Charging Alt Battery from Smart Alternator
Submitted: Wednesday, Aug 06, 2025 at 17:11
ThreadID: 151242 Views:6587 Replies:13 FollowUps:58
I'm sure this has been done before but after searching archives I 'm having difficulty. I have a 80 series LC with a 2nd battery connected by an isolator switch. Used mainly to run the Engel 45lt fridge. Now this works fine for me over the last 20 years.
Now my grandson aged 21 has 2018 Pajero and want to go bush with me so he is asking me how to set up a 2nd battery system. I understand that his Pajero has a smart alternator, I basically understand how they work. I've said to him to use the KISS principal for his setup as he will only go bush occasionally.
I believe going to Auto electricians for a wired system can cost up to $2000. this is unnecessary for what he intends to do.
So my suggestion to him is to buy wet cell 100ah battery, put it into a battery box, connect his Engel fridge and charge it through the cig lighter socket in the back of vehicle. (I'm aware he may need a dcdc charger between the alternator and battery)
Considering the smart alternator issue is this method feasible? if not I'm looking for an equally simple set up
Cheers Jeff R
Reply By: Batt's - Wednesday, Aug 06, 2025 at 17:42
Depends on his budget but another option is a battery box with built-in charger/isolator that covers all battery types so it's a one of buy and no need to upgrade in the future. You will only need to run some wires off the starter battery fit an Anderson plug and away you go.
AnswerID: 648382
Follow Up By: jeff r - Saturday, Aug 09, 2025 at 17:18
Thanks Batts for your input appreciate it.
FollowupID: 929706
Reply By: IvanTheTerrible - Wednesday, Aug 06, 2025 at 18:31
You cant have a battery in the cabin of a vehicle unless it's fully sealed to the cabin and vented to the outside.
AnswerID: 648385
Follow Up By: IvanTheTerrible - Wednesday, Aug 06, 2025 at 18:49
The cig socket probably will not supply enough current and w ithout a DC-DC will never provide a good charge voltage
FollowupID: 929651
Follow Up By: Batt's - Wednesday, Aug 06, 2025 at 20:34
Is there a push on for that in 4wd's these days ? There would be thousands of people with an agm or lithium in their cabin but yes I wouldn't put a lead acid in there because it's venting gasses all the time.
FollowupID: 929655
Follow Up By: IvanTheTerrible - Wednesday, Aug 06, 2025 at 20:45
Batt's We have had a customers car fail a roadworthy. We had to fit a sealed box out of a race car. :-)
FollowupID: 929656
Follow Up By: Batt's - Wednesday, Aug 06, 2025 at 23:00
So interesting to find out if that was just the individual who done the roadworthy's choice to knock it back or if there is a crackdown on it in certain states or Australia wide like batteries in caravans these days.
We had a van 20yrs ago and it had a lead acid already under the lounge seat which was not in a sealed box I so I fitted one and ran a clear tube to the outside.
FollowupID: 929660
Follow Up By: Allan B (Sunshine Coast) - Thursday, Aug 07, 2025 at 09:22
Ivan is wrong. AS/NZ 3001 applies to recreational vehicles but not passenger vehicles. So if the "car" that Ivan refers to was not a motorhome or caravan then it was not subject to that regulation and should not have been defaulted.
This is a cut-and-paste from AS/NZ 3001……….
"Specifies requirements for electrical installations associated with connectable electrical installation s used for the purposes of accommodation, habitation or other residential, commercial purposes or recreational uses that are intended for connection to external low voltage a.c. supply systems (i.e. 50 V a.c. to 1000 V a.c.) "
FollowupID: 929663
Follow Up By: Peter_n_Margaret - Thursday, Aug 07, 2025 at 09:35
"AS/NZ 3001 applies to recreational vehicles but not passenger vehicles."
Wrong again :)
AS/NZ 3001 applies to "transportable buildings" and a transportable building needs to have the capability to be plugged into the grid.
It could be a passenger vehicle, but it does not apply to a recreational vehicle (or any other vehicle) that can not plug into the grid.
FollowupID: 929664
Follow Up By: Member - LeighW - Thursday, Aug 07, 2025 at 10:29
From the VIC roads website regarding roadworthiness:
"All batteries must be adequately supported and secure. In addition, if fitted in a luggage or occupant compartment, the battery must either be of a type that is fully sealed or be located within a sub compartment which is vented to atmosphere outside the vehicle.
Vehicles with batteries located in the same way that the vehicle manufacturer installed the original battery are deemed to comply with this requirement, provided the battery is of the same type as the original, and its installation and related components are as per the vehicle manufacturer’s specification."
FollowupID: 929666
Follow Up By: Allan B (Sunshine Coast) - Thursday, Aug 07, 2025 at 13:04
Peter, NOT "wrong again" I'm afraid, but merely an abbreviation that applies to the subject that Ivan raised. There is a section within AS/NZ 3001 that relates specifically to motorhome and caravans. And yes, it does refer to those with an installed 230vac inlet facility, which those vehicles mostly have. But the Standard has no reference or relativity to "cars" which is what Ivan said….."We have had a customers CAR fail a roadworthy."
