Saving a Trek ? No Position Recorded on Save/Archive?
Submitted: Saturday, Jul 05, 2025 at 13:22
Member - Mark B68
I enabled tracker and drove from Northside
brisbane to Bribi and return. I then disabled tracking and went to Save/Archive trek but got message No Positions Recorded.? The Reload just keeps counting down?
I went from Samsung Phone to Samsung Tab and can see the trek but getting same message ??
Do I need some more RTFM/Watch Video or is their an issue?
| Mature Couple - Still working!! waiting to make the BIG STEP to go travel this big country of ours.
Background of Military Service, Medical and ITMember My Profile My Position Send Message |
Reply By: Member - A_P - Saturday, Jul 05, 2025 at 17:27
Have you looked in the search menu in the
track logs section?
648208
Follow Up By: Member - Mark B68 - Saturday, Jul 05, 2025 at 17:56
Will see if I can find it!
929415
Follow Up By: Member - Mark B68 - Saturday, Jul 05, 2025 at 18:43
Not quite sure what I am searching for as I am unable to save the Trek?
929416
Reply By: TrevorDavid - Saturday, Jul 05, 2025 at 18:56
Mark
It is a Track not a Trek. Try enabling tracking and see if you can save it. If all else fails have a squiz in export positions & save it from there.
TrevorDavid
648209
Follow Up By: Member - Mark B68 - Saturday, Jul 05, 2025 at 20:54
Worked it out eventually... Thanks Heaps... just need to use the Tracking option a bit more.... :-)
929417
Reply By: Member - A_P - Saturday, Jul 05, 2025 at 19:38
The search menu is between the pin and the folder icon top right corner of the Traveller app
The
track logs ( if auto saved) are in the
Track logs icon ( to the right of
places and
treks)
If your position data was auto saved then it should be there
If you disabled tracking before your device had time to sync data then you should re-enable and give it time to do that. The
track logs data comes from the ExplorOz server, not from the device
648210
Follow Up By: Member - Mark B68 - Saturday, Jul 05, 2025 at 20:55
Thanks heaps ... just need to use it some more.....
929418
