need a GPS guru
Submitted: Wednesday, Sep 01, 2004 at 22:30
Member Eric
well I think I need to stick with things that have a engine in them lol . I am trying to upload maps from Discover oz to sd card on a card writer , always stops at 30 % any ideas guys and gals ?
Reply By: Truckster (Vic) - Wednesday, Sep 01, 2004 at 23:05
Have you formatted the card? Maybe its having issues with the card.. You know your luck so far with that thing.
74842
Follow Up By: John - Saturday, Sep 04, 2004 at 16:42
Whenever I'm creating stuff for upload I always turn off Antivirus programs.
- This is a recomendation from the Magellan yahoo group.
Try it - speeds things up - gives the computer less work to do.
John (
Perth) at present in
Townsville
334938
Reply By: Member - Stephen (WA) - Thursday, Sep 02, 2004 at 00:00
Eric,
Patience is a virtue......apparently....
Mine does exactly the same...sits on 30 and 31% for effing ages. It will eventually finish its run however.
Go and make a cuppa, mow the lawn, paint the house and by the time you've finished all that, it should've moved off 30% and progress through the rest of the run.
Stephen J.
74849
Follow Up By: Wazza (Vic) - Thursday, Sep 02, 2004 at 04:10
Stephen's right, had the same with a mate's. Sat on 30% for ages. Eventually does the last 60% really quickly.
334703
Reply By: cokeaddict - Thursday, Sep 02, 2004 at 09:05
Ahhh modern technology....
where would we be without it ay :-)
74859
Follow Up By: Truckster (Vic) - Thursday, Sep 02, 2004 at 09:25
LONG LIVE PAPER MAPS!!!!
334712
Follow Up By: Baz (NSW) - Thursday, Sep 02, 2004 at 09:42
HEAR HEAR !!!
334715
Follow Up By: Greg Harewood - Thursday, Sep 02, 2004 at 10:14
Truckster/Baz et al...been through this before I now...but….all maps have their shortcomings - even paper ones. GPS units are very valuable tool - and one with maps on it is even better (detail on DiscoverAus overall pretty good). Paper maps are also a valuable tool - so choose "horses for courses" depending on your requirements. If you restrict your usage to one or the other (out of ignornace/technophobia/spite?) you’re just making it hard for yourself. If you have no need for a GPS with maps ..fine..but I can assure you some people find them indispensable for work and play. One good thing about a GPS unit is that you can actaully collect data in the field and go back home and add to or make your own paper maps!! I do it all the time - Yahoo!!
334718
Follow Up By: Truckster (Vic) - Thursday, Sep 02, 2004 at 10:50
Intrestingly enough, batteries have never gone flat on my paper map..
YMMV
334722
Follow Up By: Member - John (Vic) - Thursday, Sep 02, 2004 at 13:46
Truckster your a bloody stirring cynic. LOL.
You are looking for or may now have a GPS for your self so what are carrying on about.
Once you have used a GPS with a Lap Top you wonder how you ever did without the convenience of the thing.
Besides which they are also good fun to use, my 14 year old son loves navigating with the system and it is a great learning curve in all aspects for him.
He gets a buzz telling others in the group where we are and how far to go before they have even unfolded the paper map.
My GPS has never run its batteries flat either as it is powered of the vehicles battery, same with the lap top.
But having said that I still carry the paper maps for the area in which I am in as I am not so blind as to realize that it is prudent to still do so, things do happen to electronics.
334740
Reply By: equinox - Thursday, Sep 02, 2004 at 12:41
Question for Greg:
About ten years ago when I was working for WMC I used a small dash-mounted Garmin GPS unit for various survyes etc. Coming home to
Perth from Mt Keith I set the GPS to take a position reading every 5 minutes. When I got home and downloaded the data I had a very accurate road map of the route and still had about 97% of the GPS's memory left.
I've only got a cheap Garmin Etrex now but could you tell me if there is any GPS available in Australia for perhaps under $1000 that can provide the facility mentioned above without having to revert to storing the data on a laptop in the field?
Eq.
74878
Follow Up By: Member - Bob - Thursday, Sep 02, 2004 at 13:00
Eq,
all the hand held Magellans are less than $1000 and they will all record a track. Not just every 5minutes but almost continuously. One interesting feature is to select track profile and see your altitiude over the whole trip. Of course you can later download the saved tracks to your computer if you want.
334731
Follow Up By: Utemad - Thursday, Sep 02, 2004 at 14:21
Have a look at this.
Garmin Comparison
Which Etrex do you have?
The Venture, Legend and Vista allow you to adjust the track points for accuracy or more distance by time or distance.
The Legend and Vista allow 10000 track points but others only 2000. You can save 10 tracks in any of them using the available points.
I personally have the Etrex Legend and have tracked 8hr drives on the standard settings and it has used minimal memory. Even on long twisty drives such as in NZ I have had no troubles. Tracks the road perfectly on the GPS or when downloaded to mapping software.
Incidentally, with the standard software supplied on the Legend I was able to drive around NZ with all the main roads perfectly represented. Although we didn't rely on it.
334743
Follow Up By: Greg Harewood - Thursday, Sep 02, 2004 at 18:41
equinox - If I need to keep lots of track points I use PDA equipped with GPS (Ipaq2210 + CF GPS unit + 256mbSD ~$750)...unit has 64mb onboard memory and whatever SD or CF card you feel like sticking in it - so storage not and issue. All (?) Magellan GPS units are limited to 2000 track points so this restricts you on big trips...unless you can hook up to a laptop/PDA after-hours. I have no idea what Garmins or other GPS units have with regards to track point storage but looks like others are in the know on this one. The number of track points required relates to your proposed use of the data and the map scale at which you are going to plot it. 2000 points will be enough in some circumstances..but in others a bit sad.
334761
Reply By: Member - Clive G (WA) - Thursday, Sep 02, 2004 at 16:20
I have the Gaemin Etrex Legend as
well, It suits me, continuous tracks plenty of memory,
Clive
74894
