Saturday, Dec 28, 2002 at 01:00
an interesting point you have mentioned. Firstly a comparision between the terrain of the two areas would not be fair. The incident at Como had very steep terrain, horrendous winds, very high temperature coupled with very low humidity. I would think, from what I've seen of the
Big Desert NP this would not be a valid comparision.
It wouldnt matter where it was, if you have horrendous winds, very high temperature coupled with very low humidity you have problems. Ive seen grassfires on flat ground go faster than we could. by LOTS...
I know BD wouldnt be hilly like The bank of the Woronora River, but it was a point I was making.
Secondly you have mentioned that Como had not been burnt in 30 years. Most likely true, would that be true of the mentioned NP?
Does it matter? 2-3 yrs can build up some insane
fuel levels under the right conditions.
One thing that has been puzzling a few poeple that I know is why the RFS had not conducted a harard reduction in Como (or the surrounding areas) before?
Ask the Greenies.
Interesting that you mention those qualifications.......funny how the RFS personnel always feel compelled to do this.
what you would rather I said this is my point of view but Im a moron with no idea?
Just for the record, I agree with the original statement that there is not reson to get all hot and sweaty, property protection is formost, let the rest burn as long as it's not impacting on communities.
Property protection is not always possible when you have a wild fire blasting through... No matter how many men and tankers you put infront of it. Burning off is not always possible either with NPWS, Scum Greenies(think of it if your house burnt to the ground and someone said oh
well..) which stop things, but when the fire goes thru them trees burn anyway!!!
Flames 12 mtrs high or more, stand next to your house, and look up, then imagine 100's of degrees C (which in reality you cant nobody can) and things explode before the flames actually get there from radiated heat. trees, houses, cars, etc they just go boom....
if theres NO way that anything can burn from this fire, houses, schools buildings of any sort, then bleep it, let it burn if you wish...
Again YMMV..
5351
