heat exchangers
Submitted: Thursday, Jan 02, 2003 at 01:00
ThreadID: 2781 Views:2188 Replies:9 FollowUps:4
has any one heard of helton heat exchanger or is using one.i found helton heat exchangers on the net they are a qld company and sell them for $99 with a 2yr waranty just wanted to hear anything about them before i spend my money thank you
Reply By: Member - Melissa - Friday, Jan 03, 2003 at 01:00
Diamond,
What are you planning on using it for...a car shower? Have heard of them for this use. Considerably cheaper than the Glind or Twine but don't know if they are as good.
:o) Melissa
AnswerID: 10474
Reply By: wazza - Friday, Jan 03, 2003 at 01:00
Diamond,
I guess this is them:
http://www.airequip.com.au/helton.htm
Just in case anyone else wants to have a squiz. I am interested as well now...
Wazza
AnswerID: 10477
Reply By: rodeoowner - Friday, Jan 03, 2003 at 01:00
Well, that looks like the go. How much is the Twine unit all up? If you bought the Helton heat exchanger ($99) and a Shurflow pump ($160), hoses ($30??) shower rose and hose ($20??), then say at $300, is that cheaper?
Or you could lose the Shurflo pump and get something cheaper.
I am a Gas Technician by trade so can make one myself with copper, but with labour I don't reckon you could get one made for $99.
Someone buy one!!
AnswerID: 10490
Follow Up By: Member - Melissa - Friday, Jan 03, 2003 at 01:00
My thoughts exactly...someone buy one and let us all know!
It's got me thinking. Glind and Twine use the Flojet and Shurflo pumps. Does anyone know of a cheaper alternative with a good name. If you could get something that would give you an in-car shower for under $300.
:o) Melissa
FollowupID: 5530
Twine is $380 on this site.
Is anyone else having trouble getting to the models, installation & specs page of the Helton website? I can get their main home page, but not these other pages.
AnswerID: 10491
Reply By: geoff - Saturday, Jan 04, 2003 at 01:00
Hi diamond I was looking at one of them as well and am going to buy one . I have a bildge pump and a shower head I used to use when I had a old heat exchange fitted to my holden HQ.I don't have the heat exchange anymore but I have the rest of the stuff. The pump works well it pumps out 20L in around 3m.I let you know how it goes.
Regards Geoff
AnswerID: 10556
Reply By: Brian - Saturday, Jan 04, 2003 at 01:00
Droped in to see the Guy at Healton heat exchangers just before Xmas!
They look verry good I saw the unit mounted on their Cruser troopy. Had been sitting for an hour and the water was HOT!(couldn't hold hand under) They use it on a regular basis for camping and hand washing on the job. He uses his vehcle mount air compressor to presurise(10psi) a small water tank so no pump! They come in several hose connector formats depending on the setup of your heater hose's. I will be buying one as soon as I get my new Patrol. Give the guy a call he is eay to talk to.
Brian
PS no affilation
AnswerID: 10558
Follow Up By: Michael - Sunday, Jan 05, 2003 at 01:00
Hi Brian, Was their troopy a petrol or a diesel, if their's was petrol and you are going to get a diesel the output temperature will be vastly different. The diesel runs much cooler, the 4,2 patrols run even more cooler than the diesel landcruisers. Hope this helps
FollowupID: 5589
Follow Up By: Brian - Tuesday, Jan 07, 2003 at 01:00
Yes it was a Diesel and no I did not know Patrols ran cooler! I believe I will still get one but may have to re think the way I install it
Brian
FollowupID: 5685
Reply By: diamond - Saturday, Jan 04, 2003 at 01:00
thanks for the replys i think i will order one on monday i phoned the guy this morning and was quite happy with what i was told .its only $99 and ive drunk more than that in one night lol so if its good you will hear about it and he might sell more and if its not you will also hear about it lol
AnswerID: 10559
Reply By: tourer - Sunday, Jan 05, 2003 at 01:00
This one caught my eye as I was scanning the forum. So I checked out the Helton website. Maybe it's just me, but they make some pretty good claims about their unit. One pass of water and it heats to 50-60 degrees.
That seems almost too good to be true for a unit that is 100mm shorter than the Twine unit but the same diameter.
Maybe they do with a slower flow rate.
AnswerID: 10585
HI Tourer, they probably have more copper tubing in them,Instead of having a single row coil , they may have a innner coil, allowing the unit to be shorter with an increase in length of copper tubing. Michael
FollowupID: 5590
Reply By: helton - Monday, Jan 06, 2003 at 01:00
hi
sorry to be so hard to find. The Helton site has only just been activated on the web and all bugs will be gone soon.
We have a fourth model coming shortly which is suited to Land Cruisers and Patrols.
Please feel free to contact us on 0428 118 012 or fax 07 3881 3826 or
Heton Heat Exchangers
mail@helton.com.au
www.helton.com.au
AnswerID: 10666
