Building a touring/4x4 vehicle data logger — what would be the best da
Submitted: Sunday, Feb 15, 2026 at 16:56
ThreadID: 152181 Views:618 Replies:4 FollowUps:8
G’day legends,
I’m building a small standalone trip/vehicle data logger for remote touring and 4x4 trips for my family and friends and I’m trying to figure out what people actually care about.
Idea is:
Logs engine/vehicle data while you’re driving. (ODBII/K-Line)
GPS coordinates.
Analog inputs for battery voltages or digital inputs for switching signals.
Saves everything locally to SD card.
Can review trips later.
Potential live dashboard via WiFi on your phone.
Viewing historic data will be from CSV or similar where graphs can be setup..
Question for you guys:
When you’re out touring, what do you actually monitor? Temps? Voltage? Fuel usage? Nothing?
And have you ever had a failure or breakdown where you wish you had data from before it happened? Like if you knew your battery has been struggling to charge over time before you went on a trip and had a starter motor failure etc, this could have been flagged earlier for replacement.
Reply By: Member - Warren H - Sunday, Feb 15, 2026 at 18:50
Everything you've listed can be done using an OBD2 reader and the Torque Pro app or Apple equivalent. Wrt parameters, coolant and transmission temps for on-the-go visuals, then other parameters such as intake air temperature, rail pressure for problems but proper interpretation of these is level above my expertise.
NT Pajero
2007 Goldstream Crown
AnswerID: 648957
Follow Up By: HairyLocal694 - Sunday, Feb 15, 2026 at 18:58
Thanks for your input. I do agree about the Torque Pro app and have recently come across it but never used it. From what i can see is it can only log ODBII data and not read or process external inputs.
I will have to try Torque Pro for a bit to see what it has to offer.
FollowupID: 930589
Follow Up By: Member - Warren H - Sunday, Feb 15, 2026 at 21:19
You are correct it only deals with OBD2 data.
NT Pajero
FollowupID: 930591
Reply By: RMD - Sunday, Feb 15, 2026 at 20:57
Hairy.
If you monitor the voltage and it is insufficient, then WHAT!
How would a monitor be able to show a BATTERY struggling to charge? If volts and amp supply is sufficient, it will charge, and you still won't know if it has the capacity to start the engine later. SO what does struggling to charge mean?
With the starter motor failure, no meter will tell you that! How could you predict the burning of contacts to stop the starter operating??? or a MECHANICAL STARTER FAILURE???
I use the fuel gauge to see the usage and conditions vary that too!
I made a system to indicate if head temp got too hot, ie, sounds an ALARM. It is the best way!
Apart from voltage, maybe, and water temp, you have no control over most of it anyway so not much use storing the data. WHO is going to interpret it later? And what are you going to do about it?
AnswerID: 648959
Follow Up By: HairyLocal694 - Sunday, Feb 15, 2026 at 21:23
1. A weak/older battery will have more voltage sag when cranking and bounce back to nominal voltage slower. This is measurable just by volts alone.
2. A bad starter can be seen as a weak battery if just looking at the collected data. If ODBII data was recording cranking RPM, maybe it can be monitored over time to show if starter is struggling. (Filtering out temp variations etc would be essential). Now i don't think a mechanical failure can be predicted but there can definitely be data pointing to worn out hardware.
3. I would want to monitor the health of my batteries(Main and Aux etc) and other parameters also that can point towards worn engine hardware.
Just hypothetical but can be implemented with the right data collection and testing to prove what data corresponds to what physical problems.
FollowupID: 930592
Follow Up By: RMD - Monday, Feb 16, 2026 at 16:47
A WEAKER BATTERY WILL SHOW HIGHER VOLTAGE FAR QUICKER than a NEW ONE WILL. DO YOU KNOW WHY? Measuring by volts ALONE won't prove it to most people unless they have EXPERIENCE in the starters, batteries, etc.
How will the average person ever begin to interpret any data recorded. Will you incorporate a digital interpretive system so the normal operator would see what it means?
How WILL monitoring battery voltages indicate WORN ENGINE HARDWARE???? The Alternator is the ONLY ITEM dealing with battery health and it either charges correctly , ie VOLTAGE READING or it DOES NOT! Can you tell if an ALT HAS a DUD DIODE?
Are you making some of this up as you go along?
FollowupID: 930598
Follow Up By: Member - David M (SA) - Wednesday, Feb 18, 2026 at 10:07
"Are you making some of this up as you go along?"
Think your spot on RMD.
Doing it just to wind you up.
Dave.
FollowupID: 930602
Reply By: Member - Bigfish - Monday, Feb 16, 2026 at 09:22
I think your way over thinking it. Get an Ultragauge or Scangauge and they can tell you everything you need to knwo. I,ve had batteries that have tested well and a week later have dropped a cell and become useless..no tool will predict this. I,ve been monitoring my vehicles performance with an Ultragauge for 6 years. It works brilliantly and preset alarms let me know of pending issues. Battery inputs will vary with revs of the engine and battery output usage...these can be all over the place and knowing the figures on a trip is of no value. I fail to see the value in knowing that my vehicle was putting out 13.5 volts at 100kph at gps co=ord.Lat 1234 long 12324.. The answer to your last question is simple...get an Ultragauge or Scangauge and this will monitor everything you need to keep an eye on your vehicles operation whilst traveling. I monitor gps speed, intake temp, engine temp, transmission temp, volts, boost and if you want you can do fuel usage , trip time etc, etc......well worth the money and not expensive.
AnswerID: 648962
Follow Up By: RMD - Monday, Feb 16, 2026 at 16:50
Bigfish
I think he wants to produce something for sale to satisfy a need which has already been catered for by what you mentioned.
FollowupID: 930599
Follow Up By: Member - Bigfish - Tuesday, Feb 17, 2026 at 18:21
He has posted the same question on other forums so yes...I think he is testing the waters for a commercial product for the market..personally I think its a waste of time..
FollowupID: 930601
Follow Up By: Member - Warren H - Wednesday, Feb 18, 2026 at 10:35
A good question would be what data gets logged in industrial applications of ICEs as part of maintenance procedures? Not a data logger application but oil analysis for wear metals is commonly done in industrial applications.
NT Pajero
FollowupID: 930603
Reply By: Member - LeighW - Wednesday, Feb 18, 2026 at 16:48
There was a couple of ODB units that allowed you to select and log ODB data, one such unit was the "DashDyno" from unit from Auterra. It had a graphical display, alarms and external inputs, allowed reset of fault codes and had trip computers etc and was well in advance of the scangauge units of the time. There didn't appear to be much demand though from the general public market for data loggers. I used a DashDyno for many years and only repalced it recently as the company was no longer updating codes and I wanted to monitor my trans temperatures. In the many years I had the unit I never used the logging capabilty apart from the trip meters.
A quick check of the net gives a few hits for ODB2 data loggers which aren't expensive so if your considering to develope your own to market I would suggest you research what's already out there.
AnswerID: 648964
