House solar panel on 4x4 roof
Submitted: Saturday, Jan 31, 2026 at 14:09
ThreadID: 152141 Views:2427 Replies:11 FollowUps:25
Hi All
I'm looking at doing a poverty solar installation and would appreciated any input.
Don't want to spend a fortune and am relatively time poor. Troopy still has AGM's. Yeah, I'll rewire it one day and install Lithium.
Wanted to put a house panel up top. I can get a new 450w (or there abouts) for low $200's.
Controller is wired in car, Anderson plug on bull-bar. Yes, controller can handle that wattage and voltage.
How to mount is my question.
I can't fit my car where I park under the house with a rack on. Have a full sized ARB rack, but at 65 kg and myself heading towards 60, it isn't as easy to get on and off by myself anymore.
I have two old rhino racks which I think might be the go. Maybe the heavy duty uni strut length ways, and 4 lighter weight uni strut cross braces.
I'm just planning on running a lead from panel to Anderson plug manually when parked up.
Not looking to angle it, yep, I know, hugely more efficient. Then need to carry a ladder. At 450w, lying flat in the Top End, I'm hoping I'll get enough juice.
My man concern is the panel just falling to bits the first lot of corrugations I hit.
I feel the centre of the panel needs to be supported, not just the frame. Thoughts?
Thanks for your input.
Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Peter_n_Margaret - Saturday, Jan 31, 2026 at 14:43
I doubt you need centre support.
I have a friend with a Canter with 4 similar panels on the roof, mounted in the conventional way.
We recently drove the Canning (and other places), without any issue.
AnswerID: 648920
Follow Up By: Member - lyndon NT - Saturday, Jan 31, 2026 at 14:53
Hi Peter
Thanks for the reply. I won't be driving down the Canning anytime soon, so that gives me some comfort. I just thought those huge panels are really designed to be stationary. The 12v ones that are smaller and have heavier frames, I can see them being OK. mmm
Lyndon
FollowupID: 930536
Reply By: Member - lyndon NT - Saturday, Jan 31, 2026 at 14:56
Whoops, also the bracket types people are using to hold these panels down. Not sure if the frame has sufficient "bulk" to bolt it down. Or maybe just some ally angle down the sides would do?
AnswerID: 648921
Follow Up By: Peter_n_Margaret - Saturday, Jan 31, 2026 at 15:01
Pic.....On the Canning, 2024.
Have no close up pics :(
Those panels did the southern Canning in 2024, northern Canning, Hamersley Range and Anne Beadell in 2025 and is now in Tasmania.
FollowupID: 930537
Follow Up By: Member - lyndon NT - Saturday, Jan 31, 2026 at 19:39
Thanks Peter
I guess I'll give it a go. What size panels are they on the OKA?
FollowupID: 930541
Follow Up By: Peter_n_Margaret - Saturday, Jan 31, 2026 at 21:34
3 @ 160W plus 3 @ 200W plus 200W as an awning over the rear window.
https://youtu.be/L2EOrguTzZk
FollowupID: 930545
Follow Up By: RMD - Tuesday, Feb 03, 2026 at 17:43
Lydon.
Depending on the panel either being LONGish or more Square, over a large area the middle of the glass is UNSUPPORTED and while probably OK on an OKA with big wheels and bottoming of suspension unlikely to cause a substantial INSTANT SHOCK to the CENTRE of GLASS MASS, a smaller vehicle like a LC will experience sudden and intense shocks sometimes to the GLASS centre MASS. Although GLASS is truly ELASTIC it only bends past a certain point. Therefore, I have used a thin aluminium strip, 25mm wide, edge on between the side rails and going across the MASS centre, Simply glued on with Polyurethane or SILICON sealant. That edge ON support stops the GLASS bending DOWNWARD in it's centre as the FRAME SUDDENLY is forced UP by the vehicle body. It is an instantaneous action you are wanting to dampen. If using two panels you can use a Reg, Mine 72vOC and reg 100V rating, which is more than the total panel voltage and the SERIES connection will give more overall supply harvest to the reg, and by using same size wiring as before, amps much the same but voltage doubled. The MPPT will then do it's best for you!
PS. I recently packaged THREE LARGE TV's in slim boxes with AMPLE SCREEN/GLASS SUPPORT because leant over they BEND and CRACK by GRAVITY ALONE. All three survived from Vic to Hervey bay in a TRUCK!
FollowupID: 930552
Follow Up By: Member - lyndon NT - Tuesday, Feb 03, 2026 at 20:12
Thanks, yes, I was concerned about the middle of a large panel flexing. Car has hard suspension and can shake like S--T in certain conditions.
