Coleman/Primus as base for weater heater
Submitted: Saturday, Jan 28, 2006 at 14:02
Member - Collyn R (WA)
Am considering using a Coleman or Primus shower heater as basis for simple general
water heating in our TVan. Concept is to connect via
tank and larger pump, then plumb to sink etc. Also connected to larger gas bottle.
Heater would of course be external
Would appreciate comments from anyone who has done this - there are a few comments in the archives - but nothing current.
Collyn Rivers
Reply By: Dilligaf - Saturday, Jan 28, 2006 at 14:17
I had a Primus and now have a Coleman. Primus is overall poor design and implementation. Coleman works as described and gives instant hot
water quickly without stuffing around. I have our Coleman connected to a larger
water tank with pressure pump and also a quick disconnect gas fitting to a 9kg bottle that is AGA approved that looks like a Ryco air hose fitting.
To put it succinctly the Primus takes a lot of stuffing around, the Coleman you twiddle
the knob and you have hot
water. Is that simple enough for you?
151465
Follow Up By: Shaker - Saturday, Jan 28, 2006 at 14:57
The reason that I didn't buy the Coleman in the first place was that the accessory gas hose was not available in Australia.
But, I too must admit that I like the general portabilty of the self contained cannisters. We found the Primus to be fiddly to operate & annoying in the extreme with its over temperature gas shut off.
405102
Follow Up By: Dilligaf - Saturday, Jan 28, 2006 at 15:04
Shaker the accessory gas hose is available in Australia and they arrived 6 weeks after the hot
water systems. Coleman has a 1800 number you can phone and that is what I did when I wanted to know about the gas hoses. You can refill the Coleman canisters with an adapter you buy from the US. I use a 9 kg gas bottle with our and our friend refills the disposable gas cannisters 10 times as they recommend in the instructions that comes with the refill adapter.
405104
Follow Up By: Shaker - Saturday, Jan 28, 2006 at 16:31
I can assure that they weren't available for quite some time after the HWS was released in Australia, which is why I made the initial mistake of buying a Primus.
My comment was that after thinking that it was necessary, I find that I prefer the disposable cannisters.
I mus admit that I have never heard of the refill adaptor & would appreciate more information & how much is each refill?
405115
Follow Up By: Shaker - Saturday, Jan 28, 2006 at 16:36
From the Coleman website:
PROPANE
FUEL - 1 PACK
Model No: 5103A164T
· All new lightweight and portable
fuel source, a more convenient way to
fuel a wide range of
camping appliances
· Allows the user to run multiple LPG appliances without heavy cylinders
· Ideal emergency reserve when your standard cylinder runs empty
· Safe & self sealing, so you can remove whenever you choose
· Non-refillable
405118
Reply By: Shaker - Saturday, Jan 28, 2006 at 14:17
I have owned both ..... Coleman is heaps better!
151466
Reply By: Andrew (Whyalla SA) - Saturday, Jan 28, 2006 at 14:25
Collyn
I bought a Coleman before xmas for our High Country trip.
First thing is that its plastic and quite bulky - sorry to state the obvious. LOL
I was using it as a shower and the pump was lifting approx 1m with excellent flow.
The self ignition worked
well and gas use wasnt too bad although I havent finished the disposable gas bottle yet to be sure. It has done about a dozen showers plus a LOT of playing around with it. I also have the hose that allows it to run off of normal gas bottles but I quite like the self contained nature of using the Coleman bottles. Disposable bottles are wasteful though.
Its a good product Collyn, if its bulk can be accommodated.
regards
Andrew
151468
Reply By: ACDC - Saturday, Jan 28, 2006 at 14:52
Have a look at this site you may pickup some ideas!
www.zodi.com
151472
Reply By: ozdragon - Saturday, Jan 28, 2006 at 16:26
Hi Collyn
The other thing to remember about the Coleman....10yr warranty.
151481
Reply By: allblack55 - Saturday, Jan 28, 2006 at 16:40
Hi Collyn,
The Primus Hot Shower unit is a much maligned product, I have spent considerable time investigating its shortcomings and their potential solution(s), I have one and think it's great for our requirements.
Contact me direct if you would like some details.
sunelec@netcon.net.au
Leigh
151482
Reply By: wheeler - Saturday, Jan 28, 2006 at 16:44
Leigh
I would be interested in your remedies. Why not post em here for us all to see.
Cheers :-)
151484
Reply By: GoLucyVan - Saturday, Jan 28, 2006 at 20:39
Hi all,
Last month in QLD (we are from SA) they had both gas leads [POR? and the other method of connection (3/4") thread ones?] to connect the coleman hot
water system directly to a 9kg gas cylinder. We also got the garden hose type pressure attachment to connect the system to a normal hose. This is the beginnings of the system we are putting in our caravan with two hot
water outlets - one over the sink and with a T-piece to the outside to connect into to a shower tent. We will eventually get a gas fitter to connect to the caravan gas supply - probably near the stove hotplate gas line.
regards GoLucyVan
151520
Follow Up By: The Tinker - Saturday, Jan 28, 2006 at 22:53
The stove hotplate in a caravan uses low pressure gas and is piped after the regulator on the gas bottle. Your Coleman hot
water system requires high pressure gas. You can run from a separate gas bottle, or you can purchase a lump of brass you can put on your gas cylinder so you can have your current regulator as
well as the high pressure connection for the Coleman.
405165
Reply By: Member - Collyn R (WA) - Saturday, Jan 28, 2006 at 21:54
Thank you for assistance everyone - most helpful.
Have managed to pull most details off Coleman website. But no measurements are given. Couild someone give me the dimensions and approx weight please.
Collyn
151537
Reply By: brett - Saturday, Jan 28, 2006 at 22:19
Front to back 420mm including knob
height 410mm
width 220mm
weight with pump and no gas cylinder 9.7Kg
Yes it's bulky but works very
well, no problems with overtemp cutout as it doesn't happen till 70deg C then it automatically reignites when the temp drops. Have used
mine with a 12V pressure pump and the mains
water adapter, works very
well, no problems with the pump priming and if you tweek the regulator inside the adapter you can get more flow.
Even though your not meant to refill the cylinders I have done several with no problems, the Yanks have been refilling them for years. Just check the valve is not leaking after refill and that's it. Even non refilled ones can leak if screwed on and off many times and it has a dodgy valve. Got my adapter off EBay. Worse case is if the cylnder is overfilled the valve will vent gas, this has never hapened to me, it's no more dangerous than filling your car up with petrol. Just observe some basic safety and enjoy your 70 cent gas refill instead of $6.95.
151541
Follow Up By: Member - Collyn R (WA) - Sunday, Jan 29, 2006 at 11:39
Thank you Brett - and everyone else. Will give it a go.
Collyn
405201
Reply By: gonebush SA - Monday, Jan 30, 2006 at 21:43
i must put in my 2 cents worth, we bought a primus
water heater and haven't regretted it for one minute. yes for the first couple of lights it took some getting use to then we played around ignored the instructions and now it's so easy to light first time every time and we have never had a problem with the
water cut off. we too were tossing up between the coleman and the primus and we are glad we got the primus. good luck.
151934
