How to reset trip meter
Submitted: Friday, May 23, 2025 at 21:35
ThreadID: 150451
FollowUps:4
Member - Terry O4
How do I reset trip meter on map page
Reply By: Member - nick boab - Saturday, May 24, 2025 at 00:58
Swipe left
Also FYI if you're unaware swiping left option is also when in some of the navigation features ie , delete , routing , etc .
Aswel , menu top left hand corner under setting > map screen you can also add up to three or remove the trip meter completely
as
well as change/edit the way that the main screen appears on your device .
Hope this helps :-)
647980
Reply By: Member - Duncan2H - Saturday, May 24, 2025 at 08:53
Another "trip meter" tip.. you can actually have 3 trip meters displayed.
Settings -> Map Screen -> Odometers -> 3
Its only 1 by default.
I have 3 running:
1. Total Trip Distance
2. Daily Total - reset each morning
3. Fuel Tank Total - reset each fuel fill.
Also turn on Range Rings when you're in settings.. one of
ExplorOz Traveller's finest features.
647984
Follow Up By: Allan B (Sunshine Coast) - Saturday, May 24, 2025 at 09:59
Hi Duncan, would you oblige me by describing the "fine feature" of Range Rings.
I genuinely would like to learn this.
929132
Reply By: Member - Duncan2H - Saturday, May 24, 2025 at 10:27
Allan,
5 circles on the map around your current location.. each at an interval you specify - I have them set 1klm.. at a glance you can assess distance to your next turn or your destination. It really gives me a great awareness of my location in relation to features around me and my intended travel route.
At times I have them set to 10klms instead when on a long drive to a far distant destination - mostly they are set to 1klm when navigating around obscure dirt roads and tracks.
Regardless of the zoom level of the map - you can pick a distance to stuff easily. I genuinely think they should be on by default when the app is installed, one of my favorite features of the app. I have asked for a second set of range rings to be implemented at a different distance interval and in a second colour - I remain hopeful we might see this in some future version.
647985
Follow Up By: Allan B (Sunshine Coast) - Saturday, May 24, 2025 at 11:20
Thanks Duncan, I thought it may be that.
In 2010 I assembled a Silicon Chip project named "Multi-function GPS Car Computer" which included an odometer which could be set to count down from a preset rather than up. I found this very useful to recognise the upcoming turnoff selected from a paper map. With the advent of digital GPS enabled maps it was less necessary as I could see the icon approaching the turnoff on the display so the gadget was dispensed with when it eventually failed.
I can see how the Range Rings can be similarly useful.
929135