My copy of AS/NZ 3001 is "corrupted" and when I have time to sort it out I can quote details.
FollowupID: 929668
Follow Up By: Batt's - Thursday, Aug 07, 2025 at 13:26
I wouldn't say Ivan was wrong as I expect they would have been going of information supplied to them by the customer.
The type of battery was not mentioned either which can make a big difference.
FollowupID: 929669
Follow Up By: Peter_n_Margaret - Thursday, Aug 07, 2025 at 16:43
Allan, I am pretty sure that AS/NZ 3001 does not apply to ANYTHING that is not "Connectable" ie. capable of being plugged into the grid (and everything - with some specified exemptions, that does).
My OKA can't be "plugged in" and it therefore AS/NZ 3001 does not apply. What does apply though is AS/NZ 3000 due to the power distributed from the inverter via hard wiring.
The fine print is critical with this stuff..... It is hard work to comprehend sometimes.
This is a list of exclusions I acquired form somewhere. Edit: says "2:2022"
My conclusion is that if the NON recreational vehicle (car) is "connectable" then 3001 applies.
And if it is NOT "connectable" the 3001 does NOT apply.
FollowupID: 929673
Follow Up By: Allan B (Sunshine Coast) - Thursday, Aug 07, 2025 at 18:33
Peter, You say that I am "Wrong again" but that is not so . AS/NZS 3001.2 has a title of "Electrical installations — Connectable electrical installations and supply arrangements."
Under "1.1 Scope" it includes "Section 1.1.2.2 Recreational vehicles: (a) Caravans, (b) Campervans, (c) Motor homes, (d) etc.etc. and a range of non-recreational vehicles.
My point of argument with Ivan is that he said a "customer's car failed a roadworthy" due to non-conformity for lack of a sealed battery box. Well he did not say "motorhome" etc, he said a "car" and I very much doubt that the car was not arranged with a 230vac inlet socket in order to qualify as a "Connectable unit".
DISCLAIMER: Leigh makes a point that….."All batteries must be adequately supported and secure. In addition, if fitted in a luggage or occupant compartment, the battery must either be of a type that is fully sealed or be located within a sub compartment which is vented to atmosphere outside the vehicle."
And I can well believe that. When it comes to electrical matters, Victoria does not necessarily conform to Australian Standards as do other States but "goes it alone". I have had the pleasure(?) of working under Victorian electrical regulations who refused to recognise my South Australian Electrical Workers Certificate and I had to be examined and qualify all over again to qualify for their certification. It is not just Victoria either, even those States that adopt the AS/NZS 3000 often have interpretations and additional requirements. It can make working Commonwealth-wide rather difficult.
Peter, you highlight an image from AS/NZS 3001 that states about "Other vehicles may use this Standard as a guide" which means that although these vehicles are not embraced with the Standard's requirement, it is suggested that they may find the Standard useful as a guide." But not a requirement.
Yes, the "fine print is critical" and I am very familiar with interpreting these Australian Standards (and others) in the performance of my work.
My over-riding point is that Ivan's expression should not be taken at face value without considering the specific circumstance. Ivan is good at throwaway expressions.
Incidentally, this may be a good opportunity to point out that AS/NZS refers to "Lithium ion" batteries and makes no distinction of a LiFePO4 battery. however, I have had communication with the Standards organisation and they consider that a LiFePO4 battery (Lithium Iron Phosphate battery) is a type of lithium-ion battery. So do not consider that a LiFePO4 battery is not excluded from the requirements.
FollowupID: 929678
Follow Up By: Peter_n_Margaret - Thursday, Aug 07, 2025 at 19:08
I agree with your post detail Allan, but "Non connectable = Not applicable".
https://www.australiastandards.com/product/as-nzs-3001-2-2022/
"Specifies requirements for electrical installations associated with connectable electrical installation s used for the purposes of accommodation, habitation or other residential, commercial purposes or recreational uses that are intended for connection to external low voltage a.c. supply systems (i.e. 50 V a.c. to 1000 V a.c.) by either a detachable supply lead or a supply lead directly connected to the connectable electrical installation. Includes requirements and provides guidance for the installation of extra-low voltage systems (i.e. less than 50 V a.c. or 120 V d.c. ripple free)."
OKA 196 motorhome
FollowupID: 929679
Follow Up By: Bonz (Vic) - Thursday, Aug 07, 2025 at 19:50
AllanB. Ivan said the car was knocked for roadworthiness, not electrical compliance.
All the AS 3001 chatter is irrelevant to a roadworthy requirement. As I found out from VicRoads, to put a battery inside my Troopy, it either had to be fully sealed or in a compartment sealed from the vehicle interior and vented or open to the vehicle exterior. They printed the blurb off their website for me which specified it. Ivans advice is spot on what VicRoads told me.