FollowupID: 930553
Reply By: Zippo - Saturday, Jan 31, 2026 at 19:08
Weird coincidence! Last night I watched a video on me-tube with a comparison of auto-vs-house panels, and the dude did briefly cover the mounting and corro aspects.Here
AnswerID: 648924
Follow Up By: Member - lyndon NT - Saturday, Jan 31, 2026 at 19:38
Ha, Serendipity
FollowupID: 930540
Reply By: AlbyNSW - Sunday, Feb 01, 2026 at 10:45
A point to note is house panels are usually higher voltage than RV ones so will need a compatible controller
AnswerID: 648925
Follow Up By: Member - lyndon NT - Tuesday, Feb 03, 2026 at 20:13
Cheers, yeah, have a victron 100/50
FollowupID: 930554
Reply By: Allan B (Sunshine Coast) - Sunday, Feb 01, 2026 at 11:38
Hi Lyndon,
On my Troopy I had only a single 120?W panel mounted above the cabin roof as the rack occupied the rest of the roof. The panel was bolted via brackets directly to the roof. No problems.
On the Sprinter I used 4x 120ww 22.8v panels that measured 1578mm x 541mm x 35mm. They were attached to the OEM recessed rails on the roof. The forward two panels were transverse then the other two behind were arranged longitudinally. I deemed that the panels were too flexible so reinforced their frames on their longer dimension with 40x40x3mm aluminium angle. Even then I found the most forward panel which bore the brunt of the travel airspeed, exhibited fluttering so added a rubber bush between the panel and roof, attached only to the panel. This cured the flutter and all has been well since.
I would mention though that the sprinter is not subject to the extreme road conditions that the Troopy experienced. It has however survived the Strzelecki Track and a few short unsealed and corrugated access tracks.
I have no knowledge of the flexibility of domestic type panels so the above may not be appropriate.
But I do know that quite a few people have used domestic panels on vehicles off-road.
AnswerID: 648926
Follow Up By: Member - lyndon NT - Saturday, Feb 07, 2026 at 16:22
Cheers Allan
I'm pretty certain I'll go for a house panel, if it fall to bits, so be it.
The angle is a great idea. I'll think I'll do what RMD suggested and just silicone it from side to side, seeing as it's just to stop the flex. With unit strut to mount it as aforementioned.
Lyndon
FollowupID: 930567
Reply By: Member - nick boab - Sunday, Feb 01, 2026 at 20:41
Lyndon, did you consider cheap flexible panels glued on ?
AnswerID: 648927
Follow Up By: Member - lyndon NT - Wednesday, Feb 18, 2026 at 20:05
Hi Nick
I did buy a flexible panel once. Output was terrible compared to a fixed glass panel.
FollowupID: 930604
Follow Up By: Member - nick boab - Thursday, Feb 19, 2026 at 08:42
Hi Lyndon: while the flexible panels may not be the best for producing power ,longevity they are easily mounted and serve a purpose.
I have two flexible panels 1 x200w 1x 160w mounted to my rooftop tent in SERIES and they are working exceptionally well for me.
Interesting , the 200w panels I bought from a well known Victorian importer that doesn't produce anywhere near that in watt's
The other panel 160 Watts I bought from Kings on special cheaply that does produce somewhere near what they claim.
Horses for courses
FollowupID: 930606
Follow Up By: Allan B (Sunshine Coast) - Thursday, Feb 19, 2026 at 08:57
Hi Nick, if you have the panels in series then the 200W panel output is limited by the current capacity of the 160W panel. Effectively you have a total rating of 320 watts, not 360W.
FollowupID: 930607
Follow Up By: Member - nick boab - Thursday, Feb 19, 2026 at 09:08
Allan, the 200 watt panel I referred to was tested prior to the second panel and in series.
FollowupID: 930608
Follow Up By: Member - nick boab - Thursday, Feb 19, 2026 at 09:20
The earlier comment I made 930606 .
I forgot to mention as well the kings 160 watt panel was a larger area size then the 200w.
FollowupID: 930609
Follow Up By: Allan B (Sunshine Coast) - Thursday, Feb 19, 2026 at 12:07
Nick, now you have got me totally confused.
I'll just put it simply….. In a series configuration, the maximum available output current will be that of the smallest panel. Panel area is of no significance.
EDIT: ….. of the electrically smallest panel.
FollowupID: 930610
Reply By: Batt's - Sunday, Feb 01, 2026 at 21:50
Do house solar panels have higher voltage output than ones we use on our vehicle's or vans for eg ? Just wondering if a special type of solar regulator would be required.
AnswerID: 648928
Follow Up By: Allan B (Sunshine Coast) - Sunday, Feb 01, 2026 at 21:57
Yes Batt's, house panels can be up to 40v and do require a regulator rated to accept that voltage.
FollowupID: 930546
Follow Up By: Peter_n_Margaret - Sunday, Feb 01, 2026 at 23:17
Victron is good for these. Good quality at a reasonable price.
With my new build I will be using 430W semi flexible panels that are 42V and Victron controllers.
FollowupID: 930547
Follow Up By: Allan B (Sunshine Coast) - Monday, Feb 02, 2026 at 13:17
They look good Peter. My only apprehension would be removal if necessary. Especially on a composite roof.
How are you attaching them?
FollowupID: 930548
Follow Up By: Nomadic Navara - Monday, Feb 02, 2026 at 13:24
Quote " Just wondering if a special type of solar regulator would be required."
