Temporary power
Submitted: Tuesday, Sep 16, 2025 at 07:59
ThreadID: 151573 Views:7391 Replies:15 FollowUps:37
Where I live has regular power outages and during one in 150 year flood events which there have been several in the past 20 years has been out up to 7 days.
There are a lot of very capable and expensive travelling set ups capable of reasonable 240v output.
I have 2 large fridge freezers that I'd like to be able to rotate when such events occour but they are at opposite ends of the house, one right next to my camper and fuse box but the other not and it's power point is inaccessible so it would be ideal if I could get a sparky to sort out an input and C/O switch to feed just the fridge GPOs and light circuits.
Has anyone gone down this track before and found out the legalities.
Don't really want to go down the solar battery road as it would never pay for itself in my lifetime, would rather spend the dollars making my travelling easier and it can double as back up power.
I'm pretty sure there are strict regulations around solar batteries so I assume it might not be as easy as it sounds keeping the insurance companies on side.
Reply By: Member - Bigfish - Tuesday, Sep 16, 2025 at 08:21
Get yourself a 3-5kva generator and a sparky can certainly rig up a change over switch in your meter box for when you have blackouts. I,ve had the same set up for years when I lived in Gove. Have a set up now I,m in Far North Queensland. I say 3-5 kva so realistically you could run your house apart from aircons. If you have no power for 7 days then it would be nice to know that all the fans, lights, tvs. etc. can still be used. I use a 3kva for my house as well as a spare 1kva camper unit. Having 400 a/h of lithium also means I dont run the gennies much..
AnswerID: 648513
Follow Up By: qldcamper - Tuesday, Sep 16, 2025 at 08:41
Pretty much h what I want to do only an inverter rather than genset. Its the legality and safety of having it mobile and not perminant is the question I'm asking.
FollowupID: 929882
Follow Up By: Member - Bigfish - Tuesday, Sep 16, 2025 at 15:36
The set ups are perfectly legal if done by a licenced electrician. Safety is not an issue. Its a simple job to do and there are even kits available on the web. All legal and safe. As I said I,ve had setup like this years and all good. I test run mine twice a year and run the gennies every 3 months.
FollowupID: 929900
Reply By: Member - LeighW - Tuesday, Sep 16, 2025 at 08:29
I assume you mean you intend to put sufficient solar and battery a van to cover the consumption of the two fridges and lights in your house when there's a blackout?
I'm not an electrician but I don't see the chenage over switch being an issue as not much difference either supply the fridges and lights from a generator or van assuming both are wired for such by an electrician.
You would need to work out the battery capacity required keeping in mind you would want to allow for 2 or 3 days in a row unless your in a sunny area and you might be surprised how much battery and solar you'll need on the van to keep those two fridges running.
AnswerID: 648516
Follow Up By: qldcamper - Tuesday, Sep 16, 2025 at 08:43
Leigh i havent asked about the logistics of the system, I'm asking about the legalities of such a system.
I'm pretty sure captian obvious will be along shortly with a couple of pages of obvious details that a highschool kid could work out that has nothing to do with what I'm asking.
FollowupID: 929883
Reply By: Member - Jim S1 - Tuesday, Sep 16, 2025 at 09:13
Is it worth asking your insurance company ?
Of course, getting to talk to anybody who has the faintest idea what you are talking about might be a problem.
Jim
AnswerID: 648518
Follow Up By: qldcamper - Tuesday, Sep 16, 2025 at 09:24
You right Jim, only someone that's actually gone down that track before me or happens to have a copy of the latest standard could shed light on it so to speak.
I could have googled it but I have no faith in Google searches as the results could have been written by any idiot.
Pretty sure no insurance will cover loss caused by dodgy electrical installations.
FollowupID: 929886
Reply By: Loddo48 - Tuesday, Sep 16, 2025 at 11:08
Running your house off the caravan set up is no different to having a generator connected to your switch board via a correctly installed inlet and change over switch. It will stilled be classed as an external AC supply regardless, if it is from a generator or a battery supplied inverter. Your electrician will be able to do the correct installation of inlet and change over switch which will have to comply with the standards.