FollowupID: 929680
Follow Up By: Allan B (Sunshine Coast) - Thursday, Aug 07, 2025 at 21:02
Then I owe Ivan an apology. ..... Sorry Ivan. I clearly misunderstood you.
I was not aware that Victoria was writing its own motor vehicle standards outside of the national ADR regulations and legislation pertaining to . Australian Standards. Has the Victorian state government again drafted its own legislation and rules in this matter?
FollowupID: 929681
Follow Up By: Bonz (Vic) - Thursday, Aug 07, 2025 at 21:11
The roadworthy stuff varies state to state and isn’t an AS/NZS afaik. Wouldn’t it be lovely to have a national roadworthy standard. We are a nanny state tho. So beware????
FollowupID: 929682
Follow Up By: Allan B (Sunshine Coast) - Thursday, Aug 07, 2025 at 21:39
I sometimes wonder how much $ all this State duplication is costing us taxpayers in having the law fraternity and the state administrations to duplicate legislation and other controls for matters that are common to the whole of Australia. The only real thing that varies by State is the weather…. and none of them can control that anyway.
FollowupID: 929683
Follow Up By: Bonz (Vic) - Thursday, Aug 07, 2025 at 21:42
I think theres a strong case to abolish State Government and have federal and local government bodies.
FollowupID: 929684
Follow Up By: Batt's - Friday, Aug 08, 2025 at 01:10
They've had these different laws and rules between states for too long and have little disregard to how much it cost the taxpayers especially when the money could have been used for much better things.
It also keeps the government happy putting state against state and they have some many sheep following them who are blind to the reality of things.
Was looking at a caravan in NSW recently but to bring it over the border to QLD the rta basically told me it is de registered any money left on the plates either goes to me or the previous owner they weren't 100% sure who. Then has to get a QLD roadworthy and gas inspection then reregistered not just a simple transfer even though the vehicle had a current NSW roadworthy certificate.
NSW owners don't need a gas certificate to sell a van but in QLD you do so I could have been also buying something with hidden issues because of the different state rules making things difficult.
Not worth the hassle plus throwing more money down the drain.
FollowupID: 929685
Reply By: jeff r - Wednesday, Aug 06, 2025 at 19:14
I'll certainly use some hefty wiring from the starter battery to the 2nd battery
AnswerID: 648386
Follow Up By: jeff r - Wednesday, Aug 06, 2025 at 19:37
Just looked at the Kickass Battery box certainly looks the part. I'll ditch the idea of charging via cig socket and use a Anderson plug instead. I also like
the idea of mounting a dcdc charger on top.
Will the smart alternator be capable of fully charging the battery with this con figuration?
FollowupID: 929652
Follow Up By: Batt's - Wednesday, Aug 06, 2025 at 20:16
That's why they have the dcdc charger to compensate for low voltage that might be supplied from the smart alternator. These types of chargers are usually designed to correctly recharge the battery in stages which should give the battery the best chance of lasting for a long time. That's the basics of how I would explain it others may have more technical info in you need it.
Only other thing is I wouldn't use a blade type of fuse on a charger again because I had one melt before it blew and use ANL type for higher voltage with a spare fuse or on hand and trip switches can trip out with the extra heat if there under the bonnet.
FollowupID: 929654
Follow Up By: Batt's - Thursday, Aug 07, 2025 at 13:38
If looking at a lithium battery find a battery box that has everything set up ready to go so it's just plug and play then you don't have to muck around setting up your own shunt and monitor.
Or just use an agm battery for simplicity which is fine inside the cabin of a vehicle.
Unfortunately it can get overwhelming these days but there are easy ways to get around it.
FollowupID: 929670
Follow Up By: jeff r - Thursday, Aug 07, 2025 at 17:04
Thanks again, I'll probably go with the AGM, I know the value of the Lithium but I want to keep the batteries as similar as possible to aid charging.
FollowupID: 929676
Reply By: Member - Bigfish - Thursday, Aug 07, 2025 at 06:20
I,ve a second battery set up in my Pajero that has been in there for about 9 years. Lithium battery now (was AGM). DC/DC in section at rear where 3rd seats were taken out. 2 x 100 a/h lithium batteries. Single 6B&S wire from start battery positive to anderson plug for dc/dc and an earth wire from a bolt found in the 3rd row section for an earth. Do not run an earth wire from start battery...most dc/dc instructions say this anyway for smart alternators at least. Good quality dc/dc will have a voltage sensing system anyway so a separate switch at start battery not needed. Use a suitable fuse to suit dc/dc sizeand cable. Definitely put a shunt on the battery so you can monitor charge and discharge/state of battery. Go lithium...lighter, last longer and more efficient.
AnswerID: 648387
Follow Up By: jeff r - Saturday, Aug 09, 2025 at 17:23
Bigfish, I really appreciate your thoughts, 6B&S from the start batt and dcdc charger now on our list.
