Bushranger Emergency Hand Winch
Submitted: Tuesday, Sep 17, 2002 at 00:00
Savvas
Has anyone had any experience with the Bushranger Emergency Hand Winch. (
http://www.bushranger.com.au/showcase.asp?page=item&id=50X00). It looks a bit light duty to me, at only 1500kg rating, but it could be handy in some situations. Any comments?
Reply By: les - Tuesday, Sep 17, 2002 at 00:00
Savvas,
Had a look at the website you mentioned. This looks identical to the light duty units I've seen at Autobarn / Reject
shop etc. IMHO don't waste your money. These are really little more than a fence wire strainer. When you need a hand winch you REALLY need it, so get something that'll do the job. I use a "Big Haul" winch. It's 3 times the size of the unit, yet rated to a realistic 1600kg. You can double that with a snatch block, to a usable 3200kg, but even then, pulling a stuck 4wd uphill is backbreaking work ! That's with the leverage of a 1.5m long steel handle ! I wouldn't imagine the unit you mention would cut the mustard.
Cheers, Les
6720
Follow Up By: Savvas - Wednesday, Sep 18, 2002 at 00:00
Thanks Les ... I've used a Tirfor to pull a 60 series Cruiser out of a bog. Not much fun! And we didn't have a snatch block around at the time, so it was a single cable pull.
3012
Reply By: Goran - Tuesday, Sep 17, 2002 at 00:00
The only situation that you can use this device would be reseting the tyre on the rim. That is it.
6729
Reply By: Savvas - Wednesday, Sep 18, 2002 at 00:00
Thanks guys .... I thought as much. Bushranger do some reasonable gear, so I'm a bit surprised that they'd be pushing this as a recovery item.
6734
Reply By: Juddo - Tuesday, Oct 01, 2002 at 00:00
I was at a show the other day having a look at the same bushranger hand winch. It is very light duty compared to a tirfor or the like. The price looks good, but if it is not useful, then I guess they are worthless and you should not waste your money. Cheers, Matt.
7078
Reply By: John - Wednesday, Oct 09, 2002 at 00:00
Savvas. Mate, I am a fully qualified Pannel Beater and have been for 10 years. I have been using this type of winch in my
shop in one form or another with upwards of 4.5t on these with the help of one pully. They may look weak as bleep but they can take a bloody good hiding, (BUT!) I belive the situation that may include the pulling of dead weight up an incline, out in the scrub
miles from any where, If I were standing next to that winch, I would want to be sure that it can handle it safely. I have just purchased a big haul and had to use it last week in that very situation. I think I did the right thing just for peace of mind. It's worth spending a little more money just for that. I hope this has helped.
7287
