glow plugs
Submitted: Tuesday, May 03, 2005 at 19:34
glowing-hot
hi all, just trying to find out what glow plugs are orig for my nissan 1995 rx 2.8, i realise there is two diff types.thanks.
Reply By: 80scruiser - Tuesday, May 03, 2005 at 21:44
Trying to rack the brain cells about this one.
I went through this with a customers one some time back. From memory I had to remove them to check the voltage's on them. I think one is 11 volts and the other set is alot lower but can't remember.
Best of luck
109524
Reply By: crfan - Wednesday, May 04, 2005 at 10:05
Hi Glowing hot,
the origanal plugs are NGK cylinders 123 are cx01 (NGK)or cp70 HKT (6.5v)
cylinders 456 are cz01 (NGK)or cp71 HKT (6.5v)
hope this helps.
Retail for the the cp70 is about $22 and cp71 $30. from Coventrys.
109584
