Sunday, Jun 26, 2005 at 09:01
As one who has had both an engine and turbo blow up (
well documented on this site)I still believe the Nissan is a great truck.
Mine an early 2000 had all the problems that have given the 3.0 litre its bad name,but you cannot ignore the fantastic power and torque that this engine provides,terrific economy,towing ability, and driveability.
Why would Nissan persist with this engine except for the above features?
They new that once the problems were solved it would be the most suitable for this new age of cleaner fuels and high tech diesels.
Although you could criticise Nissan for the way it avoided a recall,no one that I know who had an engine failure in the early models was not provided with a new engine,even
well out of warranty.
It was quite clear with the sump increase and other attempts to cure the problem Nissan was at a bit of a loss as to how to address the failures,I believe at least 3 different pistons were fitted before the oil starvation to the upper cylinders was found to be the fault.
Personally I would not buy an early model unless the engine had been replaced,otherwise pick anything after the end of 2002.
For the people driving the earlier models and claiming 70,80,000 with no problems,keep up the extended warranty and write to Nissan stating you have the problem affected model, and wish to register your concern on their records.
Most failures it would appear are after 100,000 kms (
mine 118,000).
In summary,I tow an 18ft van, and regulary tour the outback in the club scene,the Nissan has a great record for build strength and reliability and with the rise in
fuel costs is most worthy of your consideration,just pick the year carefully.
Regards and good luck.
117495
