Sawtooth charging from alternator?
Submitted: Wednesday, Jun 04, 2025 at 18:30
ThreadID: 150546
FollowUps:24
Joe
Hi team,
I’m wondering if anyone has seen an issue like this before?
We have 2 x 100a batteries in a camper trailer.
We have been on the road today (and off-
grid for several days where we totally drained the batteries) and we were hoping to charge the batteries. However, instead we charged in this sawtooth pattern and barely put charge into the batteries at all.
We’re currently hooked up to a powered side and the batteries are charging at a pretty constant 16amps.
Any idea as to what may have caused this?
Alternator not happy? Bad batteries?
We do suspect that the 200a of lithium are only holding 120-140amps (based on the smart shunt reading, however, not sure how to confirm that).
Any thoughts would be appreciated!
Sawtooth charging pattern
Reply By: RMD - Thursday, Jun 05, 2025 at 08:49
G'day Joe.
Looks to me to be the action of a DC DC Charger going flat out, and reducing it's output because of internally generated heat and therefore almost stopping the charge delivery UNTIL it cools below a set internal threshold, ONLY to be TAXED again as straight away the heat build up again reduces output to SAVE the DC DC UNIT itself. Is the DCDC unit able to be cooled? Does it have an internal fan? is there copious amounts of COOL passing air so it CAN DO IT's JOB? if hidden away inside a caravan bin or cupboard there is almost NO airflow to cool a DC DC unit. Even having a DC DC mounted horizontally and NOT VERTICALLY can make a big difference to the ability of the airflow not being able to travel/pass upwards and carry heat away. Ok under light duty, but high current , maybe NOT!
While the Max load of deep discharged batteries is being applied to the DCDC , it will continue to do that.
You did say alternator charged but didn't specify if ALT to BATTERIES DIRECT or through a DCDC UNIT.
If the alt is used directly to the batteries, THAT can cause the alt to fail through CONSTANT HIGH AMP DELIVERY which they are not designed for, ie LONG TERM Duration of plenty near MAX amps.
648083
Follow Up By: Joe - Friday, Jun 06, 2025 at 12:11
Interesting about the heat. I'll
check when on the road today.
It's a Cub Frontier and in a cupboard. Not much airflow at all. I will try and fell for heat after stopping.
It is through a projecta dc-dc charger.
929236
Reply By: Joe - Sunday, Jun 08, 2025 at 19:09
Another update as the plot thickens...
1) on a friend's car we get stable charge through the alternator. (Image FA).
2) since the adjustments by the auto elec we get a better charge on the battery with OUT alternator...but it still drops out . (Image A)
3) when charging with a solar blankets - with direct sun, I heard the DC DC drop out periodically with a slight whine sound. (Image S)
I can't work out where the problem lies as it seems that the issue is present with both solar and alternator, however, it appears with solar as
well?! Or does solar drop out like this normally?
Friends alternator (2014 Prado)
Solar blanket
Alternator
648106
Follow Up By: RMD - Sunday, Jun 08, 2025 at 19:49
Hello Joe.
Can you let us know what brand of DC DC charger you are using please. I tried a cheaper brand which claims all sorts of abilities but they operate on and off all the time and DO NOT produce ANY MPPT operation. I had two the same, both Sub Standard.
Thanks.
929249
Follow Up By: Joe - Sunday, Jun 08, 2025 at 19:52
Yes, it's a Projecta 25a DCDC.
929250
Follow Up By: RMD - Sunday, Jun 08, 2025 at 19:57
Joe.
Do you have access to try another brand? I had one of those as
well and it did much the same after working ok for a while. I noticed the dropping whine with it too.
929251
Follow Up By: Joe - Monday, Jun 09, 2025 at 11:20
We will be stopping in
Broome in 3 or 4 days. We can try and pick up another one then.
Any suggestions as to better options or brands of chargers to look at?
929253
Follow Up By: tonysmc - Tuesday, Jun 10, 2025 at 20:38
Hi Joe, if getting a stable charge on your friend’s car, it suggests it is not the charger itself but something else in your car. Hate for you to spend money on a new charger that doesn’t fix the issue, so here’s some random ideas. As someone said earlier, it seems like an auto reset circuit breaker operating but if there is not one in the system, I’d suggest try moving any earth connections to see if any are loose? Have you put a multimeter on the input side of the charger while the alternator is running to see if there is any change in voltage? Has the DCDC chargers’ mode been set to Lithium or is it still on wet cell?
929256
Follow Up By: Joe - Tuesday, Jun 10, 2025 at 21:31
Hi Tony,
I 100% agree. However, I have tried 2 different solar blankets and have the same issue with those as
well. The whine and cut out is present with both blankets.
We have had an auto elec
check all grounds and charger rates twice in the car. Toyota has also checked the alternator.
We're going to a power
shop in
Broome. I'll ask them to
check those things. Thank for the suggestion.
929257
Follow Up By: qldcamper - Wednesday, Jun 11, 2025 at 05:59
Joe,
I have been trying not to let my personal opinion of Projecta equipment sway my judgement but anyone in the automotive trade that was around when Projecta first hit our market probably has a similar opinion.
Unless fitted with a cooling fan which low power DCDC chargers of any quality should not need should make no audible noises, their frequency of operation should be
well above our hearing range.
Without hands on testing I'm not going to guess a diagnosis but that is a big arrow pointing at the charger for closer investigation.
929258
Follow Up By: RMD - Wednesday, Jun 11, 2025 at 19:20
I agree with QLD. Maybe, as a short term
test, Simply jump/connect the alternator output via length of heavy wire which WILL ACT as a resistor and may get warm if there for too long, AND HAVE IT CONNECTED direct to the aux battery. Straight away, if the charge happens correctly and is constant, the DC DC unit would seem to be the problem. A short term
test might prove which way to decide/move!
929267
