water tank bad taste
Submitted: Monday, Mar 20, 2006 at 11:19
ThreadID: 31928 Views:7291 Replies:11 FollowUps:1
I've got a water tank under my CT and it gets a bad 'iodine' type taste in the water. You can even taste it in coffee and tea made from it. I've flushed it with chlorine and also tried vinegar, but it comes back. Any ideas please?
Reply By: Footloose - Monday, Mar 20, 2006 at 11:23
Have you tried searching the archives, I seem to remember a few with this problem with lots of solutions. One I vividly remember is not to fill your tank from a hose unless you let the hose run for a bit, apparently water already in the hose bakes in the sun etc and isn't conducive to great water in a tank.
AnswerID: 161642
Reply By: Member - Roachie (SA) - Monday, Mar 20, 2006 at 11:26
On the Forum of Ultimate Camper owners, there has been some discussion about this matter too.
The method that seems to work is to half fill the tank with water and add a liberal dose of BiCarb soda.......take the camper for a drive to slosh the mixture all about and then empty it out.
Hope this will assist.
AnswerID: 161647
Reply By: Member - Ian W (NSW) - Monday, Mar 20, 2006 at 11:29
Try Bias Boating Marine or Whitworths Nautical World for tank flushing/taste remover products or alternativly give your tank a heavy dose of bicarbonate of soda, allow to sit for 24Hrs then flush.
I believe from may previous posts that the type of hose you use to fill the tank can have an effect. I use my garden hose that lays around on the front/back lawn and have no problems to date.
Best of luck
Ian
AnswerID: 161648
Follow Up By: agsmky - Monday, Mar 20, 2006 at 11:59
As roachie has stated, it is better to slosh the stuff around....bicarb is a cleaner/scourer and not a disinfectant, therefore it will do more if agitated. It's fine particles actually loosen any contaminants off the container and this should be flushed out then. The other thing to do is just before you drain the tank, take it for a quick drive etc to stir the water. This will make sure you get all the crap out that has settled on the bottom of your tank.
BTW twinkles, what type of material is the tank made from, plastic, fiberglass or SS. Some members may have a better way to remove the taste from different containers.
andrew
FollowupID: 416370
Reply By: muzbry 3175 - Monday, Mar 20, 2006 at 12:08
Gday
The old wifes tale is to give the tank a liberal squirt of lemon concentrate ....we did that with ours and never have had a bad flavour.
AnswerID: 161654
Reply By: 3.0turbob - Monday, Mar 20, 2006 at 12:34
I had a similar problem with mine (black plastic water tank) as well as "floaties" in the water. I had always drained it as much as I could after a trip, even jacking up one side to help it drain. Anyway I ended up taking the tank out, cutting a hole in the top, so I could actualy get my hand inside and give it a good scrub. I made a cover from stainless steel glued some rubber strip to it and screwed it back into place with some stainless anchor clips for the stainless screws. So now I know its clean.
Rob
AnswerID: 161661
Reply By: govo - Monday, Mar 20, 2006 at 13:08
Purchased a CT back in 1996 and fitted a 70 ltre black plastic tank under it...we tried every trick mentioned above until a mate at work sugested Coke....i poured avout 4 ltres of Coke Cola in it and left for on there for a month...since then the water comes out the same taste it went it...l have heard that the lemon concentrate does work too
AnswerID: 161670
Reply By: Member - Doug T (QLD) - Monday, Mar 20, 2006 at 14:02
Could be from the hose , check the post from earlier today Post No ID: 31915
AnswerID: 161682
Reply By: cokeaddict - Monday, Mar 20, 2006 at 14:11
Hey Twinkles,
I havea 95ltr stainless steel tank mounted under floor of my GQ, I recently had the water go "off" so i drained it, half filled it with water and 2 packs of bi carb..took it to Menai for a few hours of sloshing around (and a fun muddy day ) and came home. Sat the car over night, then went back down for 30 minutes of rough stuff. Drained it at Menai when i finished having fun. Came home re filled it..drained it again..refilled it and now its fresh again.
I found out its caused by the filling hose i use, clear plastic and sits in sun when not used...not a good thing to do. So now I havea proper black hose that stoppes any sunlight getting in.
Ange
AnswerID: 161683
Reply By: bmwrider - Monday, Mar 20, 2006 at 17:47
I had the same problem with my Jayco Finch. Went to a Caravan supplies place. They had a number of products. Some which required completely flushing and removing the tank and such. I found something called CAMCO/RV Taste Pure. You add this as directed to the tank and it eliminates the taste. Cost $20. You use 1oz per 20 gallons of water. Will last for ages. 16oz container. Easy as.
Garry
AnswerID: 161716
Reply By: Twinkles - Monday, Mar 20, 2006 at 17:52
Thanks everyone. I'll try these one by one 'til I get it right.
AnswerID: 161717
Reply By: Rod - Wednesday, Mar 22, 2006 at 12:44
I used half a bottle of vanilla essence and half filled the black poly tank with water. Was cheap and effective.
AnswerID: 162200