FollowupID: 929707
Reply By: Member - McLaren3030 - Thursday, Aug 07, 2025 at 07:17
Hi Jeff R,
Firstly, let me state that I am not an Auto. Elec. or a 12 volt specialist.
A Cig. Lighter socket is generally only a 10 amp supply, so trying to charge a 100 AmpHr battery from a 10 amp supply is going to take a very long time, depending on how “flat” the battery is. A compressor fridge could theoretically use between 72 & 120 amps in a 24 hour period. Yes, the vehicle would be providing charge to the Aux. Battery whilst the engine is running, but the fridge is also drawing from the battery at the same time. You would be far better using a dedicated 6 B&S cable from the cranking battery to a genuine 50 amp Anderson plug. If you are going to use a LiFePo4 battery, then a DC/DC Charger with a dedicated LiFePo4 charging profile would be a good idea. A shunt connected to the battery negative terminal and a display showing the battery voltage, and more importantly the SOC (State of Charge) is also a good idea.
As far as a battery in the cabin of the motor vehicle not being roadworthy is concerned, I have not heard of that one before. Certainly the regulations around battery storage and caravans as changed, but I have not heard of these changes applying to auxiliary batteries in motor vehicles. Certainly Jeeps and Landrovers had their cranking batteries inside the cabin of the vehicle for many years, not sure if this is still the case. In fact, Slimline LiFePo4 batteries are designed so that they can be installed behind the seats in a Ute. In my case, my 175 AmpHr LiFePo4 battery is in the rear of my wagon.
AnswerID: 648390
Follow Up By: Batt's - Thursday, Aug 07, 2025 at 14:15
Just saying that throws a curve ball into things and just complicates things unnecessarily 72- 120ah in a 24h period. I've never seen or read any info over the years from a 12v fridge manufacturer that claims such a large power consumption or even in 4wd magazines fridge comparison tests no matter how biased some people think they might be. If everyone followed that theory then no company would have ever sold a 100ah battery to someone who goes camping on the weekend.
Realistically with my experience during different times of the year a 100ah will give you a minimum of 2 days with room to spare.
FollowupID: 929671
Follow Up By: jeff r - Thursday, Aug 07, 2025 at 16:52
Thanks Macca, I am certainly doing away with the cig socket concept
FollowupID: 929674
Follow Up By: Member - McLaren3030 - Friday, Aug 08, 2025 at 08:20
Hi Batts,
The fridge manufacturers state what the power consumption is, the majority quote between 3 to 5 AmpHrs. Some will use less, depending on certain circumstances. However, using 3 to 5 AmpHrs as a guide, and multiplying by 24, gives you the total AmpHrs in a single day, (without charging of course).
FollowupID: 929686
Follow Up By: Allan B (Sunshine Coast) - Friday, Aug 08, 2025 at 09:20
Hi Macca,
Fridge manufacturers mostly use the same compressor and the same insulation so their published performance figures vary only by their honesty. Although they often only quote the instantaneous motor current as predicting the daily consumption varies greatly depending on ambient and fridge usage.
So their published figures are likely to be in Amps rather than Amphours. Then there is the duty cycle factor which typically has the fridge motor running for between 1/3 and 1/2 of the time. So the prediction now becomes 3-5 Amps multiplied by 1/3 to 1/2 duty cycle, multiplied by 24 hours to arrive at the daily Amphour consumption. What cannot be accounted for is the user behaviour with variations for fridge location, temperature setting, how often the fridge is opened, how many warm cans are loaded each day etc..
But as you say, it is a guide.
FollowupID: 929689
Follow Up By: Peter_n_Margaret - Friday, Aug 08, 2025 at 15:56
Allan, there is a bit more variation between manufacturers than that I reckon.
The same (Secop/Danfos) compressor can be run at different (or variable) speeds and that affects the efficiency and the energy requirements.
Don't confuse power and energy.
And insulation is a very big factor that the manufacturer can do well or do very badly. It is possible to halve the energy consumption of a commercially made RV fridge just by doing a better job with the insulation and without changing the power requirement at all.
FollowupID: 929692
Follow Up By: Allan B (Sunshine Coast) - Friday, Aug 08, 2025 at 16:44
Yes Peter, There is a rather wide range of fridge quality if you were to go to the more extremes of quality and price, but I was thinking of the average bloke buying the average fridge at the average price. You know, the sort of bloke that might be found on this forum. ….Blokes like me and Macca and Jeff for instance, not someone of extremes.
Actually, I thought that I did make mention of insulation but thank you for raising that.
But be assured, I would never confuse power and energy. I recognise them both and have little of either with this cold weather which however suits poorly performing fridges wonderfully.
Keep up the good work.
FollowupID: 929695
Follow Up By: Peter_n_Margaret - Friday, Aug 08, 2025 at 18:17
Allan, I certainly would not accuse you of mixing up power and energy (and the units that go with them), but sellers of this sort of stuff certainly do and it does not help their cause at all.
