Thursday, Jun 02, 2005 at 08:11
G'day Scotty,
I have a 92 80 Cruiser on dual
fuel. I boughtthis in Feb and was going through similar debates with myself as you are.
In my opinion, if you are doing lots of city k's, it is impossible to look past lpg - just too cheap to run a 4500!
I found
mine already on gas, so was happy. However l have since found that my
tank runs out of it's 10yr certification this year - they will check this in a roadworthy (in Vic anyhow). Shortly after l had an issue with not being able to idle on lpg. This turned into an $1100 recon of all the rubber diaphragm etc in the lpg side of the
fuel system.
To some up, yep it looks like a deal to find one fitted already, but check it's age and service history.
Mine has probably cost me 50% of a new installation.
Also, if you buy one already converted, make sure that the two pipes which used to connect to the sub
tank are blocked off. If not, you run the risk of petrol gushing out, when climbing a modest
hill with a full
tank. This happened to me also!
The car is fantastic now though. I use
mine in the bush and as a daily driver for 250km per week. You'll hardly notice a difference on gas, but as stated before the consumption is a little more.
The lubricator you mentioned is a good idea, but don't get too wound up about it! LPG is a dry
fuel, so that is why lube kit is recommended. I do not have one, as the valve seats are hardened anyhow and in a truck that has done some good
miles, you will not reap the reward. Save the money on the lube itself (kit is cheap) and put it towasrds having the head (valves etc) reco'd when it happens - maybe 10yrs away!
Look out for prices of the cars too, you can find the 4500at about 15k now!
Hope this helps
Beast of Bodmin
114046
