What happens when a dual battery carks it
Submitted: Saturday, Dec 18, 2004 at 16:09
ThreadID: 18679 Views:2246 Replies:6 FollowUps:1
I have two deep cycle batteries in paralel (12V) setup in the truck. I was wondering what typically happens when one of them cark it? Ie ive heard they drop a cell and volatage reads very low etc. What effect does this have on the good battery? Does the combined outp[ut volate still read 12V, are there any obvious signs etc?
Im just wary of one battery dieing, and discharging the good battery.
Glenn.
Reply By: hl - Saturday, Dec 18, 2004 at 17:31
Probably not safe. If one cell shorts in one, the other will try and dump into the other. Can involve very high current, heat and general destruction.
Much better way to have to 6V in series to get higher aH capacity.
AnswerID: 89391
Reply By: Member - Davoe (WA) - Sunday, Dec 19, 2004 at 16:11
If one of you batterys carks it it will hog most of the charge putting your good battery at peril. There is still something to be said for the old style cole hersy switch which you can individually test the starting power of each battery and issolate a dud one
AnswerID: 89466
Follow Up By: 28patrol - Sunday, Dec 19, 2004 at 18:51
I agree. My deep cycle was not being charged enough to keep the fridge running. Thinking it was on the way out (4yr old) went to the battery people for testing. Turned out my starter was dud and it was hogging the majority of the charge. Replaced with a new starter and the deep cycle came back like new
FollowupID: 348354
Reply By: Aandy(WA) - Sunday, Dec 19, 2004 at 20:21
So many things to worry about .... but it hasn't happened yet! If it does happen you'll have problems and you will have to disconnect and then replace the dead battery - but don't worry about it now!! Carry a third battery if it will put your mind at ease. But what happens if your starting battery fails? oh no but then you could also get 2 punctures .... or you could find coolant loss etc, etc ... DON'T WORRY and have a good holiday!
AnswerID: 89484
Reply By: Member - Jeff M (WA) - Monday, Dec 20, 2004 at 12:11
This could be an issue with some of the cheaper electronic battery isolators that only stop the flow of current in one direction when the engine is switched off. If you are using a smart relay (like the redarc or Arrid) this is not something that is going to leave you stranded anywhere.
If for example one of my batteries drops a cell, I'm going to get an alarm in the cab telling me that the system's voltage has dropped bellow 11.5V. Then I can turn the vehicle off and switch between the batteries to see which one has the problem, dissable it and run off one battery.
If my starter dies while I'm parked up and my vehicle won't start, I can check the voltage with a metre, say WTF disable it and rig my second battery to start the vehicle, run on one battery.
If my aux fails while I'm parked up I'm going to get an alarm saying my battery is going flat, I'll start the car and the voltage won't be increasing correctly, so I'll know something is not right, find the faulty battery and disable it.
So personally I can't see why it would be a major problem.
AnswerID: 89561
Reply By: Member - Bradley- Monday, Dec 20, 2004 at 13:29
with 2 in parallel, if one drops a cell, it will pull the charge put of the 2nd batt, easy enough to disconnect one at a time and load test them if you are worried. but if you find the dud one early enough on its way out then you can just disconnect and continue on one.
AnswerID: 89576
Reply By: Mainey... - Tuesday, Dec 21, 2004 at 13:11
Glenn,
We are talking about two "deep cycle batteries in paralel (12V) setup in the truck.
I was wondering what typically happens when one of them cark it?"
As both DC batteries are wired in parallel and disconected from the crank battery by an isolator till the vehicle starts and then the two good batteries will be scavenged by the dud battery.
Bradley stated,
"with 2 in parallel, if one drops a cell, it will pull the charge put of the 2nd batt, easy enough to disconnect one at a time and load test them if you are worried. but if you find the dud one early enough on its way out then you can just disconnect and continue on one" .......I could not have said it any better, so won't try.
AnswerID: 89744