FollowupID: 929696
Follow Up By: Allan B (Sunshine Coast) - Friday, Aug 08, 2025 at 19:40
Which may be a good reason to disregard manufacturer's performance expressions and consider users recommendations in making a purchase choice.
FollowupID: 929698
Follow Up By: Peter_n_Margaret - Friday, Aug 08, 2025 at 20:39
Problem with that is that users typically only have useful experience with one example of a wide range of product and it will invariably get a glowing endorsement because few of us will admit to making a bad choice.
FollowupID: 929700
Follow Up By: Batt's - Friday, Aug 08, 2025 at 23:24
Macca I might have read it wrong and thought the amps was a typo as most people use ah to calculate power usage off a 12v battery for their fridge etc. I haven't actually seen it explained like that before.
FollowupID: 929702
Reply By: Member - Mark (Tamworth NSW) - Thursday, Aug 07, 2025 at 07:56
Go to the Pajero 4WD Club Forum, it is a very active website and do a search, there will be many similar posts there regarding 2nd batteries. Suggest your grandson becomes a member.
There's a specific folder/section for the NX model which ran from late 2014 to 2021 as well as a folder on Lithium batteries for camping .
https://www.pajeroforum.com.au/
My last Pajero was a 2014 NW, ran similar set up to your 80 series.
Based on my current experience with our 2021 Prado which some claim have a smart alternator, I wouldn't be so sure about not being able to use a simple VSR. But have a look at what's on the Pajero Forum. You will definitely need heavier wiring back to the Tub. with the VSR setup.
AnswerID: 648391
Follow Up By: jeff r - Thursday, Aug 07, 2025 at 17:07
Thats a good idea Mark I'll push him in that direction. He's going on a long learning curve.
FollowupID: 929677
Reply By: Member - Warren H - Thursday, Aug 07, 2025 at 13:47
Alternatively you could get a 'power station' that are portable and usually have an inverter, solar panel controller, usb, 12v power outlets etc. Probably still need a connection to the starter battery although if it's just for a few days an prior a/c charge and cigarette lighter to top up might be adequate.
NT Pajero
2007 Goldstream Crown
AnswerID: 648393
Follow Up By: jeff r - Thursday, Aug 07, 2025 at 16:56
Thanks warren, I have been eyeing off the power stations. it will probably be in the mix
FollowupID: 929675
Reply By: Gbc.. - Friday, Aug 08, 2025 at 12:23
I was forced into using the wife's forester for a trip or two when the ranger let us down, so we transplanted a 30l fridge and an optima battery into the back of it and plugged the battery into the 10a factory socket - I knew I was on a hiding to nothing and I wasn't disappointed haha. I was looking for 240v chargers every night.
My suggestion, grab a kings BattBox with a 100/120 ah Lifepo4 for $600/$700 odd. You need a feed wire from the start battery and your wiring is all done, along with feeds to fridges etc.
As for smart alternators, with the loads a 4wd usually runs they rarely drop below cutout point and if they do they are back over cut in threshold very quickly. My current mazda/isuzu and my last ranger both had smart alts. I didn't run an ignition feed on either and have not noticed any difference. Not hard to hook up ignition feed if you want to though.
AnswerID: 648398
Follow Up By: jeff r - Saturday, Aug 09, 2025 at 17:10
Thanks Gbc appreciate your thoughts
FollowupID: 929705
Reply By: Anthony P8 - Sunday, Aug 10, 2025 at 14:21
Hi Jeff.
Aside from all the debate, I am an electrician, retired (fitter, mechanic and auto qualified). You can get a cheap lithium (sealed) from someone like Kings, that goes behind the seat of the vehicle. I am not a fan of Kings, BUT, if on a budget, there is enough Youtube evidence of people supporting them, and when they break, Kings just replace them within warranty, no questions asked.
Sealed lithium is safe and fine behind a seat in the cabin.
One of the cheapest ways is a slimline Kings lithium, a cheap DCDC - run the positive through an ignition controlled relay to ensure the DCDC does not allow charging when the vehicle is off, and run an ignition trigger to the DCDC which overrides all the issues of a smart alternator. This ensures no issues when it comes to your starter battery.
Smart alternators are not really smart, just variable voltage. Alternators, period, are a very crude way to charge a battery.
Kings slimline lithium: $400 https://www.4wdsupacentre.com.au/batteries/lithium/100ah-ultra-slim-lithium-battery.html
iTech 25A DCDC: $250 https://itechworld.com.au/collections/dcdc-battery-chargers
A relay, some wire and ensure everything is fused individually, another $150.
That is an entry level, pretty solid, solution you can mount anywhere in your vehicle that will house it, approx $800 DIY.
