Range Rover Overheating
Submitted: Tuesday, Jan 07, 2003 at 22:41
ThreadID: 2848 Views:6780 Replies:8 FollowUps:6
Some Range Rovers have a problem with over-heating. This seems to happen when climbing long steep hills, especially in hot conditions, presumable meaning that the air-flow through the radiator is inadequate to allow proper cooling, even with the engine running at high revs.
Does anybody have experience with a suitable replacement radiator, or other modification to Rangies to keep them running cool in the toughest conditions? Mine is a 4.6 EFI in a '85 model.
Steve
Reply By: OziExplorer - Wednesday, Jan 08, 2003 at 09:35
Steve there is quite a range of different radiator cores available. Any proper radiator shop would be able to fit one of these higher efficiency cores, or even a core with more depth. In many cases you can fit a radiator quite easily from say a Holden or Ford V8 with very little modification, as it is easy to change the outlets on a radiator. These are often around a 1/3rd price of a Range Rover specific core. Find a helpful competent radiator repair shop, or better still try a few different ones and what they have to offer. If this is a problem on those vehicles, they may already have a proven fix.
AnswerID: 10806
Reply By: Truckster - Wednesday, Jan 08, 2003 at 11:30
How long have you had the car, or do you know its history?
Has anything ever been done to the cooling system?
Has the problem just started, or always been a problem?
Is it leaking at all?
Doesnt always mean its not getting enough air, could be worn water pump, or clutch fan gone, or just full of crap!
Theres lots of things to check before you go dishing out $400-800+ on a new Rad. Remember this model/style radiator worked well for years in Lots of Rangies... But now it could be 17yrs old(Doubt it thought!!).. Could be time to replace, but first check a few things.
Physically remove it from the car. Then hose the fins out, you can't get to the complete rad to hose it out while its on the car. I did mine on the weekend while doing a clutch fan, and the amount of crap that came out from behind the Cowl, and air cond cooler... I thought it was clean before that!
Next, turn upside down so the filler cap is on the ground... stick the hose in the bottom of the rad, so the water comes out the filler cap(which is at the ground level)
You could even while its out take it to a radiator place to get it checked for blockages inside.. My original one was 35% blocked inside... But Id try the other things first.
Other things you can do that are cheaper,
Check fan belt tension on the water pump.
New Coolant
Thermostat
Radiator Cap
Radiator hoses
Temp Guage Sender
Temp Guage!
You could change all these and keep the current ones as spares.
Not so Cheap are
Water Pump
Clutch Fan(if they have one)
All could be old, and just due for replacement.
As for where to get replacement radiator... ANY radiator shop. or you can get special Desert Racer style ones but then your lookin at $1500ish!
Another thing to do is, get one of the 4b magazines, and ring a few of the Rangie places that run ads in them. They could have upgraded rads in stock.
Where do you live??
I got mine for my GQ from Seaford Radiators in Seaford.. Ask for Sid.
AnswerID: 10815
Reply By: Gary - Wednesday, Jan 08, 2003 at 12:52
One thing that has not got a mention yet, is it an auto if so you may want to check the oil cooler lines from the rad to the oil cooler or Radiator as the case mybe.. If they have being hit by rocks and crimped in anyway then this will also give you a high temp reading without the engine actually overheating. It would mean the Rad just can not handle the extra heat coming from the trans. The lines dont need to be crimped by much.
Just another thing to think about.
Hope it helps.
Gary
AnswerID: 10824
Reply By: Steve - Wednesday, Jan 08, 2003 at 18:24
Further information on the setup:
The engine is new, has extractors, and extra bonnet vents, the
radiator is in excellent condition, and was recently replaced with a 3 core high-efficiency design to try to stop the overheating problem. The
thermostat is new (89 degrees), the gauges are calibrated and accurate. The viscous coupling on the fan has been locked up, there are two electric cooling fans in front of the radiator. They all work correctly, and are thermostatically controlled, not just from the air-conditioner circuit.
The cowling is fitted correctly, and the rubber seals between the condenser and the radiator are in place. The overheating only occurs at high engine loads when the vehicle is moving slowly (high revs, but low forced ventilation speeds)
The water pump is in good condition.
AnswerID: 10842
Follow Up By: Gary - Wednesday, Jan 08, 2003 at 22:56
The engine is new, just how new. Is it a recon engine, how many Kms since replacement, who did the engine. Since the engine has been removed what else has changed..it may be something very simple.
FollowupID: 5847
Reply By: Darryn - Wednesday, Jan 08, 2003 at 20:22
Steve fit an external engine oil cooler and if its an auto fit an external tranny cooler as well. I have seen various overheating vehicles helped by oil coolers and tranny coolers in the bottom radiator tank are one of the worst cheap and nasty things the auto industry does to save money.
Regd's Darryn
AnswerID: 10854
Follow Up By: Steve - Wednesday, Jan 08, 2003 at 22:28
I have fitted the vehicle with a good quality Engine Oil Cooler as well. The auto trans. cooler is separate from the radiator. It is the RR genuine external type (circular) that is mounted in front of the condenser. None of this has solved the overheating problem.
Back to the drawing board...
FollowupID: 5843
Reply By: Eric - Wednesday, Jan 08, 2003 at 23:00
Steve.
The first thing to check is the bottom radiator hose temperature. If the bottom hose is cold it tells you the radiator is cooling the water but the water is not circulating fast enough, if the bottom hose is to hot that means the water is circulating but the radiator is not cooling it enough.
There are some good pionts in previos posts but the one about kinks in the transmission oil lines is complete crap, blocked oil lines will cause transmission over heating only. Eric.
AnswerID: 10878
Follow Up By: Gary - Thursday, Jan 09, 2003 at 14:49
Eric,
It is not crap, before Steve told us his setup most autos run their oil through the base of the radiator for cooling. If you have a kinked line YES the trans over heats but that heat need to be taken somewhere and that somewhere is the radiator..try it some time !!
FollowupID: 5890
Follow Up By: Gary - Thursday, Jan 09, 2003 at 14:50
Eric,
FollowupID: 5891
Reply By: brian - Thursday, Jan 09, 2003 at 06:59
Hello Steve, i see everyone is focussing on cooling system,could it be minor leaking head gasket,or remotely possible to have porous cyl head,you said it was a new engine,if rebuilt did the heads need retensioning after initial running in period,just a thought.
if cooling system proves ok i would be looking for the source of the excess heat you seem to have.
AnswerID: 10887
Follow Up By: Steve - Thursday, Jan 09, 2003 at 09:38
I'm not losing any coolant at all, have no white death in the sump, and no bubbles in the radiator. This makes me think that there is no problem with the heads (they were rebuilt, and surfaced before engine reassembly).
My guess is that the collant is travelling too fast through the radiator, and not having an opportunity to enough exchange heat (the three core design would mean that collant travels throguh the radiator faster than a larger core size). This means that the coolant re-entering the block is too hot. Faster rammed air speeds (e.g. highway), overcome the problem. I think a (much) bigger radiator is possibly the answer.
Thanks for the tip.
Steve
FollowupID: 5874
Reply By: brian - Thursday, Jan 09, 2003 at 09:11
Steve,forgot to ask did you have overheating with the first engine as well as the second??? is this why you have vents in bonnet??
AnswerID: 10891
Follow Up By: Steve - Thursday, Jan 09, 2003 at 09:42
The first engine did overheat very slightly, but I think that this is not uncommon to Rangies. The replacement engine is 4.6L (against 3.5L), so everything is working harder to keep up anyway. The bonnet vents were added after the second engine was installed, but have not helped much.
Steve
FollowupID: 5875