AnswerID: 648519
Follow Up By: qldcamper - Tuesday, Sep 16, 2025 at 11:44
Thanks Loddo,
What you are saying is pretty obvious as far as will it work. The question is, is it safe and compliant.
I thought I'd run it by the group in the hope that someone has recently been down the sparky road. As you are aware there are many different standards and none of them are in the public domain and sparkys I have discussed it with only pay for the standards that is relivant to the sort of work they take on so cant give a yes or no. Powering a house from a perminantly hard-wired device like a genset or inverter is different to a removable device (standards wise).
Also the fact that I only want 2 cct bkrs supplied by it and the rest of the house will remain connected to the grid is another grey area they don't want to put their lisense number to.
FollowupID: 929894
Follow Up By: Member - LeighW - Tuesday, Sep 16, 2025 at 12:42
In my home solar battery setup the inverter has an EPS output that runs the kitchen GPO's and all the house lighting. Under normal conditions power comes into the inverter via the mains and powers the EPS circuit. If the power fails the inverter changes the circuit over to run of its output. Similary to want you want but in your case a manual change over to the caravan inverter whereas in my case it's automatic. The electrician suggested the he install a contactor that justs swaps the whole house over to the inverters EPS on mains fail but I just went with the kitchen an lights. If needed down the track he can add a manual changeover switch for the rest of the circuits if required.
You just need to find an electrician that is familar with such a setup.
FollowupID: 929898
Reply By: Loddo48 - Tuesday, Sep 16, 2025 at 11:58
qldcamper
To answer you reply to me , Having worked as an electrical contractor for 50yrs I have a fairly good knowledge of what is required to satisfy the current standards regarding the installation of an external power source that is connected to your house switch board via an inlet socket and change over switch. I know that QLD has some strange idea regarding electrical installations but if the inlet and change over switch is installed as per the standards then it should not be a problem . Your electrician SHOULD have a copy of AS/NZS 3000-2018 and the requirement are in it .
AnswerID: 648520
Follow Up By: qldcamper - Tuesday, Sep 16, 2025 at 12:07
Thanks Loddo, you should have stated you actually know what your on about that sets you above those that just do a google search and copy and paste that this group has plenty of.
So ultimately your saying what I am trying to achieve is actually achievable legally?
Just didn't want to waste a lot of my time and that of those I contact if it wasn't viable.
FollowupID: 929897
Reply By: Loddo48 - Tuesday, Sep 16, 2025 at 12:16
Many electricians will state that things can't be done because they will not think outside the square or their comfort zone, and are not willing to think about how the job can be completed and still meet the standard requirements which are the minimum that we have to work to.
AnswerID: 648521
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Sep 17, 2025 at 11:19
I think that "Many electricians will state that things can't be done" because they anticipate getting involved in a "Can of Worms" which will cause them pain and a less-than-happy customer. And I can't really blame them for that.
FollowupID: 929903
Reply By: Kenell - Tuesday, Sep 16, 2025 at 19:43
Qldcamper, I am not qualified to comment on the electrical aspects of your posted request. I can possibly help with the insurance position however. I can only speak generally as I don't know your specific insurance policy. In my experience policies cover the circumstance you are proposing providing it is done in accordance with the legal requirements and has been signed off by a qualified electrician. (So if the ship hits the span they have someone to go after)
There are two aspects to look at when considering the insurance cover. First - were you asked at the outset or most recent renewal about temporary / alternative power supplies? I've never heard of that happening but it might be sneaking in with the increasing of disasters. Secondly, is there any specific reference / exclusion in the PDS?
Good luck with it.
AnswerID: 648522
Reply By: 2517. - Tuesday, Sep 16, 2025 at 20:38
I would put your question to ChatGPT,you may be surprised at the answer,it has solved some technical problems for me.Just give it all the information.
AnswerID: 648523
Follow Up By: qldcamper - Wednesday, Sep 17, 2025 at 05:45
Thanks for the suggestion but I have the answer to the question i asked from a real person with a career of experience in the field.
