02 Jackaroo Clunking on hard lock
Submitted: Sunday, Jan 02, 2005 at 15:20
Jack fan
G'day all,
My 02 model jackaroo is clunking when you turn the wheel from hard right lock left again.
What could this be? Is it a simple rubber stop or is it something else
The car only has only done 30k and is not used in extremely difficult terrain.
Reply By: ats11279 - Sunday, Jan 02, 2005 at 17:59
Grease the steering stops?!
91017
Reply By: Patrolman Pat - Sunday, Jan 02, 2005 at 18:13
As ats said grease the sterring lock stops. My old Navara had the same problem, a dob of grease on the stops, (two each wheel) fixed it up.
91018
Reply By: locallaw - Sunday, Jan 02, 2005 at 23:48
Gidday,Give a bit more info.Is the jack standing still does the noise come from inside or outside.It sounds to me it could be a loose nut that holds the steering wheel on.It could also be a loose steering box.A bit more info and we can narrow it down.
Seeya Locallaw
91046
Follow Up By: Jack fan - Monday, Jan 03, 2005 at 08:08
sorry, it happens mostly when you are reversing out of the driveway or
parking. it also comes from the right wheel side of the car.
thanks in advance
349631
Reply By: locallaw - Monday, Jan 03, 2005 at 08:53
Gidday again,Still a little more info required.When reversing are you on full lock then go over the gutter or hit a bump.Is this when you hear the noise if do as above grease the steering locks on both front
wheels in behind the brake rotors.
Seeya Locallaw
91063
Follow Up By: Steviebee - Monday, Jan 03, 2005 at 23:56
Hi locallaw,
can you please enlighten me - what are these steering locks ? are they fitted with nipples ? what am I looking for ?
.... even if they seem ok, it seems to me that it is good preventative maintenance to give them a dob of grease so they don't become a problem.
Thanks, Steve
349767
Reply By: Steviebee - Monday, Jan 03, 2005 at 12:07
Hello Jack fan,
I currently also have a problem with a knock in my '99TD steering and have traced the source to one of the components in the steering column. Although your description is slightly different, it will only take you a couple of minutes to check to see if it's in fact from the same source. My knock has appeared after only a similar mileage.
I suggest you check out my answer ID 86319 to post ID 18162 in the archives. Check for the knocking with the engine off, and give me a shout if this could be the source of your problem.
Good luck, Steve
91082
Follow Up By: Jack fan - Monday, Jan 03, 2005 at 14:53
just went out and tryed but luckily there is no knock.
looking, it seems that i do have to grease the sterring locks.
thanks to all who repilied
349676
Reply By: Savvas - Monday, Jan 03, 2005 at 21:42
Mine does it too, always has. But only if it's pointed downhill, and coming off hard right lock at
parking speeds.
I never really worried about it. It's now down 90k and doesn't seem to have any other problem as a result.
91180
Reply By: Member - DOZER- Wednesday, Jan 05, 2005 at 08:17
Check all the drive shaft rubbers and if one is torn, that c/v is knocking...and you need to get it fixed yesterday.
Andrew
91382
