Sawtooth charging from alternator?
Submitted: Wednesday, Jun 04, 2025 at 18:30
Joe
Hi team,
I’m wondering if anyone has seen an issue like this before?
We have 2 x 100a batteries in a camper trailer.
We have been on the road today (and off-
grid for several days where we totally drained the batteries) and we were hoping to charge the batteries. However, instead we charged in this sawtooth pattern and barely put charge into the batteries at all.
We’re currently hooked up to a powered side and the batteries are charging at a pretty constant 16amps.
Any idea as to what may have caused this?
Alternator not happy? Bad batteries?
We do suspect that the 200a of lithium are only holding 120-140amps (based on the smart shunt reading, however, not sure how to confirm that).
Any thoughts would be appreciated!
Sawtooth charging pattern
Reply By: Max E - Wednesday, Jun 04, 2025 at 19:27
I would check for damaged wiring or loose connections.
Assuming you have two 100ah in parallel, I would charge and test them separately.
648075
Follow Up By: Joe - Wednesday, Jun 04, 2025 at 20:43
Hi Max,
Yes they are in parallel.
We had a auto electrician check the wiring. However, we didn't have this issue at the time. He was fixing an Anderson plug issue.
Test with a battery tester at a
shop or another method?
929222
Reply By: Max E - Wednesday, Jun 04, 2025 at 20:47
I would seperate the two batteries. Check voltage and try charging individually.
648077
Reply By: Member - LeighW - Wednesday, Jun 04, 2025 at 20:53
How are the batteries charged, do you have a DCDC for instance?
More info as per the charging setup would be good?
What is the make and model of the tow vehicle?
648078
Reply By: qldcamper - Thursday, Jun 05, 2025 at 07:29
Joe,
Is this the first time you have created these conditions or have you had the batteries this low before and the system has operated satisfactorily, in other words, can you confirm the system has ever worked and this is a recent development?
My guess is it is an equipment incompatibility or failure problem or recent modification. The pattern is too uniform for it to be a wiring fault that has developed.
648081
Reply By: Member - Duncan2H - Thursday, Jun 05, 2025 at 08:43
Kinda looks like a Voltage Sensing Relay like a Redarc SBI or similar cutting in and killing the feed to the camper trailer when the batteries charge and pull down the vehicle system voltage (via whatever mechanism they are hooked up to).. or a DCDC charger itself determining the vehicle is not running just from the voltage level and ceasing charge - when in reality there's a Smart (dumb) Alternator in place..
As others have noted, more information required about setup.
648082
Follow Up By: Joe - Friday, Jun 06, 2025 at 12:12
This is what the auto elec thought and he has wired to the ignition. We will test it today.
929237
Reply By: RMD - Thursday, Jun 05, 2025 at 08:49
G'day Joe.
Looks to me to be the action of a DC DC Charger going flat out, and reducing it's output because of internally generated heat and therefore almost stopping the charge delivery UNTIL it cools below a set internal threshold, ONLY to be TAXED again as straight away the heat build up again reduces output to SAVE the DC DC UNIT itself. Is the DCDC unit able to be cooled? Does it have an internal fan? is there copious amounts of COOL passing air so it CAN DO IT's JOB? if hidden away inside a caravan bin or cupboard there is almost NO airflow to cool a DC DC unit. Even having a DC DC mounted horizontally and NOT VERTICALLY can make a big difference to the ability of the airflow not being able to travel/pass upwards and carry heat away. Ok under light duty, but high current , maybe NOT!
While the Max load of deep discharged batteries is being applied to the DCDC , it will continue to do that.
You did say alternator charged but didn't specify if ALT to BATTERIES DIRECT or through a DCDC UNIT.
If the alt is used directly to the batteries, THAT can cause the alt to fail through CONSTANT HIGH AMP DELIVERY which they are not designed for, ie LONG TERM Duration of plenty near MAX amps.
648083
Follow Up By: Joe - Friday, Jun 06, 2025 at 12:11
Interesting about the heat. I'll check when on the road today.
It's a Cub Frontier and in a cupboard. Not much airflow at all. I will try and fell for heat after stopping.
It is through a projecta dc-dc charger.
929236
Reply By: tonysmc - Thursday, Jun 05, 2025 at 09:32
I’ve hooked up a DCDC charger in my boat, to charge an auxiliary lithium battery. The boat motor only puts out 35 amps maximum. I was finding the charger was cutting it and out like this (sawtooth) and I assumed it was because charging the lithium was drawing power too quickly from the battery it was charging from, and that battery voltage dropped too much. I made some changes that fixed it.