AnswerID: 648404
Follow Up By: Batt's - Tuesday, Aug 12, 2025 at 14:04
I looked into the Kings etc slimline for my wife's ASX but you still need a shunt, charger and all the wiring then found a better solution but comes at a cost. There are slimline lithium batteries with a built-in charger so minimum wiring required which is handy and keeping track of it via Bluetooth is what Baintech have. We haven't bought one because there is not enough room in her car but they look like a good idea for a 4wd. LBS have 3 diff but battery sizes but I can't find info if they have Bluetooth or not so you can keep an eye on the battery. There are others that look like there just generic rebranded batteries.
We'll probably just get the 36ah Kings portable unit because we don't use the 30ltr fridge in her car a great deal just handy to be able to keep it running if needed out shopping for the day or overnight etc.
FollowupID: 929714
Reply By: Peter J4 - Monday, Aug 11, 2025 at 07:41
I recently was asked by my sister if i could help her set up a system in her late model Xtrail so she could travel along with our other sister in her little motorhome. They both have extensive experience of long 4wd trips with family in tow but now both are single so travelling together occasionally.
She was going to tent it and needed the ability to make a cuppa, cook and have a small fridge and camp lighting and charge phone and tablet.
As it was only going to be for a few 2-3 week trips a year and the occasional 2 or 3 day I was reluctant to spend the time and effort for a permanent vehicle based solution so after sitting down and discussing it with her she ended up with a "power station" which had a 120ah battery and was good for 2kw ouput, single induction cooktop, collapsable 1litre 240v jug and a rechargeable camplight.
After the first 2 week trip she was over the moon with how well it worked, they had a mix of free and powered van sites so she found that with the power station plugged into the 12v outlet in the car while travelling it easily kept up with the 40l fridge even when it was parked up while they did walks etc. Every few days they would get a powered site and she would fully charge the power station on mains and she reckoned the jug and induction cooktop took only a few percentage points off the capacity for each use.
Then to top it off she could use the power station at home in a blackout for the 24hrs the power was out after recent storms.
Yes it was a bit more expensive but if the vehicle installation of wiring etc had to be taken into account then it was good value.
AnswerID: 648406
Follow Up By: RMD - Wednesday, Aug 13, 2025 at 13:37
Peter j4
Which battery, inverter brand supplies 2000watts for an induction cook top? At 12 or maybe 13v is around 150 amp being sucked out of the battery. Nearly all BMS systems in batteries DON'T / aren't able to supply 150 amps discharge rate. They get a tad hot, if not frying quite soon!
A 2000 + watt & inverter in a Battery box is all it is.
They are not Power Stations , they don't generate power, only convert previously STORED energy. Power station was a deceptive term used by manufacturers to trick buyers!
FollowupID: 929719
Reply By: qldcamper - Monday, Aug 11, 2025 at 08:14
Jeff, time to start over and remember your KISS principles you mentioned.
Start at the end and work back from there.
Eliminate the biggest variables.
First is the battery, how long do you need it to last both short term and long term, is he going to drive short distances then stay put for several days, or just a couple of nights with long drives in between and how many years service would you be happy with?
Compromise is a big part of it, many forum experts have no idea and insist everything has to be theoretically perfect and try to convince you your outfit will be burned to the ground if you don't adhere to their advice to the word and argue tooth and nail if anyone dare disagree with their thoughts.
Will your grandson still own the car in 2 years, life gets in the way of plans at that age.
Sort out those details and choose a battery to suit.
A simple flooded battery and simple ignition controlled will work well enough in most cases but the forum experts will disagree. The battery will be operating in less than ideal parameters and might (probably will) need replacing every couple of years but you will be on your third battery and still be financially better off than if you try to set up a theoretically perfect lithium system that will last 3 times longer than the service life of the car.
Your 6 days into it and still reading people arguing about irrelivant details and other than confused you have got nowhere, wait till you ask how to actually install the hardware, still weeks worth of debates of every detail of every aspect of the install.
AnswerID: 648407
Follow Up By: Batt's - Tuesday, Aug 12, 2025 at 14:45
Just wondering how does the KISS principle works when possibly have to replace the battery every couple of years that's not a good compromise in anyone's eyes that's just adding to the confusion now.
A lead acid will be under the bonnet so probably giving advise that using insulation has been proven to extend the life of batteries in that situation would be handy to go with the KISS principle. There should be no need to have to replace it that often.
I've had a 2 diesel 60 series cruisers a TD5 disco and a petrol GQ over the years with an aux lead acid battery and they can be good up to 5yrs give or take because there are several variables. So yes it is a good idea but in no way believe you'll be up for a new battery that often unless you run it flat a lot.
As far as financial better of going by what qldcamper says then no you won't be. 100ah around $200 or so depending on quality which will make a difference that's going to add up over 10 yrs.
FollowupID: 929715
Follow Up By: qldcamper - Wednesday, Aug 13, 2025 at 11:58
As usual Batts, you have completely missed the point of my post but at least you have proven the point about forum experts.
FollowupID: 929716
Follow Up By: Batt's - Wednesday, Aug 13, 2025 at 15:52
I could be wrong but wasn't the main points the KISS principle, that it's ok to use a lead acid battery and also about you having a go at the people you call experts on this site ?
