Calcium - Calcium Batteries.
Submitted: Friday, Apr 08, 2005 at 16:47
ThreadID: 21883 Views:3099 Replies:6 FollowUps:9
I probally know the answer to my own question here, but I have the option to buy a new 105Amp/Hr Calcium-Calcium battery for a good price through work as we have 3 extras that we didn't end up using for a job.
My thought is that it won't work very well as it would replace my 85amp/hr WetCell Deepcycle under the bonnet and being maintanence free would die quickly with the exccessive heat under my bonnet.
Am I right, or will it not make much difference weather it's hot or not.??
Reply By: Redback - Friday, Apr 08, 2005 at 17:33
No wrong, this type of battery comes standard in the Discovery and other Landies and so far ours has been in our Disco for 4 years it's an 110AH calcium battery a very good battery.
Baz.
AnswerID: 105752
Reply By: Wok - Friday, Apr 08, 2005 at 18:15
I believe there is a difference between Ca and Ca-Ca batteries, in their charging requirements. From memory, the voltage required for Ca-Ca is higher?
May pay to check your alt output first .
AnswerID: 105759
Follow Up By: Member - Jeff M (WA) - Friday, Apr 08, 2005 at 19:22
Wok, I know what my altenator output is, but what voltage would the ca-ca require to charge? We have been using them with our solar setups for running wirless security cameras and they work great, but obviously solar charges at 14.1v not 13.8 like most alternators.
But to be honest my deep cycle requires a higher output that the alternator is giving to fully charge anyway, so I'm more worried about the battery life/damage. I reguarly put the system on a 240v charger before and after trips to top it up anyway as it is.
FollowupID: 362893
Follow Up By: Wok - Friday, Apr 08, 2005 at 21:22
Have a look @ this link
Consensus is 14.8V for Ca-Ca, 14.2V Ca hybrid[depends on alloy]. Haven't been able to nut out AC Delco's specs...have seen it before!? I gathered that Ca-Ca are more finicky on charging & floating = prone to problems?
The solar reg should be adjustable for battery type; hence output voltages [ I think the better ones have 2/3 stage charging algorithm, if yours has fixed voltage I think that would be the float voltage?]
Ca-Ca is been superceded by AGM type?
FollowupID: 362912
Follow Up By: Member - Jeff M (WA) - Saturday, Apr 09, 2005 at 10:30
We use BP Solar 3 stage regulators, not sure of the exact specs but I know they have a regulated output for running gear directly off the regulator which is fantastic for us, it then back feeds the battery through the regulator once the solar drops down and we get a constant 12.0v. out of the unit to our gear (which is a bit sensitive at times). We were using cheaper 3 stages before and trying to run the gear direct from the battery but as you say when it's being boosted by the pannels it was blowing ourbleepup.
14.8v seems a little excessive for a vehicle, they are the ACDelco's that we use.
FollowupID: 362956
Follow Up By: Wok - Saturday, Apr 09, 2005 at 20:02
The 14.8V appears to have been used by GM in USA[ bear in mind the colder the ambient, the higher the bulk voltage] it certainly wouldn't be this high in Oz. I have not been able to track down the float voltage for AC Delco ca-ca battery which would be more appropriate for alt charging.
Another bit of trivia came out - the full charge voltage of ca-ca is 12.4V.
I have the impression that the bulk voltage of your solar reg is set low to protect the load. If this is so it is unlikely the ca-ca bank is receiving full charge [ unless the regulator has a seperate reg output [12V] for the load which is activated when the solar reg is in bulk stage]
IMHO the ca-ca batt is not a good idea for vehicles....check the links
Traction charger
more guff
The Traction link speaks volumes
FollowupID: 362999
Follow Up By: Member - Jeff M (WA) - Saturday, Apr 09, 2005 at 20:13
Yeah the regulator has three sets of terminals. Input (from pannel), battery and 12v regulated.
FollowupID: 363001
Follow Up By: Wok - Sunday, Apr 10, 2005 at 04:25
Impressive reg.
I agree with your comment about underbonnet temps. IMHO the biggest killer of batts[ just ignored because its so hard to resolve]
FollowupID: 363029
Follow Up By: Member - Jeff M (WA) - Sunday, Apr 10, 2005 at 22:37
Yeah they are pretty kick ass reg's, we had heaps of problems as our digital recorders use Computer Hard Disks which run normally of a regulated switch mode PSU with +/-5v and +/-12v. The problem is most of our units are 240v with there own internal switch mode PSU's. The ones we use off solar had to be 12v, so the 12v rail is not regulated, only the 5v. Plug it onto a battery getting a "boost" charge from a solar regulator and bye bye hard disk drive! :-O
We played around with our own ULV Regulators but they too were causing their own problems with the varying voltages from the battery (overnight mainly when the voltage dropped below 12.5, then the reg would shut down). Ended up finding these BP regulators, works a treat! And it's all in one unit!
FollowupID: 363137
Reply By: 80scruiser - Friday, Apr 08, 2005 at 22:15
I run a calcium battery for my main starting battery but not my accessory battery. I still use a deep cycle battery for that.
The calcium batteries don't like being run dead flat. No good for running fridges and putting in old ladies cars, the ones that don't drive. My supplier gives me a three year warranty on calcium batteries.
AnswerID: 105802
Reply By: Mainey (WA) - Friday, Apr 08, 2005 at 22:44
Jeff,
tell me some more about the battery... Brand, model etc...
AnswerID: 105807
Follow Up By: Member - Jeff M (WA) - Saturday, Apr 09, 2005 at 10:31
AC Delco 100/105 amp/hr 550CCA Calcium-Calcium battery.
FollowupID: 362957
Reply By: WWAB - Saturday, Apr 09, 2005 at 10:24
HELLO, JEFF
HAVE A LOOK AT CHALLENGE BATTERIES IN OSBOURNE PARK,I GOT A
90 AMPHR DC-AGM DEEP RIVER BATTERY..CHECK-OUT DEEP RIVER BATTERIES
ON THE NET TO RESEARCH WHAT WOULD SUIT YOUR NEEDS.
AGM BATTERY CAN TAKE A HIDING DISCHARGE ALOT & PUT IN A HIGH CHARGE VERY QUICKLY---AGM WERE FIRST DESIGN FOR MILITARY USE. STILL COST MORE THAN A STANARD DC. SAME OLD SAYING," YOU GET WHAT YOU PAY FOR"
ADRIAN --WW35---PERTH.
AnswerID: 105856
Follow Up By: Member - Jimbo (VIC) - Saturday, Apr 09, 2005 at 10:51
Adrian,
Do you mean "Full River"?
Jim.
FollowupID: 362959
Reply By: WWAB - Saturday, Apr 09, 2005 at 11:00
SORRY -JUST WOKE UP
--FULL RIVER-- BATTERIES IS RIGHT
ADRIAN
AnswerID: 105865
