More on Fat tyres and the coeficient of friction.
Submitted: Thursday, May 19, 2005 at 18:08
robak (QLD)
Well, I got a response from Bridgestone re post Other Ideas on Tyres
Just like we tought
- THE MORE RUBBER YOU GOT - THE LESS RUBBER YOU LEAVE ON THE ROAD.
Hi Robert,
Quite an interesting thread on the web
forum. Thankyou for your enquiry. There are certainly some good points of interest.
I believe that the thread has been started by someone who has been studying pure physics. Looking back on one of my text books from my university days (Serway, Physics for scientists and engineers) it does state that co efficients of friction are nearly independent of the area of contact between the surfaces. One would imagine that this is correct for relatively smooth and flat surfaces.
If you consider the tyre / road contact patch then there is definitely a degree of mechanical influence from tread design interacting with the typically coarse road surfaces which we have in Australia. A wider tyre will allow more flex free grooves and ribs to be incorporated into the design, providing additional mechanical grip with the coarse road surface. Sidewall strength will also play a large part just to make things a little more complicated.
Tread compound will generally be one of the biggest factors affecting the friction co efficient of a tyre. If we considered F1 slick type tyres pre groove days acting on a smooth road surface then the pure physics would come into play where contact area would have little effect on friction force. Additional width in such a case would be of benefit to increase the shear force required to overcome the shear strength of the tread rubber compound (Shear strength is equal to the Shear force divided by the contact area. If area is increased then more force ie engine power is required to shear the tread compound of equivalent shear strength.) This is why the skinny tyre on the XR would leave a lot of rubber on the ground due to rapid acceleration. The power of the engine easily overcomes the shear strength of the tread compound acting on a small surface area and subsequently leaves a large amount of rubber on the road surface. Also, in general a sticky race type compound will wear at a more rapid rate. By increasing the width, the tyre footprint size will increase, and road pressure will decrease for improved wear life.
Tyre design in real world conditions is definitely much more complicated than outlined above due to many factors including expectations on wear life, vehicle design etc
Hope that this helps.
Happy motoring.
Darryl Moliere
Technical Field Service Engineer (Qld)
Bridgestone Australia
Reply By: Exploder - Thursday, May 19, 2005 at 18:27
Good on him for taking the time out of his day to read the responses and give a answer.
111954
Follow Up By: Member - Blue (VIC) - Thursday, May 19, 2005 at 18:41
I'll second that, in his position I would probably just disgarded the whole affair as Too many variables, too many opinions, too bluddy hard... As I'm not in his position, I appreciate the response.
368317
Reply By: F4Phantom - Thursday, May 19, 2005 at 19:43
Yes, thanks Romak for asking him + the guy getting back to us, you all should probably buy his brand of tyres from now on. So basicly, more material can be a good thing, especially if the compund does not change. This may mean that if your going out to buy a new set of tyres, buy the wider ones, they will likley last longer.
111971
