What size air hose for arb compresors and what type of fitting?
Submitted: Sunday, Feb 13, 2005 at 10:47
Member - Toonfish
just wondering if anybody knows
What size air hose for arb compresors and what type of fitting?need to get some hose but not sure if they use 10mm or 8mm hose and wht fitting the use to connect to quick connector on compressor.
Reply By: Puddin & Gumnut (Sydney) - Sunday, Feb 13, 2005 at 17:16
G'Day Toonie, Just checked
mine & Looks like 8mm ryco but my eyes ar'nt what they used to be.
98147
Reply By: Member - Jiarna (SA) - Sunday, Feb 13, 2005 at 19:38
I just fitted my ARB compressor, and it came with an 8mm hose and nonstandard fitings. I am using my old 10mm hose with air tool fittings (Ryco I think). I just unscrewed the ARB one and whizzed it in the dump, and fitted my standard quick connect fitting.
Works fine with 10mm hose, although 8mm would take up less room. BTW, my 10mm hose is twice as long.
Oodnadatta
98172
Reply By: time waster - Monday, Feb 14, 2005 at 15:10
i used 6mm hose mainly folds up smaller and used the push button fittings but use 10mm from compressor to resivoir
tank
98302
Reply By: Member - Toonfish - Monday, Feb 14, 2005 at 17:28
thanks guys for the help.
found out by looking at the quick connector it was written "ryco 20l"
lmao
thats kewl so 3 connectos and a tyre inflator hose with a quick connect fitting .
used 10mm as it was easily available .
wanted a reduction connector and 8mm hose for less space but its all done now .
thanks again
"go exploroz!!"
98330
Reply By: Member - Jeff M (WA) - Monday, Feb 14, 2005 at 18:47
I used 3/8" High pressure
fuel line hose. It's rated to handle the under bonnet temps and is rated to 12 bar. I did have some std compressor hose on but it burst due to the heat. (I use a bluetounge but it's the same principle).
98346