FollowupID: 929901
Reply By: Member - nick boab - Wednesday, Sep 17, 2025 at 02:44
Qld : This conundrum appears to have a "elephant in the room" if I understand your question correct, you want to run your house freezers and lights etc off your camper in the event of a power out ?? How is that goingwork ?
HAHA :)))
AnswerID: 648524
Follow Up By: qldcamper - Wednesday, Sep 17, 2025 at 05:49
Quite easy Nick, I just have to install kero fridges and lamps then have a 12v to kerosene converter installed in the fuse box of the house. Just a matter of logic.
FollowupID: 929902
Follow Up By: Member - nick boab - Wednesday, Sep 17, 2025 at 17:21
Haha:)))))
FollowupID: 929905
Follow Up By: RMD - Saturday, Sep 20, 2025 at 15:21
QLD
I recommend AVTUR which is a higher grade of KERO and will cover the distance far better than the parts wash grade! It might even make the fridges fly!
With all those power outages, You don't live near "BOWEN" do you?
FollowupID: 929927
Follow Up By: qldcamper - Saturday, Sep 20, 2025 at 15:30
Good point RMD. AVTUR is a term I havent heard since my apprenticeship days which I served with an ex RAAF sparky. I just assumed it was military speak for Jet A1. Should definatly make the fridges run smoother.
FollowupID: 929928
Follow Up By: Member - nick boab - Saturday, Sep 20, 2025 at 21:15
Formally qld I thought you might be hedging towards and upgrades!! from an unnamed company with a bank of solar panels and lithium batteries, haha:)))
FollowupID: 929940
Reply By: Allan B (Sunshine Coast) - Wednesday, Sep 17, 2025 at 10:24
Hi QC,
As you say, " it might not be as easy as it sounds".
I know that you say "Its the legality and safety of having it mobile and not perminant is the question I'm asking". To have it "mobile" I take it that you wish to use the power source of your travelling rig and its solar and batteries. Well that can be achieved but to be legal and safe will invoke the requirements of government regulations and two Standards…. AS/NZS 3000 Wiring Rules and AS/NZS 3001.2 Connectable Electrical Installations. You would need an electrical contractor familiar with both and capable of carrying out this work to satisfy the electrical authority and insurer.
I do have views of the feasibility of your proposal but I understand that you are not asking that.
AnswerID: 648528
Reply By: Batt's - Friday, Sep 19, 2025 at 08:30
Can't see any issue legally if you get an electrician to install a switch and socket so you can use an alternative power source wether it's from a battery or genset. 15amp is minimal for a caravan to legally plug into. If you have house insurance ask them before you do something.
Your using batteries so no poisonous fumes and no legal distance specified that the van needs to be from the dwelling unless your insurance has something written there. Also as long as the caravans electrics are legal, up to standards all good and the meter box on the house is up to spec.
We had to get our meter box upgraded to get ours set up in 2013.
AnswerID: 648533
Follow Up By: qldcamper - Friday, Sep 19, 2025 at 09:17
Batts, my concern was the fact that the house will not be completely isolated from the grid just the two breakers switching from one source to another and will the RCDs operate correctly and other technicalities that i dont pretend to understand like how common neutrals and earth's fit in to the standards. I don't really need or wish to understand, hence the reason I asked for a simple yes or no answer which I have basically got.
FollowupID: 929914
Follow Up By: Loddo48 - Saturday, Sep 20, 2025 at 18:54
qldcamper, once the C/O switch is installed in your switch board as per the standard there is no way that you can send power back into the grid, your rcd's will still work as the MEN and earthing system has to remain intact and not disconnected. So find a sparky that knows how to read the standard and do the install .
FollowupID: 929933
Follow Up By: qldcamper - Saturday, Sep 20, 2025 at 19:11
Ok Loddo, this reply from you confirms you do not understand what I am actually asking, your assuming I just need the run of the mill co switch from mains to alternative power source for the entire house.
