stopping rust spots
Submitted: Monday, Feb 13, 2006 at 21:13
simple
does anybody know of a good / effective way of stopping the rust from starting and continuing in stone chips and a couple of little dents.
suggest away you clever folks
cheers simple
Reply By: Vivid Adventures - Monday, Feb 13, 2006 at 21:18
rust converter
some touch up paint
154780
Reply By: Member - laura B (NSW) - Monday, Feb 13, 2006 at 21:19
back in our silly days we crashed friends ma's car - not very bad though.....bought a nail polish about the same colour and covered the parts without paint anymore......8yrs later the car is still looking good...havent noticed the rust....
Laura B
154781
Follow Up By: Eric from Cape York Connections - Tuesday, Feb 14, 2006 at 07:00
The problem
laura is then my mates would know the colours I have got and could get jealous.
All the best
Eric
408821
Reply By: glenno(qld) - Monday, Feb 13, 2006 at 21:20
Buy one of those cheap grindy bit kits that you put in your drill . Put a pointy one in and carefully grind out the rust . Then paint away .
154783
Reply By: BenSpoon - Monday, Feb 13, 2006 at 21:40
check previous posts.
Get your 2-letter colour code off your firewall placard, go see a panel beater and get them to mix up 500ml of paint for you, and get the hardener in a separate container (the hardner chemically sets the paint, and you can keep your touch up paint in a jar for years if you dont mix in the hardner in up front)
Wash your car (dont wax), use a little paint brush to brush touch, then wax it when almost dry. Unless its a metallic (sparkly paint) you cant even tell. If you wax before you brush touch, it will be like trying to put a cat in a full bath.
154793
Follow Up By: Member - Paul J (ACT) - Tuesday, Feb 14, 2006 at 08:43
That is so cruel, trying to put a cat in a full bath!
Try a full bucket instead, much better, oh, and wear long gloves.
408826
Follow Up By: Vivid Adventures - Tuesday, Feb 14, 2006 at 08:50
easiest if you flatten out the cat first - then you can do it without gloves.
408827
Follow Up By: Member - Paul J (ACT) - Tuesday, Feb 14, 2006 at 10:01
Reminds me of a bumper sticker I saw once,
"A good cat, is a flat cat"
408841
Reply By: The Rambler( W.A.) - Tuesday, Feb 14, 2006 at 00:19
Fisholene and then auto touch up paint
154825
