Hema and Oziexplorer
Submitted: Friday, Jan 21, 2005 at 16:50
Utemad
I have checked the archives and even rung Hema but to no avail as yet.
I am curious to find out how people find out what datum and projection Hema uses for its maps. They do not put either of these important bits of info on their paper maps. I have emailed them before and they have told me but haven't got back to me this time. They did tell me though that this info is not available on their website either.
I don't understand why such a prominent map making company does not include this info on the map itself. Lots of other map makes include it.
Reply By: sav - Friday, Jan 21, 2005 at 18:11
The Hema maps I have clearly state:
Projection: Lambert Conformal Conic
Datum: GDA94 (equivalent to WGS 84).
Sav.
94313
Follow Up By: Kings - Friday, Jan 21, 2005 at 18:50
I have the "Great Desert Tracks" series and they clearly state "Lambert Conformal Conic Projection" and WGS 84 Datum. Base data supplied by AUSLIG.
The information is in the title block on the top RHS of the sheet EG "GREAT DESERT TRACKS"
South East Sheet
353313
Follow Up By: Utemad - Friday, Jan 21, 2005 at 19:00
Just double checked my Hemas and still nothing.
I tried using LCC like you said however Ozi asked for
Latitude 1
Latitude 2
Central Meridian
Origin Latitude
Do your maps give this map specific info or do you need to figure it out?
When I did the Hema New Zealand South Island map it used Equidistant Conic projection. I can't remember if I figured it out or Hema told me. I just had a quick look at it and I think it wouldn't be too hard to figure out but it would be easier if they just told us. Last I talked to a Hema rep he was endorsing Ozi so they should include this info.
Thanks.
353315
Reply By: Kings - Friday, Jan 21, 2005 at 19:15
Sorry UTEMAD,
I can't help you with OZIEXPLORER functionality. I am about to pay for the licence and have a go at scanning my maps in. No experience as yet.
I am told that it is a laborious but relatively simple task.
There are plenty of experts around who read the
FORUM, so just hang on!
Kings
94318
Follow Up By: Utemad - Friday, Jan 21, 2005 at 19:32
Thanks all the same. It is not all that hard but it can take a while.
Well worth it though.
353319
Reply By: The Explorer - Saturday, Jan 22, 2005 at 00:56
Hello - which Hema maps/areas are you talking about - there are many. They may use different projections for different maps. Also the data required to define a projection changes as you move from area to area..i.e. more info required!
94365
Follow Up By: Utemad - Saturday, Jan 22, 2005 at 09:58
I realise that the info changes map to map which is why I think it should be printed on every map. However the map I am currently wanting info for is the 'Hema Tasmania Handy Map'. I scanned it before I went but didn't have time to stuff around getting this info. Therefore I just made it WGS84 and lat/long. Close but not that close.
Thanks.
353354
Follow Up By: Pluto - Sunday, Jan 23, 2005 at 09:43
I think you'll find that most Hema maps pulished prior to the GDT series have no references to datum and other calibration info. It wasn't untill GDT that they realised the value of including this info (lets face it, when you are using a paper maps as an ordinary road map, without relating it to a GPS, what use does the datum have? the only thing that matters in this case, is the noted distance between intersections).
I have scanned and calibrated a number of older hema maps without too much trouble, with the one obvious exeption. The original release of the Central Australia map was beyond me. I just couldn't get the map
grid and the Ozi
grid overlay to line up. I emailed Hema, who were as helpful as they could be. In the end the map was originally created by "rubber sheeting" a number of other maps with different projections. So the map was never intended to be to scale.
I don't believe they have practiced this method of map construction since GDT was released.
353448
Follow Up By: The Explorer - Sunday, Jan 23, 2005 at 12:11
Ok - as pointed out by others it may not be possible to calibrate the map to the level of accuracy you would expect. Have you tried using lat/long along with the "Use Polynomial Calibration for map" (found within OPTIONS on the menu availble when calibrating a map)
If this option is ticked OziExplorer will use 2nd order polynomial calculations when calibrating the map. This allows maps to be calibrated even if they are not truly square (linear). This is useful for calibrating maps where the true map projection is not known.
To use this option you must have 7 or more calibration points specified. If you can get enough points from the map directly use waypoints of known points (your own or use namesearch database).
Limitations - Using a polynomial calibration on a truly linear map can cause unpredictable results.
