The blue wire...
Submitted: Wednesday, Nov 24, 2004 at 18:34
Member - Blue (VIC)
Have mounted and am ready to wire up my redarc solenoid. The blue wire say's +AUX on it but the diagram supplied shows this wire connected to the top terminal where the Starting battery goes??? A second diagram says use this wire to power a "momentary swith" so as to use the Aux battery as a starting battery in emergency. A little help here if you please
Blue
Reply By: Steve - Wednesday, Nov 24, 2004 at 18:44
Hi Blue.
i have a redarc installed by auto electrian. you want me to take few pics and email to you, if yes give me yr email n i'll send some over.
cheers steve
85756
Follow Up By: Member - Blue (VIC) - Wednesday, Nov 24, 2004 at 20:22
That'd be good thanks Steve, I'm going to try it with the blue swinging free but would be nice to have the pics for later reference.
bluegeorge at netspace dot net dot au
have broadband so don't worrie about resizing them unless you want to.
Blue
344315
Follow Up By: Member - Blue (VIC) - Wednesday, Nov 24, 2004 at 20:24
this site needs spell check, I can't believe how bad I spell sometimes until I re-read my posts
344316
Follow Up By: Bonz (Vic) - Thursday, Nov 25, 2004 at 17:27
I got a redarc under the bonnet Blue, we can have a look over lunch on Satdy if you like.
344486
Reply By: Member - Nick (TAS) - Wednesday, Nov 24, 2004 at 19:03
Gday Blue,as I understand it ,its so if your starting battery goes flat you can power the blue wire and it will link the aux battery to the starting battery to get you started .You can also link the two batterys together while winching,I think some people have a switch in the cab so they can link batterys at the flick of a switch.Ive got the blue wire floating free on
mine ,if I need to link them Ive just gotto hook it up to +.
85758
Reply By: Mad Dog (Victoria) - Wednesday, Nov 24, 2004 at 19:08
My understanding is that this wire needs to be grounded through a momentary switch for the override to operate. While the switch is pressed the batteries will be connected.
85759
Follow Up By: Member - Blue (VIC) - Wednesday, Nov 24, 2004 at 20:28
That's what I thought the second diagram was trying to show. I reckon I'll let the blue one swing (my SWMBO could really take that the wrong way) and see what happens.
344317
Reply By: Tim HJ61 - Wednesday, Nov 24, 2004 at 22:41
The Blue wire turns on the solenoid so the aux battery is connected and therefore overrides the smart circuitry within the Redarc that turns it off at 12.7v in normal circumstances. It is an optional connection and does not need to be connected.
The wiring diagram I have clearly indicates you need to apply +12v to the blue wire to power up the solenoid if you choose to do so. It also states "Use a dash mounted momentary spring return switch to connect the Aux wire to the postive of either battery to activate the solenoid ..."
Redarc provide excellent customer feedback and have talked me through several dumb questions I have asked, even providing drawings to help me with my out of the ordinary setup - 24v HJ61 Landcruiser with Redarc Voltage Equaliser and Smart Start solenoid powering an aux battery that is mostly out of the vehicle and connected only for trips away (due to lack of space to permanently mount it).
I hope this is useful.
Tim
85803
Follow Up By: Member - Blue (VIC) - Wednesday, Nov 24, 2004 at 22:52
Hi Tim,
appreciate the feedback, I have left it swinging and completed the rest of the install. The fitting diagrams I received were really quite vague and the diagrams themselves were quite grainy... Tomorrow the battery goes in and I get to test it all out.
Blue
344355
Follow Up By: Mad Dog (Victoria) - Wednesday, Nov 24, 2004 at 23:08
There appears to be some confusion because the redarc website hasn't been upgraded to reflect the new model isolator. The instructions on the website state to ground the little bolt behind the electronic box but it appears the new model has a blue wire that has to be connected to +ve
I emailed Redarc a few months ago regarding the isolator I purchased. I wanted to know if it was an old model but they informed me it was the latest and their website would be updated shortly. They are usually right on the ball
Thanks Tim, that's cleared that up should I decide to connect the blue wire.
344359
Reply By: Member - Captain (WA) - Wednesday, Nov 24, 2004 at 23:41
Mad Dog is right on the money. The "new" redarc needs the blue wire connected to +ve of the aux battery (via a switch) to overide the solenoid. The "old" redarc required a wire to only be grounded to overide it.
Redarc made the change as if you have a flat main battery and want to bring in the aux battery, when you grounded the wire it required power from the main battery to close the solenoid. But if the main battery is flat, it cannot close the solenoid...
On the "new" redarc, the blue wire goes the the aux battery and so, when the main is flat and you want to overide the solenoid, the aux battery provides the power.
I got this info direct from redarc (great customer service) and they made the change in response to complaints from 4WD's that the overide didn't work when the main battery was flat. Again, great manufacturing response to a problem.
Captain
PS. I have no affiliation with redarc - just like there products!
85814
Reply By: Troopy Travellers (NSW) - Thursday, Nov 25, 2004 at 08:49
I've recently wired up my new Redarc unit. Connect the blue wire to one contact of a push button switch (in the cab) & the other push button contact to the Aux battery via a 10A in-line fuse. Connect the ground terminal to the chassis. When you push the button you will here the solenoid click in, thus putting both batteries in parallel.
PS: I agree the Web drawing is unclear. Do not wire the blue wire to ground!!!!!!
Sparky
85832
Follow Up By: Mad Dog (Victoria) - Thursday, Nov 25, 2004 at 17:51
Yeah Sparky, the drawing on the web is for the old model, you have the new model which is connected to +
cya..
344491
Reply By: rolande- Sunday, Nov 28, 2004 at 00:24
Blue,
You probably already have your answer but just to reinforce what has already been said, this is how I have it set up, (with directions form REDARC)
1/ The blue wire goes to a pin at the back of a momentary on switch which is spring loaded and fitted to the dash.
2/ The second pin on the back of the switch is wired back to the thread on the top of the isolator to which the starting battery is wired.
So, cable from starting battery to isolator, put wire on this thread, run to switch, then from switch back to blue wire on Isolator. When switch pressed this joins both batteries together and, hey presto.
As a hint, strip the wire and crimp in place to the blue wire, I tired to get the blade lug out and broke it.
Hope this helps
Rolande
86179
