GU SUB TANK SWITCH
Submitted: Wednesday, Aug 11, 2004 at 19:38
MARK
HI GUYS
I WOULD LIKE TO KNOW WHAT WOULD HAPPEN IF I WAITED TILL THE MAIN
TANK RAN OUT BEFORE CHANGING OVER TO THE SUB
TANK ON MY 4.2 TD PATROL .
I HAVE CALCULATED THAT THRERE IS ABOUT 25L STILL IN THE MAIN
TANK WHEN THE
ORANGE EMPTY LIGHT COMES ON , CAN ANYONE CONFIRM THIS ? WANT TO SEE HOW MANY KMS I GET WHEN THE LIGHT IS ON ?
Reply By: pjd - Wednesday, Aug 11, 2004 at 20:19
it would cough & stop you would then need to pump the
fuel into the main
tank & hope it starts
72188
Follow Up By: Brian - Wednesday, Aug 11, 2004 at 20:29
Also would need to re prime it !
Brian
332379
Reply By: Bonz (Vic) - Wednesday, Aug 11, 2004 at 20:48
yep what they said, still, under controlled coditions it would be a worthwhile exercise I reckon
72194
Follow Up By: Member - Captain (WA) - Wednesday, Aug 11, 2004 at 22:37
Don't know about that Bonz! I accidentally ran my GU empty on the main
tank when I first got it (didn't realise the sub
tank switch turns off when car is stopped and need to push switch again to continue pumping - 80 series stays on the
tank selected).
So, I waited with ignition on and pumped
fuel into the main
tank (could see main gauge increase) and tried to prime. After running my battery just about flat, finally got it going some 30 minutes later. But at least I now know there is 95 litres in the main
tank (and 32 in sub).
Captain
332418
Follow Up By: Brian - Thursday, Aug 12, 2004 at 10:55
Captian you realy need to Hand prime the system as I believe that you can do damage to the pump if you run it dry!
Brian
332486
Follow Up By: Member - Captain (WA) - Thursday, Aug 12, 2004 at 20:04
Hi Brian,
I primed the pump every time I cranked it (max 30 sec cranking) until you could not depress the button any more. In future I would remove the filter and prime continuously as I think the problem was in filling the empty
fuel line from the
tank to the filter. Once filled, the engine finally stayed running.
Captain
332562
Follow Up By: warthog - Thursday, Aug 12, 2004 at 22:41
I have a 4.2turbo GU and have been told to avoid running out of
fuel as the rotary
fuel pump relies on diesel for it's lubrication and running it out of
fuel will result in premature wear. We must have come close however during a recent trip as both tanks took 126 ltrs.
332581
Reply By: duncs - Wednesday, Aug 11, 2004 at 22:30
I haven't done it in the GU but I did have the misfortune to run out in the GQ.
When it happened I was able to coast down the
hill and pull into a service station. I filled up and turned the key not really expecting much success but it fired up and ran, a bit rough at first but it sorted itself out.
Apparently theyve self priming injectors and can cope with running out of
fuel.
You don't need to prime the injectors if you change the
fuel filter just pump it up with the manual pump on the filter itself.
If you wnat to try it I would turn it off as soon as it coffs and then switch the reserve on, let it drain through for a while and re-start the engine.
Let us know how yo go.
Duncs
72213
Reply By: Member - Roachie (SA) - Wednesday, Aug 11, 2004 at 22:41
Mark,
Three things to say......
1) PLEASE DON"T SHOUT....(it is considered rude to use upper case ol' mate)
2) Although I've got a 145litre replacement
tank, it still uses the original sender unit in the
tank. I have driven around 100klm with the
orange light on and it took around 135 litres to fill the main
tank.