What DCDC charger do you use and does your car have a smart alternator? I am no expert on electrics but I’m guessing your charger might be trying to charge the flat batteries at full capacity of 40 amps but is then sensing a voltage drop from the main battery, so stops. Then the main battery voltage comes up and the cycle starts again. I’d be looking the inlet voltage to the charger and see what it is reading at.
648084
Reply By: Joe - Thursday, Jun 05, 2025 at 09:48
Thanks for the input everyone!
We have a 2021 Prado, can't comment on if it is a smart alternator.
Alternator is going through a projecta BMS before going into the batteries.
Perhaps the cutting in and out from flat was causing it. I'll hook it up to the car this morning and see what happens. I will report back.
648085
Reply By: qldcamper - Friday, Jun 06, 2025 at 06:16
You wouldn't happen to.have an auto reset circuit breaker in the feed from the original charging system would you?
Can you hear a ticking noise every 30 seconds or so?
648091
Follow Up By: Joe - Friday, Jun 06, 2025 at 09:24
I'll keep an ear out for this. I don't believe that I have heard this.
929231
Reply By: Joe - Friday, Jun 06, 2025 at 09:28
Morning All,
We stopped by an auto electrician yesterday. He replaced the ends of the Anderson plug, checked the ground and wires. That didn't help.
He believes that there was a voltage drop when the DCDC charger kicked in and that caused the charged to go off. Suggested there may be voltage drop from front to end.
It then cycles back on and repeat.
He then looked for an 'on' wire in the projecta management system to power on when there is current instead of using a change in voltage to trigger. We're hoping that this solves the problem. I'll report back.
648092
Follow Up By: tonysmc - Friday, Jun 06, 2025 at 10:11
2021 Prado does have a smart alternator, so you definitely need that ignition trigger wire connected.
929232
Follow Up By: Loddo48 - Friday, Jun 06, 2025 at 10:46
The 2021 Prado doesn't have a smart alternator; it has a temperature compensating alternator. Yes, I have one and use a dc 2 dc charger in both the car and caravan and have no problems with running both charger at maximum load. I think there is more a problem with the projecta charger.
929233
Follow Up By: RMD - Friday, Jun 06, 2025 at 11:17
Sounds like the auto elec did “somefink’ but really didn’t try to fix nothing. Of there is a voltage drop when the dc dc operates, it would be easily replicated and checked. Didn’t do it!
If you have access to an infrared thermometer, you can point it at various items in the circuit and detect if it is Bloody hot and likely turning itself off and on to save itself. The problem has only arisen when the batteries are deeply discharged , and that changes the dynamics of systems which previously operated ok at lighter loads.
929234
Follow Up By: qldcamper - Saturday, Jun 07, 2025 at 07:39
Joe hasn't actually answered my question of if the system has ever worked so hasn't even ruled out a design/new equipment fault or if it is a developed fault. Undoubtably the sparky will have asked all these questions. But I agree with you, anybody with half an idea will have narrowed it down pretty quickly with some very basic tests. Fancy gear like temp guns help but we all have,or had 10 very sensitive temp sensors that are very affective. A circuit that should be capable of high currents that fails at 18 amps is going to be a fairly obvious reason.
929242
Follow Up By: RMD - Saturday, Jun 07, 2025 at 12:03
QLD.
I thought your idea of the Thermo cutout was another possible. Didn't think anyone would fit it in line to a DC DC unit though. Sounds like Joe has been previously running CLOSE to the WIND and now has exceeded a device in the system. Why I mentioned the Infrared unit was, Some caravans have things buried inside where they are hard to reach/touch.
Fully charging the batteries with a KNOWN charger and resetting the SHUNT should provide a greater awareness of system condition!
Joe was a bit misleading. The Saw Tooth charge pattern WAS NOT originating from the alternator but from a DC DC UNIT. That alters what people can perceive and decide on possible faults.
929243
Reply By: Member - LeighW - Friday, Jun 06, 2025 at 09:44
Joe,
Where is the smart shunt installed, ie before the charger or after the charger?
Can you post up the corresponding voltage graph?
As Loddo48 wrote the Prado 150 doesn't have a smart alternator and you shouldn't
need the ignition trigger under normal circumstances.
648093
Follow Up By: Joe - Friday, Jun 06, 2025 at 12:09
It is installed after all the load on the negative side.
Yes, I will take a snapshot while driving this morning.
Ok. That's a pity that he's needed to 'override'.
929235
Follow Up By: Member - LeighW - Friday, Jun 06, 2025 at 12:26
What other loads are connected?
929238
Follow Up By: Joe - Friday, Jun 06, 2025 at 12:43
A fridge, lights, charging plugs and a pump.
