GQ drivetrain oils
Submitted: Thursday, Mar 03, 2005 at 17:43
Willem
I am looking for suggestions on which oils or grades of oil to use in my GQ front diff, rear diff, transfer box and gearbox. The gearbox and transfer box still run quietly but the speedo shows 282000km and as I bought the truck second hand I presume that the boxes are the originals . Should I put a thicker oil in? and if so which brand and grade.
Reply By: Wayne (NSW) - Thursday, Mar 03, 2005 at 18:25
Willem,
Just had a look at the Shell web site and this is what they recommend
Diff 75/90
Transfer 75/90
Gear Box 80w/90
The reason that I use Shell oil is that I can get it just about everwhere, that way if I do have to do a top up or change I am not mixing oils.
I know that you have a GQ but in the 80Series they recommend a very light gear box oil.
Wayne
100999
Follow Up By: Willem - Thursday, Mar 03, 2005 at 20:41
Thanks Wayne
359062
Reply By: GOB & denny vic member - Thursday, Mar 03, 2005 at 18:57
goodday willem
from the nissan patrol book for 1988-1997 patrols and ford replicas
1 thing always make sur rear diff is lsd oil
manual trans SAE 75W/90 GL4
auto MATIC D
transfer case SAE 75W/90 GL4
front diff SAE 80W/90 GL5
rear diff conventional & locking diffs SAE80W/90 GL5
LIMITED SLIP DIFF SAE LS80W/90 GL5
OR IN CONDIONS OVER 40c SAE LS140GL5
STEVE
PS DO WANT THIS BOOK AS I NOW HAVE THE GU
STEVE
101005
Follow Up By: Willem - Thursday, Mar 03, 2005 at 20:39
Interested in book will MM you
359060
Follow Up By: GOB & denny vic member - Thursday, Mar 03, 2005 at 20:53
willem you are welcome to the book but i have just realised you have a diesel and the book is for petrol( theres some silly buggers around )if you still want it let me know
steve
359063
Reply By: ExplorOz Team - Kerry W (QLD) - Thursday, Mar 03, 2005 at 23:50
Reply By: fisho64 - Friday, Mar 04, 2005 at 04:32
best to use the spec that the manufacturer recomends, thicker oil is not necessarily better. Imagine an oil pump with a relief valve set at (say) 80psi which then pushes the oil down a gallery into a white metal bearing. Oil enters the gallery at 80 psi whatever viscosity it is. But then picture the difference between the viscosity of (say) milk and treacle. One is going to come out the other end of the gallery at (say) 70 psi the other at maybe half that or less. This is a simplistic analogy but oil specs are worked out due to many variables and noone knows better than the manufacturer what they are
101069
Follow Up By: Willem - Friday, Mar 04, 2005 at 17:59
Thanks for your feedback. Much appreviated
359142
Reply By: fourstall2000 - Friday, Mar 04, 2005 at 08:41
It does not matter so much the brand but for the gearbox ensure it is GL-4.
If you use GL-5 which is more common you will have gearchange problems.
101079
Follow Up By: Willem - Friday, Mar 04, 2005 at 18:02
Thanks mate. Appreciate your advice
359144