FollowupID: 929935
Follow Up By: Loddo48 - Saturday, Sep 20, 2025 at 20:02
There you go assuming that I am assuming that you want to do the whole house ,yes I can read what you posted. You can power circuits you like when using a changeover switch, it is called essential and non-essential supplies, so you can pick any circuit you wish to power up via your external supply. If I knew that you were going to question my electrical qualifications and my understanding of what you were trying to achieve, I would not have responded to your question and let you work, it out for yourself.
FollowupID: 929938
Follow Up By: qldcamper - Saturday, Sep 20, 2025 at 20:44
Appriciate your input.
FollowupID: 929939
Reply By: PeterInSa - Saturday, Sep 20, 2025 at 11:05
A friend uses and RVD device infront of his RCD when getting power from his generator or inverter to power his van with 240vac.
If I was powering part of the house I would be looking at installing an RVD in the vans inverter circuit prior to powering the house.
https://www.rvdsafe.com.au/
https://www.rvdsafe.com.au/shop/
The other area that I would looking further at is the earthing. I understand that some Inverters have an earth connection others do not. I think your inverter may need an earth connection and an earth stake ( to link the Caravan frame (earth) to the house earth).
See attached 7.5 Mobile Installs.
https://www.victronenergy.com/media/pg/The_Wiring_Unlimited_book/en/ground,-earth-and-electrical-safety.html
Note am not an electrician, just looked into a DIY Home Solar System.
RVD from Mr Google:
An RVD (Residual Voltage Device) is an electrical safety device that monitors and detects a rise in voltage on the earth (or frame) of a system, such as a caravan or boat. Unlike a conventional RCD (Residual Current Device), which detects imbalances in current, an RVD senses dangerous voltage on the earth wire, providing an additional layer of safety, especially in isolated systems like those powered by generators or inverters, where standard RCDs are ineffective. When the detected voltage exceeds a set point (e.g., 43V), the RVD triggers the connected RCD/RCBO to rapidly isolate the power, preventing electric shock and protecting equipment.
How it works
• Voltage detection:
An RVD continuously monitors the voltage on the earth connection or frame of the system.
• Rapid Isolation:
If the earth voltage rises above a safe threshold, the RVD triggers the associated RCD/RCBO to shut off the power to the circuit within milliseconds.
• Enhanced Protection:
It provides protection against insulation breakdown, even in isolated power systems where a standard earth connection is not available for a traditional RCD to function.
When to use an RVD
• Isolated Power Systems:
RVDs are crucial for vehicles, caravans, boats, and other applications that use isolated power sources like inverters or generators.
• High-Impedance Environments:
They work in systems where a standard earth connection might be compromised or where high-impedance is a concern, which can prevent RCDs from tripping effectively.
• As a Complementary Safety Device:
An RVD enhances safety by working alongside an RCD/RCBO, providing an additional and different fault detection mechanism.
Benefits
• Personnel Protection:
It prevents electric shock by detecting dangerous voltage on the vehicle's frame or chassis before it can harm someone.
• Equipment Protection:
It safeguards sensitive equipment from electrical damage due to insulation failures or voltage leakage.
• Improved Safety with Generators/Inverters:
RVDs are essential for systems that use generators or inverters, where a conventional earth system doesn't exist to trigger an RCD.
AnswerID: 648537
Follow Up By: qldcamper - Saturday, Sep 20, 2025 at 11:11
Thanks Peter but as I said I am not interested in learning about it as I will never need to get involved in it, that's what sparkys get paid for.
FollowupID: 929925
Follow Up By: Zippo - Saturday, Sep 20, 2025 at 16:00
"An RVD continuously monitors the voltage on the earth connection or frame of the system. "
Voltage with respect to what reference?
FollowupID: 929929
Follow Up By: Loddo48 - Saturday, Sep 20, 2025 at 18:34
Installing an RCBO/RVD in the caravan supply to feed the house will not work , the RCBO/RVD will see the MEN in the switch board which you can't disconnect when installing a changeover switch as it sees this as a fault. When the changeover switch is installed as per the standard's the earthing of all equipment is not comprised and must remain intact as well as the MEN connection.
