battery.
929110
