electric over hydraulic actuators
Submitted: Sunday, Feb 05, 2006 at 16:05
ThreadID: 30454 Views:4811 Replies:6 FollowUps:1
Am currently checking the various options for interfacing the hydraulic disk brakes on my new trailer to a Tekonsha Prodigy controller.
I would appreciate technical comment from any trade or other readers who have practical knowledge/experience in doing so using either the new Dexter (DX series) , Master Brake or Titan systems (1400-1600 psi): in particular re the interface between the actuator and the controller.
The Titan seems the best bet (and is the one I hope to use) but am having difficulty in getting confirmation re the interface to the Prodigy controller
Apologies for the specialised nature of this query but there are very few of these systems in use in Australia - and reliable info is hard to find.
I gather that Kimberley Kamper use the Carlyle system - but gather this needs an additional interface?
Collyn Rivers
Reply By: Lone Wolf - Sunday, Feb 05, 2006 at 19:19
Collyn, I think you've stumped us all mate!
Here we have, the epitome of our own Dr. Karl on EO, asking for our help. Your question may well go down in EO history, as never being answered, sort of like a Buddhist koan.
I am guessing the answer, if there is one, would be around say..... 42
I ran it thru the Babel Translator, and still couldn't understand the ramifications. Oh, that's the internet Babel, not the one you put in your ear.....
Yours in awe....
Wolfie
P.S. Is the Dexter the one we saw on Perfect Match?
Don't worry 'bout me... just takin' da plss.....
AnswerID: 153178
Follow Up By: Richard Kovac - Tuesday, Feb 07, 2006 at 01:33
why
FollowupID: 407436
Reply By: desert - Sunday, Feb 05, 2006 at 20:46
Probably not what you wanted, but would it not be cheaper, more accessable re-parts, to convert to drum brakes then run the common electrical braking system that 90% of the rest of vans have??
AnswerID: 153200
Reply By: Eric Experience. - Sunday, Feb 05, 2006 at 22:19
Collyn
Not the answer you are looking for, but I overcame the same problem by using the brake control as a current proportional to braking effort to drive a modified abs pump, the pump was running in a stalled mode but the current is low, so is not enough to burn out the armature. Eric.
AnswerID: 153223
Reply By: anoldbuddy - Sunday, Feb 05, 2006 at 23:04
Collyn,
Your topic is complex. We looked into similar issues when purchasing a new boat trailer for a 2.5 tonne all-up boat rig which required breakaway brakes. Looked at the Titan - spoke to the guys at Cleveland who manufacture them. Had mixed feelings about the longevity. In the end, we chose a trailer that had a Sensor brake system - sold by Alko. The electro-hydraulic unit is really quite smart but requires a special in-car processor unit. We went down that path and outfitted 3 cars with the unit @ around the $500 each. The car unit is smart and senses whether you have a Sensor brake system on the trailer or a normal electric brake system ( my caravan) and sets it programme accordingly. the sensor unit uses an 12 pin flat connector (two rows) but is interconnected to my normal 7 pin round for when other trailers are attached. The unit uses a pressure sensitive pad on the brake pedal - works brilliantly and is far more precise and linear in action than any Tokensha unit I have ever experienced.
In operation, the trailer unit only takes about 10-20 seconds to pump up to full pressure from a cold start. If you disconnect the car, the unit locks on the brakes using the available pressure in the reservoir.
Hope this helps however, it might be a bit tangential if you are absolutely set on using the prodigy as your controller. Good luck
Anoldbuddy.
AnswerID: 153236
Reply By: Flash - Monday, Feb 06, 2006 at 01:06
Keep us informed Collyn as I've just about "had" electric drums and am seriously considering upgrading to disks. The brake controller is one area I have concerns about.
I'm even toying with making my own hydraulic pump..... but that project has a looong way to go.
AnswerID: 153250
Reply By: Member - Collyn R (WA) - Monday, Feb 06, 2006 at 10:43
Thank you for suggestions so far.
Before getting into this I was aware of the possible problems (due mainly to lack on an interface standard) - and a substantial part of the reason for going ahead was to establish what they were - and how they can be resolved.
There are several ways that I know for sure will work (using a different type of controller): the Sensa system is known to work well; and I can also do it using the system that Kimberley Kamper use. But I would prefer to use the Tekosha interface if possible - simply because there's a lot more of them around.
Why disk brakes? Much the same reason I prefer radial tyres over cross-plies for general use. It's 2006!
Collyn Rivers
AnswerID: 153294