3) Recently I had a bad experience out in the bush. I'd been camped with the Patrol facing up
hill on the side of the track all night. Next morning we decided to go for a short drive up the track. I started her up and idled for about 5 minutes (as i always do) and Gerk (who was with me in his truck) and I started off up this fairly steep (low range)
hill. My main
tank gauge was showing between quarter and half (closer to quarter though). My sub
tank was still full. As I started to climb I lost nearly all power. I pulled up and used the hand throttle to hold the revs at about 1100. Any harder on the loud pedal and she'd cough and almost stall......take my foot off the pedal and she'd die in the bum. So with the 1100 showing and hand brake on (gotta love transmission hand brakes), I got out and chocked the
wheels and lifted the bonnet. Note that wife and kids abandoned ship and left me to my own devices. I've got a Lucas/CAV filter system with glass bottom bowl and 1st thing I noticed was small air bubbles coming up from the bottom bolt through the diesel in the glass bowl. I soon twigged that she was sucking air. Jumped back in and hit the aux
tank switch. About 2 minutes later she was purring again; nice as you like!!!!
Hope this helps.....
Cya
72220
Reply By: V8Diesel - Wednesday, Aug 11, 2004 at 23:37
Mark, a bit off the subject but one thing to remember on the GU when you are doing lots of city driving is that the aux
tank pumps into the main
tank for a while every time you start up. Sounds silly but that 'full'
tank can rapidly become a half
tank quite quickly without you doing anything. Could be a trap if you're ever depending on it.
72228
Reply By: Well 55 - Thursday, Aug 12, 2004 at 07:14
I have done a further 105k after the empty light came on and when filled up still had 5lt left in the
tank. That was between Archer River and
Weipa so it was flat running most of the way.
The wife was not impressed.
72238
Reply By: Member - Michael- Thursday, Aug 12, 2004 at 09:49
Hi Mark
I'm curious myself, would like to know how far my GU 3LTD would travel. The only problem I can see is that if there is any crap in the bottom of the
tank, you are going to suck it through the
fuel lines into the filter.
Mike
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
72256
Follow Up By: Alex - Thursday, Aug 12, 2004 at 19:09
fuel is always drawn from the bottom of the
tank , so any junk in the bottom of
tank will go through and hopefully be caught by filter
332554
Reply By: crowie - Thursday, Aug 12, 2004 at 10:04
Mark
Your probably right. I have a ZD30 with same tanks and there is about 25 litres left in the main
tank when the warning light comes on "permanently". I have tested it several times on the highway so I would know when I was off road what I had left. You can work out the theoretical average distance you can travel from your normal
fuel consumption, no need to run it to empty to find out. Leave yourself a margin of error to be on the safe side. For me about 150/200km depending on conditions.
72260
Reply By: basecamp15 - Thursday, Aug 12, 2004 at 20:24
I ran my main
tank down to see if my low
fuel light was actually working, it wasn't and I ran out.
It was a simple matter to leave the car on 'on' while having the sub
tank pumping. During this time I was hand priming using the pump on the
fuel filter and when she was primed, started her up no worries.
Being a 4.2 turbo I had to idel it for a bit to get enough from the sub
tank into the main
tank before taking off again.
And you will pump a fair bit each time you start the engine too. It's possible to actually have only half your subtank left before actually draining it yourself if you do a lot of stop start driving.
Cheers, Mark.
72365
Reply By: Pluto - Friday, Aug 13, 2004 at 09:14
Mark,
My guesstimate on the reserve capacity is similar to yours, or a little less. I have run my 2.8GU for about 150km with the warning light on before refuelling. I believe I had less then five litres left when I refuelled.
As for leaving the sub
tank transfer until the last moment, I don't think there is any reason to do this. You run the risk of damaging the
fuel pump and (as Captain pointed out) waste a lot of time getting started again. My regular practise is to transfer the sub
tank once the main
tank is showing room to take the transfer. Afterall, the
fuel in the subtank is not available for use untill it is transfered. This also maximises the flushing of the sub
tank and avoids the slightest chance of stale
fuel.
Pluto
72430