929239
Follow Up By: Member - LeighW - Friday, Jun 06, 2025 at 13:58
What type of fridge, compressor of absorption. If absorption do you run it off 12V while traveling?
929240
Reply By: Joe - Sunday, Jun 08, 2025 at 19:09
Another update as the plot thickens...
1) on a friend's car we get stable charge through the alternator. (Image FA).
2) since the adjustments by the auto elec we get a better charge on the battery with OUT alternator...but it still drops out . (Image A)
3) when charging with a solar blankets - with direct sun, I heard the DC DC drop out periodically with a slight whine sound. (Image S)
I can't work out where the problem lies as it seems that the issue is present with both solar and alternator, however, it appears with solar as
well?! Or does solar drop out like this normally?
Friends alternator (2014 Prado)
Solar blanket
Alternator
648106
Follow Up By: RMD - Sunday, Jun 08, 2025 at 19:49
Hello Joe.
Can you let us know what brand of DC DC charger you are using please. I tried a cheaper brand which claims all sorts of abilities but they operate on and off all the time and DO NOT produce ANY MPPT operation. I had two the same, both Sub Standard.
Thanks.
929249
Follow Up By: Joe - Sunday, Jun 08, 2025 at 19:52
Yes, it's a Projecta 25a DCDC.
929250
Follow Up By: RMD - Sunday, Jun 08, 2025 at 19:57
Joe.
Do you have access to try another brand? I had one of those as
well and it did much the same after working ok for a while. I noticed the dropping whine with it too.
929251
Follow Up By: Joe - Monday, Jun 09, 2025 at 11:20
We will be stopping in
Broome in 3 or 4 days. We can try and pick up another one then.
Any suggestions as to better options or brands of chargers to look at?
929253
Follow Up By: tonysmc - Tuesday, Jun 10, 2025 at 20:38
Hi Joe, if getting a stable charge on your friend’s car, it suggests it is not the charger itself but something else in your car. Hate for you to spend money on a new charger that doesn’t fix the issue, so here’s some random ideas. As someone said earlier, it seems like an auto reset circuit breaker operating but if there is not one in the system, I’d suggest try moving any earth connections to see if any are loose? Have you put a multimeter on the input side of the charger while the alternator is running to see if there is any change in voltage? Has the DCDC chargers’ mode been set to Lithium or is it still on wet cell?
929256
Follow Up By: Joe - Tuesday, Jun 10, 2025 at 21:31
Hi Tony,
I 100% agree. However, I have tried 2 different solar blankets and have the same issue with those as
well. The whine and cut out is present with both blankets.
We have had an auto elec check all grounds and charger rates twice in the car. Toyota has also checked the alternator.
We're going to a power
shop in
Broome. I'll ask them to check those things. Thank for the suggestion.
929257
Follow Up By: qldcamper - Wednesday, Jun 11, 2025 at 05:59
Joe,
I have been trying not to let my personal opinion of Projecta equipment sway my judgement but anyone in the automotive trade that was around when Projecta first hit our market probably has a similar opinion.
Unless fitted with a cooling fan which low power DCDC chargers of any quality should not need should make no audible noises, their frequency of operation should be
well above our hearing range.
Without hands on testing I'm not going to guess a diagnosis but that is a big arrow pointing at the charger for closer investigation.
929258
Follow Up By: RMD - Wednesday, Jun 11, 2025 at 19:20
I agree with QLD. Maybe, as a short term test, Simply jump/connect the alternator output via length of heavy wire which WILL ACT as a resistor and may get warm if there for too long, AND HAVE IT CONNECTED direct to the aux battery. Straight away, if the charge happens correctly and is constant, the DC DC unit would seem to be the problem. A short term test might prove which way to decide/move!
929267
Reply By: Tony W - Wednesday, Jun 11, 2025 at 06:34
To me, it looks like a clear case of the cable between the Main Battery and the input of the DC DC charger is too long, or too thin, or both.
If it's less than a meter between the charger and the battery use at least 6B&S, if it's any further use 4 or 3 B&S. On both positive and negative sides
648114
Follow Up By: RMD - Wednesday, Jun 11, 2025 at 19:07
Tony W
Previously the system worked ok, with same wiring. How did the wiring get too long or thin if it hasn't been touched, replaced or altered?
929266
Follow Up By: greybeard - Wednesday, Jun 11, 2025 at 22:24
If the wiring hasn't changed then maybe bad/loose/dirty connections.
929270
Follow Up By: Tony W - Thursday, Jun 12, 2025 at 05:53
To the OP, if the 2nd axis, currently set to aux input, was set to input voltage it would provide more clues.
929271
