Friday, Jun 20, 2025 at 07:26
Hi T Tours,
As outlined in our System Requirements, the minimum specifications are based on operating system versions. This is because your device’s OS version determines whether the app can be found and installed from the app store.
We’ve kept the requirements quite low — Android 8 and iOS 14 — to ensure broad compatibility. However, please note that older devices running these versions may
not offer optimal performance, and we do
not recommend relying on outdated hardware.
For the best experience, we suggest using a high-performing device, although the choice ultimately depends on your budget.
Ask other app users for their personal recommendations if you like - theres lots of this chat shared on the
ExplorOz Traveller Facebook User Group.
Cheers Michelle
929330