FollowupID: 929931
Reply By: PeterInSa - Saturday, Sep 20, 2025 at 11:14
I think it will be a rare Sparkie that will get involved and even then it will be a nightmare if there is some type of accident, with insurance companies involved.
AnswerID: 648538
Follow Up By: qldcamper - Saturday, Sep 20, 2025 at 11:20
That i will find out once i take care of a couple of other more pressing of life's little curve balls.
FollowupID: 929926
Follow Up By: Loddo48 - Saturday, Sep 20, 2025 at 18:47
Regarding a sparky not getting involved in a simple installation of a changeover switch, I would have to ask what sort of sparky he is, the work to do that install is all set out in a book that he must work to, that being the AS/NZS3000-2018. The installation of a C/O switch is straight forward and is a common installation carried out by sparkies that know what is required. I still don't understand why an insurance company would have a problem with one correctly installed on a switch board.
FollowupID: 929932
Follow Up By: qldcamper - Saturday, Sep 20, 2025 at 19:05
Loddo, I'm starting to think you don't actually understand what I am trying to achieve.
As is always the case the arguing between people that didn't really need to get involved undermining the advice of those that do know makes the entire thread as worthless as a c^#t full of cold water.
FollowupID: 929934
Follow Up By: Loddo48 - Saturday, Sep 20, 2025 at 19:18
qldcamper, if I am correct , you want to set up your camper so it can feed you fridges in the house , is that correct? If that is the case everything I have posted is the correct way to connect it up.. It is a shame that you asked a question and I replied with the correct information and now you are questioning the information I have gave you. So please tell me what part of the question I have misunderstood,
FollowupID: 929936
Follow Up By: qldcamper - Saturday, Sep 20, 2025 at 19:44
Loddo, I'm was quite happy with your reply until others threw their two bobs worth in and confused things.
You are correct that I wish to power my household fridges that are on a devoted RCD, and lighting RCD from an alternative non perminant power source via a manual c/o switch. However the rest of the GPO RCDs and all the others for that matter remain on the main switch that can remain turned on in the absence of grid power or not.
Remember my question is not if this achievable or not but can it be done within the standards and remain legal but above all safe.
Loddo, I welcome your reply as this was an answer to your question, but to others following, unless your a lisensed contractor with a copy of the current standard please refrain from complicating matters.
FollowupID: 929937
Reply By: Peter_n_Margaret - Saturday, Sep 20, 2025 at 15:09
Why not just run an extension cord from the camper output to the fridge/freezer and leave the house wiring alone.
KISS.
AnswerID: 648539
Follow Up By: RMD - Sunday, Sep 21, 2025 at 14:25
Peter,
EXACTLY!
Why is it not considered to run the LEAD, & the freezer which cannot be moved to access the PLUG is a LIABILITY and will be moved when the freezer fails. The Wheel or LARGE DOWEL was invented to move stuff. A crowbar will assist the move.
I run my fridge off a LONG LEAD for over 4 years and a Microwave too. Batteries and inverter, just not in a camper though.
A fridge or freezer only demands at startup, around 800w and settles to 90 or less almost instantly. Why have changeover switches and complication and cost and tradies etc.
Moving the camper might be something not considered, it has wheels I presume!
I do not understand why people won't act if it won't pay them back in their lifetime. No Vehicle ever does, Why does a battery/Inverter have to? Isn't the whole idea to prevent LOSS in freezers and cater for emergencies or be used everyday.
FollowupID: 929945
Follow Up By: qldcamper - Sunday, Sep 21, 2025 at 15:09
And there he is, captain obvious.
You couldn't resist could you RMD.
It must be a real burden going through life thinking your smarter than everyone else.
My question was about the legality, not for suggestions of simple alternatives that anyone with any degree of intelligence would have assumed i had already written off as not feasible. As I put in my OP leads are not an option, I fail to see why I should have to argue the point with someone that has absolutly no idea what my set up is.
I have given you the benefit of doubt before but not this time, you have just joined Peter on my list of people not worth wasting time interacting with so in future please don't take part in any of my conversations and I won't yours.