There is nothing special about the regulators used on our homes or in commercial applications. There are three types of regulator that are commonly used for battery charging. The older shunt type that are no longer used. The second type that were introduces are the PWM type that are used when the output voltage of the panels are only a bit higher than the battery charge voltage. Thirdly, there is the MPPT type that "transform" the panels output voltage to match the battery charging voltage.
The MPPT type of charger are the main type used by caravanners. These come with a broad range of maximum permissible input voltages, so you just have to be careful that you select a model that can accommodate your panel array output voltages.
The regulators used in domestic installations without batteries operate the same way as those we use on our vans. They differ from the van models in that their output is 230V AC power and not DC battery charging power.
FollowupID: 930549
Follow Up By: Peter_n_Margaret - Monday, Feb 02, 2026 at 14:53
Allan B said "They look good Peter. My only apprehension would be removal if necessary. Especially on a composite roof.
How are you attaching them?"
They will be attached directly to the roof with either a structural silicone, or VHB tape, yet to be decided.
I have found this mob's advice very sound. Solar4RVs mounting instructions.
I don't want an air gap under them to fill up with red dirt and twigs, but understand that will cost about 10% power when it is hot (but that is also when there is plenty of energy being produced).
Getting them off is easy. Start with a multi-tool around the edges and then use a length of tiny diameter stainless steel fishing cable, or even 100kg fishing braid, with a handle each end.
FollowupID: 930550
Follow Up By: Allan B (Sunshine Coast) - Monday, Feb 02, 2026 at 21:01
......"then use a length of tiny diameter stainless steel fishing cable."
Ah, yes. Just like cheese. Clever.
FollowupID: 930551
Follow Up By: Batt's - Saturday, Feb 14, 2026 at 16:36
I had a gap under 2 aluminium frame solar panels on my chequer plate canopy for 11yrs and no large amounts of dirt ever built up under them. Wind, rain keep it pretty clean and when washing the car I usually hit the canopy with a gerni. If I didn't have a gap the dust that did get in there could build up and be hard to remove probably because of the type of surface.
FollowupID: 930587
Reply By: Phil G - Friday, Feb 06, 2026 at 09:38
Gday Lyndon,
I have a 2019 Troopy that is 2100 high and a garage that has 2140mm opening. I can't fit a glass panel on the roof because they are a touch too high
My solution is to mount 2 x 160W flexible panels on Rhino RT27 tracks which are riveted and sikaflexed to the roof. The flexible panels are framed with aluminium to keep them in shape and also to allow them to be bolted down using M6 Channel bolts. The centre of the panels is kept just above the roof ribs with some 12mm thich aluminium that is fixed to the roof with double sided tape. Been using this for about 5 years now.
The flexible panels don't last like glass even though I have a reasonable air gap. I put new panels on last year - went with the Kings 160W because they are the perfect size for my roof, are cheap and looked better quality than the more expensive ones I've had in the past. After 12 months, they are still full output - middle of the day gets me around 20 Amps.
My cable passes through the roof and to a Victron 100/30 using a sealed anderson plug cover.
AnswerID: 648932
Follow Up By: Batt's - Friday, Feb 06, 2026 at 16:22
On a different note when we had our first home built in 1995 I had some pre thought and asked about taller garage openings for a tripple garage attached to the house. The builder said they could leave 1 course/row of bricks out that way I could fit my 1986 HJ61 high roof Sahara in which had 33" tyres.
Then myself and a mate one day fitted a lift kit to the Sahara while it was in the garage then thought hope I can get it out. Ended up with 30mm of clearance luckily.
FollowupID: 930562
Follow Up By: Member - lyndon NT - Wednesday, Feb 18, 2026 at 20:12
Hi Phil
Really appreciate that info. It would also solve my clearance issue (I think).
Mmm, food for thought.
FollowupID: 930605
Reply By: Andrew L - Monday, Feb 09, 2026 at 20:01
Arnt roof panels 40 volts? Ie 6 panels =240 volts dc?
AnswerID: 648937
Follow Up By: Peter_n_Margaret - Monday, Feb 09, 2026 at 23:17
Series or parallel is an option, or a bit of both such as 3 x 80V.
My new build will have a small Victron for each of 5 panels, each 430W and 42V. Anything fails, the others carry on.
FollowupID: 930572
Reply By: nickb - Friday, Feb 13, 2026 at 00:17
I recently mounted a 475W house panel to my Coromal XC, Been on it's first 2300km trip and all good. Did about 100km worth or gravel with about 10km solid corrugations, van has no shock absorbers either. Laying flat on the roof the most I saw was 412W, but batteries were getting pretty full by that stage.
My mate modified the original solar panel bracket so it was supported on all 4 sides, I would have been happy if only the 2 long edges were supported.
Panel only cost me $130, once I convert the camper to induction cooking I'll plonk another panel next to it.
AnswerID: 648949
Reply By: Member - lyndon NT - Thursday, Feb 19, 2026 at 07:57
Connector types folks, so if I get a house panel it comes with MC4 connectors. I have heard these are moving to a tool-less design, though don't know the details re this.
Do I cut them off and crimp direct to Anderson or....? I see Red Arc sell an MC4 to Anderson adapter.
Thoughts?
Lyndon
AnswerID: 648965