Not sure how I proved your point though I did agree with the use of a lead acid battery.
FollowupID: 929720
Follow Up By: qldcamper - Wednesday, Aug 13, 2025 at 16:24
Yes Batts kiss was his target and so was not investing un necessary quantities of money until there is a need.
Your knee jerk reaction was like i was saying he definatly won't get more than 2 years when my words were probably will.
Then you went on to answer your own arguement, best place for a LA battery is under the bonnet (less than ideal but possible), running it very low (very probable) and without knowing exactly, if the charge rate is lowish, low 13s the battery will not be operating from a fully charged state. Considering these facts 2 years before becoming unfit for this use a reasonable estimate. Comparing this to your 5 year life out of your batteries i would guess you treated them better than that.
Initial cost a cheap battery and 100 amp solenoid and a bit of cable. Mounting the battery is totally on him, I would never recomend any battery be in a passenger cabin.
As for my comments about forum experts, take that any way you want.
FollowupID: 929721
Follow Up By: Member - Bigfish - Friday, Aug 15, 2025 at 13:11
Very common now qldcamper to mount lithium po batteries in behind the second row seats of twin cabs and in rear wells of wagons now that many manufacturers are producing slimline lithium to do just that. No issues with fumes and easy, lightweight to mount. .
FollowupID: 929723
Follow Up By: qldcamper - Friday, Aug 15, 2025 at 13:30
Just cause it's common doesn't make it any less of a risk. Lots of people carry LPG bottles in the passenger compartment too and get away with it.
Like I say,I would never recomend it, you can do whatever you want.
FollowupID: 929724
Follow Up By: Member - Bigfish - Saturday, Aug 16, 2025 at 19:00
And yet we all carry a mobile phone that has Lithium phosphate batteries in our car everyday. I,ve never met anyone who carries an LPG bottle in a passenger car. (apart from getting refilled and even then they are normally in the boot. Petrol vehicles have far more accidents involving fire than any ev cars based on a 5 ratio of vehicles.
FollowupID: 929729
Follow Up By: Member - Bigfish - Saturday, Aug 16, 2025 at 19:03
And yet we all carry a mobile phone that has Lithium phosphate batteries in our car everyday. I,ve never met anyone who carries an LPG bottle in a passenger car. (apart from getting refilled) and even then they are normally in the boot. Petrol vehicles have far more accidents involving fire than any ev cars based on a 5 ratio of vehicles. Electric cars, of which there are now more than 40 million worldwide, are considered by EV Firesafe to be between 20 to 80 times less likely to catch fire than an internal combustion-engined (ICE) vehicle. EV ,S use the batteries as what we use for an auxillary.
FollowupID: 929730
Follow Up By: qldcamper - Sunday, Aug 17, 2025 at 06:49
So what's your point bigfish, are you saying that because my opinion differs from yours mine must be wrong?
So your saying just because you have never met anyone that carries a LPG cylinder in the back of a wagon nobody does it? Just look at the amount of 4WD wagons at camp sites with stoves and BBQs set up, how did they get their LPG there?
I don't really care what you think and who you have met, my opinion is my opinion based on many years of experience and professional training, not just what I have read in forums and quoting statistics and not really having any idea of the risks involved. How can you minimise the risks if you don't understand what they are in the first place? If you wish to rely on ignorance and set up your vehicles without being aware of the risks involved please carry on but stop kidding yourself that you know more than the real career professionals.
Again you are helping prove my theory on forum experts. Google is not a reliable source of technical information.
You do not have to agree with my opinions but if you wish to contest them please have the decency to actually know what you are talking about, not just paraphrase or copy and past from unreliable sources.
FollowupID: 929731
Follow Up By: Member - McLaren3030 - Sunday, Aug 17, 2025 at 07:51
Hi Bigfish,
I was under the impression that the batteries in mobile phones and tablets are Lithium Ion, not Lithium Iron Phosphate.
FollowupID: 929733
Follow Up By: Member - Ups and Downs - Sunday, Aug 17, 2025 at 09:22
I must be lucky after 25years of having a gas cylinder (or two) in the back of a Troop Carrier without blowing myself up.
Of course I made sure that they were totally turned off. That is, a double check every time they were stowed.
I took the same precautions that apply to any other hazardous situations.
Safety awareness is good, essentail even, however I think it is becoming a 'God' to be worshipped by many.
(Not pointing the finger at those here)
FollowupID: 929734
Follow Up By: qldcamper - Sunday, Aug 17, 2025 at 09:47
At least you realise that luck has been on your side.
My first serious travelling outfit was an enclosed 7 by 4 trailer with an alloy lid tightly sealed to avoid dust ingress with one gas bottle mounted outside behind the LH guard. I thought i might need more gas for an extended trip so took a smaller brand new 2kg bottle which I stowed inside the trailer.
Travelling on a sunny winter day, first stop opening the trailer strongly smelled LPG, and found the safety valve on the new cylinder had failed hissing loud enough to hear.
