Roof Air Conditioners
Submitted: Friday, Nov 28, 2025 at 09:13
ThreadID: 151912 Views:2084 Replies:5 FollowUps:4
Hello,
The Air Command A/C unit on my caravan has died and I have gotten 2 prices for new units, 1st one is a Mycoolman (which I think is made by Truma ) and the 2nd is a Dometic Freshjet 7 series Lite , the price difference between the 2 quotes is well in excess of a $1K (Mycoolman being the cheapest )
I would like any feedback for personal experiences with these 2 brands before I make a decision which one to buy, some of the reviews I've read on the Dometic units haven't been all that flattering.
Thanks in advance
Reply By: Peter_n_Margaret - Friday, Nov 28, 2025 at 10:42
I am building an off grid all electric motorhome. I am making provision for a future A/C. It will be a small domestic split.
The modern small splits are a world away from traditional rooftop RV units....
Cheaper, MUCH MUCH more efficient and more versatile in their installation options.
If you can, I suggest you seriously consider going that way.
AnswerID: 648723
Follow Up By: Puttingdave00 - Friday, Nov 28, 2025 at 11:18
Thanks for the advice, I haven't made a decision one way or the other.
Dave
FollowupID: 930211
Reply By: Briste - Saturday, Nov 29, 2025 at 10:00
The Dometic Harrier Lite atop my Karavan lost its gas twice. On the second occasion my fridgie couldn't find the leak. It was out of manufacturer's warranty, but only four years old. I bit the bullet and replaced it with a Freshjet 7 Lite, since it was going to be a simple, quick swap. An expensive excercise, but so far I'm happy with it. It's much quieter and more efficient than the Harrier, being an inverter model. Several other owners who have trodden the same path seem to agree.
My fridgie cautions that none of these units are really designed for rough roads, and that's my main concern. He showed me inside my old unit as to why. Too much rigid piping instead of flexible, pressure-rated hose. Once out of warranty there are mods possible to improve the resiliance of such rooftop a/c units, so I'm told.
I can't comment on the MyCoolMan unit, other than to note that Kimberley have swapped to it. I was told by the head tech that the change was made because of supply issues. I see that it's $600 cheaper at Caravans Plus.
AnswerID: 648724
Follow Up By: Member - Bigfish - Sunday, Nov 30, 2025 at 07:17
You can buy the high pressure, flexible tubing for split systems in a van. Mat pulled his roof top air con off and put a split system on. Reckons the difference is like night and day. I know he had flexible pipes installed even though his van does not go offroad.
FollowupID: 930219
Reply By: Puttingdave00 - Saturday, Nov 29, 2025 at 12:48
Thanks for the reply, I'm leaning towards the Mycoolman as it is $1400 cheaper [installed] by I think the local agent here,
[ Jayco dealer] thought I was going to sign up on the spot for a new Dometic, isn't the internet wonderful to be able to compare prices.
AnswerID: 648725
Reply By: Batt's - Wednesday, Dec 03, 2025 at 03:41
Out of interest anyone had a 12v roof top I found them a while ago thought it would be good when off grid camping in a van. There are some videos on youtube of Americans using and installing them.
https://outequippro.com/products/top-mounted-rv-air-conditioner-with-1-indoor-unit-and-1-outdoor-unit-12v
AnswerID: 648735
Follow Up By: Allan B (Sunshine Coast) - Wednesday, Dec 03, 2025 at 10:47
Batt's, You will need a pretty decent battery system for a 12vdc aircon. Or if you were to run a 230vac aircon via an inverter.
Some of the Americans carry 800Ah of batteries! And two alternators under the bonnet.
FollowupID: 930242
Follow Up By: Batt's - Wednesday, Dec 03, 2025 at 16:23
Yes just planning ahead it would be good to have options for overnight stops etc when we get our next van that's if it has the room to fit a 12v unit as well as keeping the 240v A/C for when in van parks etc. I was looking at a minimum of 1.2kw of batteries for eg to cope with it when needed plus the fridge and lights etc. Have to see how much solar we can fit though it won't supply enough which is ok.
I already have a 2.4kva generator for a backup for longer stays that we currently use on the house for blackouts.
Most of the time we just need to upgrade our alternator which is less complex than trying to fit a 2nd one.
FollowupID: 930251
Reply By: Peter_n_Margaret - Wednesday, Dec 03, 2025 at 18:36
COP and EER
When comparing air conditioners, the energy efficiencies are described as COP (Coefficient Of Performance ) for heating and EER (Energy Efficiency Ratio) for cooling.
They describe energy IN compared with energy OUT. In modern inverter units, ratios like 4 and 5 are now common. 2 was typical not long ago meaning that they can now use HALF the power that they used to for the same effect.
If they don't quote them, walk away.
AnswerID: 648739