FollowupID: 929946
Follow Up By: RMD - Monday, Sep 22, 2025 at 13:27
QLD
NOWHERE in the POST do you say YOU DON'T want to USE A LEAD. "NOWHERE". SO NOW CLAIMING THAT, IS A BIT OFF. It is YOU who claim the HIGH GROUND, Peter and Myself simply give an ALTERNATIVE you NOW say you don't want to use when a BOWEN EVENT happens. Don't CHANGE your STORY to suit responses you don't want. It does make us doubt your integrity. We do not need to know your system and CANNOT SEE HOW the use of a simple LEAD is NOT FEASIBLE. It is OK for emergencies for a LOT OF PEOPLE in such circumstances.
You could, before ever posting here, go an arrange a system with a SPARKY/ELECTRICIAN who wants to follow your directions! WH Y ask this forum if you cannot bear to read something you suddenly and unexpectedly don't agree with as you change your story?
Claiming we think we are smarter that others is VERY SILLY and a bit NAIVE and points to your unwillingness to accept anything. SOLDIER ON SON!
PS, commenting allows many readers to decide what they might do, so trying to stop responses deprives others from information which they may be able to use!
FollowupID: 929951
Follow Up By: Member - LeighW - Tuesday, Sep 23, 2025 at 08:30
OP did write he requirement was:
"to feed just the fridge GPOs and light circuits"
Even if he was happy to use power leads he is not going to be able to supply the light circuits
with them!
But as he also wrote he has the answer he required so maybe it is time the thread was locked as its just degenerating into the usually electrical thread noise.
FollowupID: 929954
Follow Up By: Batt's - Thursday, Sep 25, 2025 at 08:12
Before I got a switch wired into my meter box my neighbour and I both used his 5kva generator for power outages to run our fridges. I used a 15amp heavy duty lead same thing can be done from a van a power board with 2 leads run to 2 fridges easy.
FollowupID: 929961
Reply By: Allan B (Sunshine Coast) - Sunday, Sep 21, 2025 at 09:11
Hi Loddo,
As a new contributor to this forum you will not be familiar with the challenges to your expertise. No matter your qualifications or experience you will not be accepted on face value and will be involved in all manner of argument and defence. The world seems to abound with people who consider they are competent at electrical matters. Cope with them as you see fit.
p.s. I am also a sparky. sigh!
AnswerID: 648540
Follow Up By: qldcamper - Sunday, Sep 21, 2025 at 09:58
Goodmorning Allan,
Loddo answered my question very early in this thread but other members did the usual thing displaying their google expertise to confuse matters, for some reason they just can't resist.
This forum would be so much better if the OP could turn off comments once the desired information has been put forward.
I imagine Loddo and yourself to be much like me, if a subject comes up that I can not help with drawing on my own knowlege, training and experience I just don't participate. If I need to google something to participate in a conversation then I consider myself unqualified to answer a question, if i don't know, I don't know.
If tradies with a career of experience in a specialised field make a comment that is in their field then it is extreemly likley the comment is correct but many here see it as a challenge.
FollowupID: 929941
Follow Up By: Allan B (Sunshine Coast) - Sunday, Sep 21, 2025 at 11:45
Don’t be too hard on them QC they just want to help and it does add some “colour’ to the thread. Just pick out the good bits.
FollowupID: 929942
Follow Up By: qldcamper - Sunday, Sep 21, 2025 at 12:35
Can you imagine sitting round a camp fire with this lot, what the conversation would be like in real time without the opertunity to consult AI, or even worse, with no internet reception?
FollowupID: 929943
Follow Up By: Batt's - Sunday, Sep 21, 2025 at 13:15
The most annoying ones around the camp fire are those that ask for help and ideas, then question and dismiss them even from qualified people so did they really need help in the first place or are they just starting up useless camp fire chat.
FollowupID: 929944
Follow Up By: RMD - Thursday, Sep 25, 2025 at 14:42
batts
And change their story as they go, so they can reject what they are being told, because it doesn't suit the narrative .
FollowupID: 929963