I think that day was the luckiest day of our lives, I don't think we would have faired very well if any form of ignition changed our luck.
Hopfully your luck will stay on the up side and never turn down.
FollowupID: 929735
Follow Up By: Allan B (Sunshine Coast) - Sunday, Aug 17, 2025 at 11:36
QC, It is possible that the temperature within the trailer was high enough to raise the LPG pressure to open the vent valve.
LPG is potent stuff. I have built and maintained LPG plants and know the risks. The biggest risk is not within a person's knowledge…… it is what they don't know.
I don't even like putting a LPG bottle in the boot to bring it home from the servo. There is a light switch in there that operates when the boot is opened!
FollowupID: 929736
Follow Up By: Member - Bigfish - Sunday, Aug 17, 2025 at 11:54
Thankyou qldcamper.....your opinion as a forum expert has been duly noted..
FollowupID: 929737
Follow Up By: Member - Bigfish - Sunday, Aug 17, 2025 at 11:59
McLaren3030...yes you are correct. Majority of mobiles are lithium ion or a polymer. Not as stable as the phosphate model battery but hold more energy for a given size...hence why they are used in smaller electronic gear.
FollowupID: 929738
Follow Up By: qldcamper - Sunday, Aug 17, 2025 at 13:01
Very likley Allan but it didn't seem very hot at the time. I would imagine an almost empty bottle still retaining a small amount of liquid gas would get just as hot fairly quickly in direct sunlight on a summers day. Whatever the reason we were very lucky.
FollowupID: 929739
Follow Up By: Allan B (Sunshine Coast) - Sunday, Aug 17, 2025 at 16:20
Agreed, The pressure relief valves are set well above the normal working pressure of the cylinders even if in direct sunlight but I was suggesting that the cylinder pressure may have risen sufficiently to cause the valve to leak a little. Pure conjecture I know, but you did say that you observed a venting and I am saying that it may have been premature. (faulty).
Therein lies the issue with LPG. It is all very good when everything works OK but is a powerful risk if something goes wrong. In industry, we design to allow for such events to be managed safely….. like not having LPG in confined locations.
FollowupID: 929740
Reply By: Member - nick boab - Friday, Aug 15, 2025 at 08:29
Have a crack...
AnswerID: 648416
Follow Up By: Allan B (Sunshine Coast) - Friday, Aug 15, 2025 at 12:21
I don't understand why that bloke is feeding his Bluetti from the car battery via a DC-DC module.
I believed that function was already incorporated within the Bluetti as evidenced by the instruction book below:
His whole procedure seems rather complicated.
FollowupID: 929722
Follow Up By: Kenell - Friday, Aug 15, 2025 at 16:48
Allan, the cable referred to in your attached diagram is the cig lighter cable connecting to the cig lighter socket. Bit confusing I agree but that is what they mean. For maximum charging from the DC circuitry the DCDC option is required at around $380 as I recall. The "Have a Crack" link highlights the simplicity of the installation which effectively renders the cig lighter in your diagram redundant.
Kenell
FollowupID: 929726
Reply By: Kenell - Friday, Aug 15, 2025 at 09:41
I have resisted buying into this thread as my recent post - 150993 - addressed the alternative that has now found its way into this post. The "Have A Crack" YouTube that has just been linked to this thread follows approximately what I did a month or so ago. I went for a slightly bigger unit.
It is apparent now that second batteries under the bonnet are a thing of the past. Lithium Iron Phosphate batteries are improving with technology and offer a viable alternative. The Bluetti in the video is not in the conventional sense a "Power Station" nor are they merely a "battery in a box". In part my thread highlighted that "we" need to remove the blinkers and at least consider the "power station" as an option.
When I purchased I was not particularly constrained by price although I was weighing up cost and efficiency comparisons before ultimately making the decision to go with the Bluetti power station. I chose not to install the DCDC although I have linked it to the alternator. It is now apparent I don't need the DCDC as the little bit of charge I get from the alternator as we drive is enough to keep the unit charged. The fridge (a Dometic CFX 2-57) is apparently very efficient and doesn't tax the power station much. I have charged it only once via a 240v AC power cable when the unit got down to 35%. It recharged to 99% in under an hour.
I am confident that the Bluetti (180P) will keep the fridge running off grid for 3-4 days with no charging even in warmer months. I have a 1Kva Honda petrol generator that I carry when off grid camping anyway so that should charge it up before anyone notices the purr (it is very quiet).
I don't like the cig lighter plugs but since both the fridge and power station are strapped to the same plane and it is a semi bayonet fit I doubt it will be an issue. I haven't tried the induction kettle test they claim but I have 5 years of warranted performance so I presume they know it can work.
Its not for everyone and every circumstance but it is an alternative. Oh and before deciding - shop around the prices can vary a lot. I paid $1288 even though the manufacturer's website advertised circa $1400.
Kenell
AnswerID: 648417
