Monday, Sep 12, 2005 at 18:58
Hi G.T.
To answer your questions first,
How Much?
I think, around $50 all up. The relays were about $11ea and the switches about $10ea.
Who fits them?
If you don’t think you could do it yourself, then you could take the circuit to an auto electrician, and I’m sure he would do it for you.
Can all autos have them?
Certainly all or most autos with electric lock up converters should be suitable. I have fitted them to Nissan and Turbo700 transmissions, and I know you can get a kit for the Landcruiser also.
Any other relevant info?
If your considering fitting it to a 4 speed GU Patrol, then most of what you need is HERE.
If you are after a kit, you can get one HERE, but believe me, they are easy to make up, and all the parts are readily available.
The kits that you buy from Wholesale Automatics are a bit basic in that they only allow you to turn the converter lock on and off through a dash switch. The one that I have is switched on with your left foot and off by touching the brake pedal. I prefer to do it this way because it allows you to lock and unlock while shifting gears, as
well as unlocking every time you use the brakes to stop, so you don’t stall the motor.
There is a bit more info on Post 26261 and if you need any more help, you can call or email. My details are on my website.
HERE,z</a
384179