353464
Follow Up By: Pluto - Sunday, Jan 23, 2005 at 12:51
I can't say that it had occured to me. Thanks for the idea.
That only problem I can see with it is, this map will need more than 9 Calibration points. I believe Ozi can use up to 30 calibration points, but the thought of calibrating it with a text editor is a bit daunting.
353469
Follow Up By: The Explorer - Sunday, Jan 23, 2005 at 13:49
Pluto - If the map has variable scale across it (like maybe a rubber sheeted map would??) even the polynomial method may not work if applied to the entire map....can say I have used it much in the recent past. Maybe I missed soemthing but why more that 9 calibration points? For polynomial the more the merrier I imagine but 7 is the minimum requirement
Another thought...
If you do need to use more than 9 (because maybe the map is large or is really screwed up) maybe you could just calibrate separate areas as seperate map files and get away with using less calibration points (for each individual section..if you know what I mean).
Arrhh calibrating your own maps - what great fun!! Im slowly doing my 50K
Kimberley series..only ~300 to go!!
353472
Follow Up By: Pluto - Sunday, Jan 23, 2005 at 15:14
He He... Good luck!
Have a look at the Ozi help file. The section where it discusses file formats. I'm fairly sure it has a limit of 30 cal points per map (I can't check at the moment). Of course the internal calibration facility only allows you to access the first 9. In only extreme cases is 9 insufficient.
Your idea of calibrating sections of the map could also be taken one step further by, copying the calibration points from the different section calibrations and pasting them into a single map calibration file. Definitely worth experimenting.
353480
Follow Up By: Utemad - Sunday, Jan 23, 2005 at 20:53
Hi Explorer,
I tried using the polynomial and lat/long like you suggested. Just by looking at the track files on the map now I'd have to say it was pretty close to being right.
Thanks for the info.
353514
Reply By: Baz (NSW) - Saturday, Jan 22, 2005 at 20:13
Utemad the datum on a hemma map is underneath the scale bar.
Baz.
94447
Follow Up By: Utemad - Saturday, Jan 22, 2005 at 22:30
Thanks Baz however I just double checked and not on the Tassie map. I think I'll check for this info before I buy the map in the future.
Good work on the new LandRover too. Hope it serves you
353412
Follow Up By: The Explorer - Sunday, Jan 23, 2005 at 11:41
I doubt the datum (WGS84, GDA94, Aus84, Aus66 are your options for Australia) used to calibrate a map covering all of Tasmania would actually make any noticeable difference. If you happened to choose say Aus 84 instead of WGS84 the 200m difference would be undiscernible at such a scale. The problem utemad is having is with the projection.
353461
Reply By: David Au - Saturday, Jan 22, 2005 at 21:03
Many Hema maps have no projection or datum as they are not designed for navigation. They are graphic interpretations to show the roads and other general data for the best display layout, and hence not suitable for navigation.
If the map does not have a projection or display then it is generally not suitable for navigation. You can sometimes calibrate these maps to some for general use, but yes, you will find position inaccuracies.
Have a look at road maps etc. you get from RACQ, RACV etc. they normally don't have a projection or datum.
94457
Follow Up By: Utemad - Saturday, Jan 22, 2005 at 22:28
Thanks David. I was thinking along the same lines myself. Some RACQ maps don't have any form of coodinates on them at all.
353411
Reply By: Utemad - Tuesday, Jan 25, 2005 at 20:22
I got a reply from Hema. Pretty much what has been said above that it wasn't designed for computer use. However they have another range that is. I better buy the right map next time I suppose.
__________________________________________________________________
Our series of state maps are difficult to georeference due to the fact that they were made only to be paper maps and were never designed to be used as background maps in programs such as OziExplorer and you may find that the information shown on the map may not appear to be exactly in right place when using the map with a GPS unit.
However having said that you can still georeference them and the details for the Tasmania Handy map are as follows:
Datum: AGD66
Projection: Simple Conic
Central Meridian: 146°30’00”
Standard Parallel 1: 41°00’00”
Standard Parallel 2: 43°00’00”
Our Regional maps series have all been designed to used as digital maps, but each map has its own projection parameters so without knowing which maps you want to georeference it is difficult to give you the parameters that you require.
Hope this helps
Regards,
____________________________________________________________________
94875
