Unsynced routes
Submitted: Saturday, Apr 18, 2026 at 21:30
ThreadID: 152389 Views:417 Replies:2 FollowUps:2
I have 4 very large routes that will not sync. Unfortunately I am not a member so I can’t export the route before resetting the app to clear the queue and get sync to work again. Any suggestions on how to fix without loosing my locally stored routes? Every time I edit or create a new route it just add to the unsynced queue.
Reply By: Member - Darro - Thursday, Apr 23, 2026 at 14:37
Hi, Any change you've added your own "place" as a waypoint, or was it just using existing public places?
Does a new route just between two locations also fail to Sync?
AnswerID: 649159
Follow Up By: Bullfrog - Thursday, Apr 23, 2026 at 22:59
Yes my large route has public places and unique waypoints.
When I just created a very simple new route the sync worked. But not sure how to fix the large unsynced??
FollowupID: 930874
Follow Up By: Member - Darro - Friday, Apr 24, 2026 at 07:43
While this may not be too helpful, it might be worth a try until someone comes up with a better option.
Save a copy your route, and delete a big chunk of the copy and see if it Syncs then. You might be able to narrow down the section it does not like.
I suspect adding in thoses sections again will work. it does for me.
FollowupID: 930876
